模具专业英语
模具专业英语
模具专业英语
一、入水:gate
进入位: gate location
水口形式:gate type
大水口:edge gate
细水口: pin-point gate
水口大小:gate size
转水口: switching runner/gate
唧嘴口径: sprue diameter
二、流道: runner
热流道: hot runner,hot manifold
热嘴冷流道: hot sprue/cold runner
唧嘴直流: direct sprue gate
圆形流道:round(full/half runner
流道电脑分析:mold flow analysis
流道平衡:runner balance
热嘴: hot sprue
热流道板:hot manifold
发热管:cartridge heater
探针: thermocouples
插头: connector plug
插座: connector socket
密封/封料: seal
三、运水:water line
喉塞:line lpug
喉管:tube
塑胶管:plastic tube
快速接头:jiffy quick connector plug/socker
四、模具零件: mold components
三板模:3-plate mold
二板模:2-plate mold
边钉/导边:leader pin/guide pin
边司/导套:bushing/guide bushing
中托司:shoulder guide bushing
中托边L:guide pin
顶针板:ejector retainner plate
托板: support plate
螺丝: screw
管钉:dowel pin
开模槽:ply bar scot
内模管位:core/cavity inter-lock
顶针: ejector pin
司筒:ejector sleeve
司筒针:ejector pin
推板:stripper plate
缩呵:movable core,return core core puller
扣机(尼龙拉勾):nylon latch lock
斜顶:lifter
模胚(架): mold base
上内模:cavity insert
下内模:core insert
行位(滑块): slide
镶件:insert
压座/斜鸡:wedge
耐磨板/油板:wedge wear plate
压条:plate
撑头: support pillar
唧嘴: sprue bushing
挡板:stop plate
定位圈:locating ring
锁扣:latch
扣鸡:parting lock set
推杆:push bar
栓打螺丝:S.H.S.B
顶板:eracuretun
活动臂:lever arm
分流锥:spure sperader
水口司:bush
垃圾钉:stop pin
隔片:buffle
弹弓柱:spring rod
弹弓:die spring
中托司:ejector guide bush
中托边:ejector guide pin
镶针:pin
销子:dowel pin
波子弹弓:ball catch
喉塞: pipe plug
锁模块:lock plate
斜顶:angle from pin
斜顶杆:angle ejector rod
尼龙拉勾:parting locks
活动臂:lever arm
复位键、提前回杆:early return bar
气阀:valves
斜导边:angle pin
术语:terms
承压平面平衡:parting surface support balance
模排气:parting line venting
回针碰料位:return pin and cavity interference
模总高超出啤机规格:mold base shut hight
顶针碰运水:water line interferes withejector pin
料位出上/下模:part from cavith (core) side
模胚原身出料位:cavity direct cut on A-plate,core direct cut on B-plate.
不准用镶件: Do not use (core/cavity) insert
用铍铜做镶件: use beryllium copper insert
初步(正式)模图设计:preliinary (final) mold design
反呵:reverse core
弹弓压缩量:spring compressed length
稳定性好:good stability,stable
强度不够:insufficient rigidity
均匀冷却:even cooling
扣模:sticking
热膨胀:thero expansion
公差:tolorance
铜公(电极):copper electrode
dowel pin 定位梢
draft 拔模锥度
draw bead 张力调整杆
drive bearing 传动轴承
ejection pad 顶出衬垫
ejector 脱模器
ejector guide pin 顶出导梢
ejector leader busher 顶出导梢衬套
ejector pad 顶出垫
ejector pin 顶出梢
ejector plate 顶出板
ejector rod 顶出杆
ejector sleeve 顶出衬套
ejector valve 顶出阀
eye bolt 环首螺栓
filling core 椿入蕊
film gate 薄膜形浇口
finger pin 指形梢
finish machined plate 角形模板
finish machined round plate 圆形模板
fixed bolster plate 固定侧模板
flanged pin 带凸缘销
flash gate 毛边形浇口
flask 上箱
floating punch 浮动冲头
gate 浇口
gate land 浇口面
gib 凹形拉紧楔
goose neck 鹅颈管
guide bushing 引导衬套
guide pin 导梢
guide post 引导柱
guide plate 导板
guide rail 导轨
head punch 顶头冲孔
headless punch 直柄冲头
heavily tapered solid 整体模蕊盒
hose nippler 管接头
impact damper 缓冲器
injection ram 压射柱塞
inlay busher 嵌入衬套
inner plunger 内柱塞
inner punch 内冲头
insert 嵌件
insert pin 嵌件梢
king pin 转向梢
king pin bush 主梢
模具相关英语(3)
difference quantity差异量
cause analysis原因分析
