塑胶模具专业英语
塑胶模具专业英语
塑胶模具专业英语
一、入水:gate
进入位: gate location 水口形式:gate type 大水口:edge gate
细水口: pin-point gate 水口大小:gate size 转水口: switching runner/gate
唧嘴口径: sprue diameter
二、流道: runner
??热流道: hot runner,hot manifold 热嘴冷流道: hot sprue/cold runner
??唧嘴直流: direct sprue gate 圆形流道:round(full/half runner
??流道电脑分析:mold flow analysis 流道平衡:runner balance
??热嘴: hot sprue 热流道板:hot manifold
??发热管:cartridge heater 探针: thermocouples
??插头: connector plug 插座: connector socket
??密封/封料: seal
三、运水:water line 喉塞:line lpug 喉管:tube
塑胶管:plastic tube 快速接头:jiffy quick connector plug/socker
四、模具零件: mold components
??三板模:3-plate mold 二板模:2-plate mold
??边钉/导边:leader pin/guide pin 边司/导套:bushing/guide bushing
??中托司:shoulder guide bushing 中托边L:guide pin
??顶针板:ejector retainner plate 托板: support plate
??螺丝: screw 管钉:dowel pin
??开模槽:ply bar scot 内模管位:core/cavity inter-lock
??顶针: ejector pin 司筒:ejector sleeve
??司筒针:ejector pin 推板:stripper plate
??缩呵:movable core,return core core puller
??扣机(尼龙拉勾):nylon latch lock 斜顶:lifter
??模胚(架): mold base 上内模:cavity insert
??下内模:core insert 行位(滑块): slide
??镶件:insert 压座/斜鸡:wedge
??耐磨板/油板:wedge wear plate 压条:plate
??撑头: support pillar 唧嘴: sprue bushing
??挡板:stop plate 定位圈:locating ring
??锁扣:latch 扣鸡:parting lock set
??推杆:push bar 栓打螺丝:S.H.S.B
??顶板:eracuretun 活动臂:lever arm
??分流锥:spure sperader 水口司:bush
??垃圾钉:stop pin 隔片:buffle
??弹弓柱:spring rod 弹弓:die spring
??中托司:ejector guide bush 中托边:ejector guide pin
??镶针:pin 销子:dowel pin
??波子弹弓:ball catch
模具成形不良用语英汉对照
aberration 色差 atomization ?化 bank mark ?料纹 bite 咬入
blacking hole 涂料孔(铸疵) blacking scab 涂料疤
blister 起泡 blooming 起霜 low hole 破孔 blushing 泛白
body wrinkle 侧壁皱纹 breaking-in 冒口带肉
bubble 膜泡 burn mark 糊斑 burr 毛边 camber 翘曲
cell 气泡 center buckle 表面中部波皱 check 细裂痕 checking 龟裂
chipping 修整表面缺陷 clamp-off 铸件凹痕
collapse 塌陷 color mottle 色斑
corrosion 腐蚀 crack 裂痕
crazing 碎裂 crazing 龟裂
deformation 变形 edge 切边碎片
edge crack 裂边 fading 退色
filler speak 填充料斑 fissure 裂纹
flange wrinkle 凸缘起皱 flaw 刮伤
flow mark 流痕 galling 毛边
glazing 光滑 gloss 光泽
grease pits 污斑 grinding defect 磨痕
haircrack 发裂 haze 雾度
incrustation 水锈 indentation 压痕
internal porosity 内部气孔 mismatch 偏模
mottle 斑点 necking 缩颈
nick 割痕 orange peel 橘皮状表面缺陷
overflow 溢流 peeling 剥离
pit 坑 pitting corrosion 点状腐蚀
plate mark 模板印痕 pock 麻点
pock mark 痘斑 resin streak 树脂流纹
resin wear 树脂脱落 riding 凹陷
sagging 松垂 saponification 皂化
scar 疤痕 scrap 废料
scrap jam 废料阻塞 scratch 刮伤/划痕
scuffing 深冲表面划伤 seam 裂痕
shock line 模口挤痕 short shot 充填不足
shrinkage pool 凹孔 sink mark 凹痕
skin inclusion 表皮折叠 straightening 矫直
streak 条状痕 surface check 表面裂痕
surface roughening 橘皮状表皮皱折 surging 波动
sweat out 冒汗 torsion 扭曲
warpage 翘曲 waviness 波痕
webbing 熔塌 weld mark 焊痕
whitening 白化 wrinkle 皱纹
http://www.bbs.请勿在论坛上使用该链接/viewthread.php?tid=54524&fromuid=53676
fuxianshan (威望:0) (广东 深圳) 电子制造
楼主,不错的总结,常见的比较实用,谢谢了
5 个回复,游客无法查看回复,更多功能请登录注册
zwy204518
zwy204518
卐我的榮譽來自忠誠卐
