论作为TE分析IC的初步报的基本格式
:lol:
本来IC分析起来是很复杂的,但是我发现很多电子厂的TE真的好拉级,即使没有专用的测试设备分析也不至于分析报告就几句话完了,平常人根本一点也看不懂!
小弟初来咋到,听大家多多指点,作为一个SQA对TE的分析报告只要做到以下几点我想 可能会更懂一些吧!
IC FA primary report format
a. According to IC diagram find GND location, use multimeter to respectively test OK and NG material.
b. contrast data
many find defects? dosage big or small per day? if happen
before this time.
b: find OK and NG variation
c: conclusion
b: Result B.
c. Contrast A and B result
c.1.Different board test result is same, show that the board can’t influence IC .
c.2.Different board test result is different, show that the different board can influence IC,
The issue may be board Matching issue.
- [] Issue Background and description.[/][]Condition[/][]Compare OK and NG test read data[/][]Swap test[/]
b. contrast data
- []Summary[/][]Issue Background and description.[/]
before this time.
- []Condition[/] No standard equipment to identify, so only pass defective phenomenon to judge defect.(2) a: Inspect appearance and give five defects mark number. Carefully inspect appearance under 10x magnifier then mark number on inverse. b: do x-ray observe their wire if sweep or open c: check all interrelated ESD, including operation tact and static desk and equipment in production line. Record inspect result and test data which including machine/equipment/operation platform contrast to our spec.[list=1][]Compare OK and NG test read data [/]
c: conclusion
- []Swap test (Use illustration mark fail item)[/]
b: Result B.
- [] summary[/]
9 个回复
wang_ping_chuan (威望:0) (广东 深圳) 电子制造 工程师 -
请问你在那上班!