raw materials原料
materials物料
finished product成品
semi-finished product半成品
packing materials包材
good product/accepted goods/ accepted parts/good parts良品
defective product/non-good parts不良品
disposed goods处理品
warehouse/hub仓库
on way location在途仓
oversea location海外仓
spare parts physical inventory list备品盘点清单
spare molds location模具备品仓
skid/pallet栈板
tox machine自铆机
wire EDM线割
EDM放电机
coil stock卷料
sheet stock片料
tolerance工差
score=groove压线
cam block滑块
pilot导正筒
trim剪外边
pierce剪内边
drag form压锻差
pocket for the punch head挂钩槽
slug hole废料孔
feature die公母模
expansion dwg展开图
radius半径
shim(wedge)楔子
torch-flame cut火焰切割
set screw止付螺丝
form block折刀
stop pin定位销
round pierce punch=die button圆冲子
shape punch=die insert异形子
stock locater block定位块
under cut=scrap chopper清角
active plate活动板
baffle plate挡块
cover plate盖板
male die公模
female die母模
groove punch压线冲子
air-cushion eject-rod气垫顶杆
spring-box eject-plate弹簧箱顶板
bushing block衬套
insert 入块
club car高尔夫球车
capability能力
parameter参数
factor系数
phosphate皮膜化成
viscosity涂料粘度
alkalidipping脱脂
main manifold主集流脉
bezel斜视规
blanking穿落模
dejecting顶固模
demagnetization去磁;消磁
high-speed transmission高速传递
heat dissipation热传
rack上料
degrease脱脂
rinse水洗
alkaline etch龄咬
desmut剥黑膜
D.I. rinse纯水次
Chromate铬酸处理
Anodize阳性处理
seal封孔
revision版次
part number/P/N料号
good products良品
scraped products报放心品
defective products不良品
finished products成品
disposed products处理品
barcode条形码
flow chart流程窗体
assembly组装
stamping冲压
molding成型
spare parts=buffer备品
模具相关英语(4)
coordinate坐标
dismantle the die折模
auxiliary fuction辅助功能
poly-line多义线
heater band 加热片
thermocouple热电偶
sand blasting喷沙
grit 砂砾
derusting machine除锈机
degate打浇口
dryer烘干机
induction感应
induction light感应光
response=reaction=interaction感应
ram连杆
edge finder巡边器
concave 凹
convex凸
short射料不足
nick缺口
speck瑕疪
shine亮班
splay 银纹
gas mark焦痕
delamination起鳞
cold slug冷块
blush 导色
gouge沟槽;凿槽
satin texture段面咬花
witness line证示线
patent专利
grit沙砾
granule=peuet=grain细粒
grit maker抽粒机
cushion缓冲
magnalium镁铝合金
magnesium镁金
metal plate钣金
lathe车
mill锉
plane刨
grind磨
drill钻
boring镗
blinster气泡
fillet镶;嵌边
through-hole form通孔形式
voller pin formality滚针形式
cam driver铡楔
shank摸柄
crank shaft曲柄轴
augular offset角度偏差
velocity速度
production tempo生产进度现状
torque扭矩
spline=the multiple keys花键
quenching淬火
tempering回火
annealing退火
carbonization碳化
alloy合金
tungsten high speed steel钨高速的
moly high speed steel钼高速的
organic solvent有机溶剂
bracket小磁导
liaison联络单
volatile挥发性
resistance电阻
ion离子
titrator滴定仪
beacon警示灯
coolant冷却液
crusher破碎机
模具工程类
plain die简易模
pierce die冲孔模
forming die成型模
progressive die连续模
gang dies复合模
shearing die剪边模
riveting die铆合模
pierce冲孔
forming成型(抽凸,冲凸)
draw hole抽孔
bending折弯
trim切边
emboss凸点
dome凸圆
模具相关英语(5)
semi-shearing半剪
stamp mark冲记号
deburr or coin压毛边
punch riveting冲压铆合
side stretch侧冲压平
reel stretch卷圆压平
groove压线
blanking下料
stamp letter冲字(料号)
shearing剪断
tick-mark nearside正面压印
tick-mark farside反面压印
冲压名称类
extension dwg展开图
procedure dwg工程图
die structure dwg模具结构图
material材质
material thickness料片厚度
factor系数
upward向上
downward向下
press specification冲床规格
die height range适用模高
die height闭模高度
burr毛边
gap间隙
weight重量
total wt.总重量
punch wt.上模重量
五金零件类
inner guiding post内导柱
inner hexagon screw内六角螺钉
dowel pin固定销
coil spring弹簧
lifter pin顶料销
eq-height sleeves=spool等高套筒
pin销
lifter guide pin浮升导料销
guide pin导正销
wire spring圆线弹簧
outer guiding post外导柱
stop screw止付螺丝
located pin定位销
outer bush外导套
模板类
top plate上托板(顶板)
top block上垫脚
punch set上模座
punch pad上垫板
punch holder上夹板
stripper pad脱料背板
up stripper上脱料板
male die公模(凸模)
feature die公母模
female die母模(凹模)
upper plate上模板
lower plate下模板
die pad下垫板
die holder下夹板
die set下模座
bottom block下垫脚
bottom plate下托板(底板)
stripping plate内外打(脱料板)
outer stripper外脱料板
inner stripper内脱料板
lower stripper下脱料板
零件类
punch冲头
insert入块(嵌入件)
deburring punch压毛边冲子
groove punch压线冲子
stamped punch字模冲子
round punch圆冲子
special shape punch异形冲子
bending block折刀
roller滚轴
baffle plate挡块
located block定位块
supporting block for location
定位支承块
air cushion plate气垫板
trimming punch切边冲子
stiffening rib punch = stinger 加强筋冲子
ribbon punch压筋冲子
reel-stretch punch卷圆压平冲子
guide plate定位板
sliding block滑块
101个热处理常用英文词汇
  1. indication 缺陷
  2. test specimen 试样
  3. bar 棒材
  4. stock 原料
  5. billet 方钢,钢方坯
  6. bloom 钢坯,钢锭
  7. section 型材
  8. steel ingot 钢锭
  9. blank 坯料,半成品
  10. cast steel 铸钢
  11. nodular cast iron 球墨铸铁
  12. ductile cast iron 球墨铸铁
  13. bronze 青铜
  14. brass 黄铜
  15. copper 合金
  16. stainless steel不锈钢
  17. decarburization 脱碳
  18. scale 氧化皮
  19. anneal 退火
  20. process anneal 进行退火
  21. quenching 淬火
  22. normalizing 正火
  23. Charpy impact text 夏比冲击试验
  24. fatigue 疲劳
  25. tensile testing 拉伸试验
  26. solution 固溶处理
  27. aging 时效处理
  28. Vickers hardness维氏硬度
  29. Rockwell hardness 洛氏硬度
  30. Brinell hardness 布氏硬度
  31. hardness tester硬度计
  32. descale 除污,除氧化皮等
  33. ferrite 铁素体
  34. austenite 奥氏体
  35. martensite马氏体
  36. cementite 渗碳体
  37. iron carbide 渗碳体
  38. solid solution 固溶体
  39. sorbite 索氏体
  40. bainite 贝氏体
  41. pearlite 珠光体
  42. nodular fine pearlite/ troostite屈氏体
  43. black oxide coating 发黑
  44. grain 晶粒
  45. chromium 铬
  46. cadmium 镉
  47. tungsten 钨
  48. molybdenum 钼
  49. manganese 锰
  50. vanadium 钒
  1. molybdenum 钼
  2. silicon 硅
  3. sulfer/sulphur 硫
  4. phosphor/ phosphorus 磷
  5. nitrided 氮化的
  6. case hardening 表面硬化,表面淬硬
  7. air cooling 空冷
  8. furnace cooling 炉冷
  9. oil cooling 油冷
  10. electrocladding /plating 电镀
  11. brittleness 脆性
  12. strength 强度
  13. rigidity 刚性,刚度
  14. creep 蠕变
  15. deflection 挠度
  16. elongation 延伸率
  17. yield strength 屈服强度
  18. elastoplasticity 弹塑性
  19. metallographic structure 金相组织
  20. metallographic test 金相试验
  21. carbon content 含碳量
  22. induction hardening 感应淬火
  23. impedance matching 感应淬火
  24. hardening and tempering 调质
  25. crack 裂纹
  26. shrinkage 缩孔,疏松
  27. forging 锻(件)
  28. casting 铸(件)
  29. rolling 轧(件)
  30. drawing 拉(件)
  31. shot blasting 喷丸(处理)
  32. grit blasting 喷钢砂(处理)
  33. sand blasting 喷砂(处理)
  34. carburizing 渗碳
  35. nitriding 渗氮
  36. ageing/aging 时效
  37. grain size 晶粒度
  38. pore 气孔
  39. sonim 夹砂
  40. cinder inclusion 夹渣
  41. lattice晶格
  42. abrasion/abrasive/rub/wear/wearing resistance (property) 耐磨性
  43. spectrum analysis光谱分析
  44. heat/thermal treatment 热处理
  45. inclusion 夹杂物
  46. segregation 偏析
  47. picking 酸洗,酸浸
  48. residual stress 残余应力
  49. remaining stress 残余应力
  50. relaxation of residual stress 消除残余应力
  51. stress relief 应力释放
机械类常用英语:冲压模具-零件类
punch冲头
insert入块(嵌入件)
groove punch压线冲子
stamped punch字模冲子
round punch圆冲子
bending block折刀
roller滚轴
baffle plate挡块
located block定位块
定位支承块
trimming punch切边冲子
ribbon punch压筋冲子
guide plate定位板
sliding block滑块
sliding dowel block滑块固定块
active plate活动板
lower sliding plate下滑块板
upper holder block上压块
upper mid plate上中间板
spring box弹簧箱
spring-box eject-rod弹簧箱顶杆
bushing bolck衬套
cover plate盖板
guide pad导料块
各式模具分类用语英汉对照
landed plunger mold 有肩柱塞式模具
burnishing die 挤光模
landed positive mold 有肩全压式模具
button die 镶入式圆形凹模
loading shoe mold 料套式模具
center-gated mold 中心浇口式模具
loose detail mold 活零件模具
chill mold 冷硬用铸模
loose mold 活动式模具
clod hobbing 冷挤压制模
louvering die 百叶窗冲切模
composite dies 复合模具
manifold die 分歧管模具
counter punch 反凸模
modular mold 组合式模具
double stack mold 双层模具
multi-cavity mold 多模穴模具
electroformed mold 电铸成形模
multi-gate mold 复式浇口模具
expander die 扩径模
offswt bending die 双折冷弯模具
extrusion die 挤出模
palletizing die 叠层模
family mold 反套制品模具
plaster mold 石膏模
blank through dies 漏件式落料模
porous mold 通气性模具
duplicated cavity plate 复板模
positive mold 全压式模具
fantail die 扇尾形模具
pressure die 压紧模
fishtail die 鱼尾形模具
profile die 轮廓模
flash mold 溢料式模具
progressive die 顺序模
gypsum mold 石膏铸模
protable mold 手提式模具
hot-runner mold 热流道模具
prototype mold 雏形试验模具
ingot mold 钢锭模
punching die 落料模
lancing die 切口模
aising(embossing) 压花起伏成形
re-entrant mold 倒角式模具
sectional die 拼合模
runless injection mold 无流道冷料模具
sectional die 对合模具
segment mold 组合模
semi-positive mold 半全压式模具
shaper 定型模套
single cavity mold 单腔模具
solid forging die 整体锻模
split forging die 拼合锻模
split mold 双并式模具
sprueless mold 无注道残料模具
squeezing die 挤压模
stretch form die 拉伸成形模
sweeping mold 平刮铸模
swing die 振动模具
three plates mold 三片式模具
trimming die 切边模
unit mold 单元式模具
universal mold 通用模具
unscrewing mold 退扣式模具
yoke type die 轭型模
注塑模部分中英文对照
塑料成形模具   mould for plastics
热塑性塑料模   mould for thermoplastics
热固性塑料模   mould for thermosets
压缩模   compression mould
压注模、传递模   transfer mould
注射模   injection mould
热塑性塑料注射模   injection mould for thermoplastics
热固性塑料注射模   injection mould for thermoses
成形零件
定模   stationary mould fixed half
动模   movable mould moving half
定模座板   fixed clamp plate, top clamping plate. top plate
动模座板   moving clamp plate. bottom clamping plate. bottom plate
上模座板   upper clamping plate
下模座板   lower clamping plate
凹模固定板   cavity-retainer plate
型芯固定板   core-retainer plate
凸模固定板   punch-retainer plate
模套   chase. bolster. frame
支承板   backing plate. supprr plate
垫块   spacer parallel
支架   ejector housing. mould base leg
模具工程常用词汇英汉对照
die 模具
figure file, chart file图档
cutting die, blanking die冲裁模
progressive die, follow (-on)die
连续模
compound die复合模
punched hole冲孔
panel board镶块
to cutedges=side cut=side scrap切边
to bending折弯
to pull, to stretch拉伸
Line streching, line pulling线拉伸
engraving, to engrave刻印
upsiding down edges翻边
to stake铆合
designing, to design设计
design modification设计变化
die block模块
folded block折弯块
sliding block滑块
location pin定位销
lifting pin顶料销
die plate, front board模板
padding block垫块
stepping bar垫条
upper die base上模座
lower die base下模座
upper supporting blank上承板
upper padding plate blank上垫板
spare dies模具备品
spring 弹簧
bolt螺栓
document folder文件夹
file folder资料夹
to put file in order整理资料
spare tools location手工备品仓
first count初盘人
first check初盘复棹人
second count 复盘人
second check复盘复核人
equipment设备
waste materials废料
work in progress product在制品
casing = containerazation装箱
quantity of physical invetory second count 复盘点数量
quantity of customs count
会计师盘,点数量
the first page第一联
filed by accounting department for reference会计部存查
end-user/using unit(department)使用单位
summary of year-end physical inventory bills
年终盘点截止单据汇总表
bill name单据名称
This sheet and physical inventory list will be sent to accounting
department together (Those of NHK will be sent to financial
department)
本表请与盘点清册一起送会计部-(NHK厂区送财会部)
Application status records of year-end physical inventory List and
physical inventory card 年终盘点卡与清册使用-状况明细表
blank and waste sheet NO.
空白与作废单号
plate电镀
mold成型
material for engineering mold testing工程试模材料
not included in physical inventory不列入盘点
sample样品
incoming material to be inspected进货待验
description品名
steel/rolled steel钢材
material statistics sheet
物料统计明细表
meeting minutes会议记录
meeting type 会别
distribution department分发单位
location地点
chairman主席
present members出席人员
subject主题
conclusion结论
decision items决议事项
responsible department负责单位
pre-fixed finishing date预定完成日
approved by / checked by / prepared by核准/审核/承办
PCE assembly production schedule sheet
PCE组装厂生产排配表
model机锺
work order工令
revision版次
remark备注
production control confirmation生产确认
checked by初审
approved by核准
department部门
模具工程常用词汇英汉对照——2
stock age analysis sheet
库存货龄分析表
on-hand inventory现有库存
available material良品可使用
obsolete material良品已呆滞
to be inspected or reworked
待验或重工
total合计
cause description原因说明
part number/ P/N 料号
type形态
item/group/class类别
quality品质
prepared by制表
notes说明
year-end physical inventory difference analysis sheet
年终盘点差异分析表
physical inventory盘点数量
physical count quantity帐面数量
cause analysis原因分析
raw materials原料
materials物料
finished product成品
packing materials包材
disposed goods处理品
warehouse/hub仓库
on way location在途仓
oversea location海外仓
skid/pallet栈板
tox machine自铆机
wire EDM线割
EDM放电机
coil stock卷料
sheet stock片料
tolerance工差
score=groove压线
cam block滑块
pilot导正筒
trim剪外边
pierce剪内边
drag form压锻差
slug hole废料孔
feature die公母模
expansion dwg展开图
radius半径
shim(wedge)楔子
torch-flame cut火焰切割
set screw止付螺丝
form block折刀
stop pin定位销
active plate活动板
baffle plate挡块
cover plate盖板
male die公模
female die母模
groove punch压线冲子
bushing block衬套
insert 入块
club car高尔夫球车
capability能力
parameter参数
factor系数
phosphate皮膜化成
viscosity涂料粘度
alkalidipping脱脂
main manifold主集流脉
bezel斜视规
blanking穿落模
dejecting顶固模
jessica.ben (威望:1) (浙江 杭州) 电子制造 经理 - 枫叶并不是因为红才美丽!
非常全面的,收藏了,谢谢!!!!!!!:( :(
2 个回复,游客无法查看回复,更多功能请登录注册
blacksheep_ivan
blacksheep_ivan
의생활과비교하지말고제자신의생활을즐겨라.
