塑胶的缩略语(全面,权威)
塑胶的缩略语、英文、中文名一览表
英缩写 英全名 中文名
AAS Acrylonitrile-Bcry ate-styrene opolymer 丙烯腈一丙烯酸脂一苯乙烯共聚物
ABS Acrylonitrile-butadiene-styrene 丙烯腈一丁二烯丙烯一苯乙烯共聚物
ALK Alkyd resin 醇酸树脂
AMMA Acrylonitrile-methylmethacrylate copolymer 丙烯腈一甲基丙烯酸甲脂共 聚物
AMS Alpha methyl styrene a甲基苯乙烯
AS Acrylonitrile-styrene copolymer(see SAN) 丙烯腈一苯乙烯共聚物
ASA Acrylonitrile styrene-acrylate copolymer(AAS) 丙烯腈一苯乙烯一丙烯酸脂共聚物
BMC Bulk moulding compound 预制整体模塑料
CA Cellulose acetate 乙酸纤维素
CAB Cellulose acetate butyrate 乙酸一丁酸纤维素
CAP Cellulose acetate propionate 醋酸一丙酸纤维素
CF Casein formaldehyde resin 甲酚一甲醛树脂
CFE Polychlorotrfluoroethylene(see PCTFE) 聚三氯氧乙烯
CM Chlorinated polyethylene(see CPE) 氯化聚乙烯
CMC Carboxymethyl cellulose 碳甲基纤维素
CN Cellulose nitrate 硝酸纤维素
COPE Polyether ester elastomer 聚醚脂弹性体
CP Cellulose propionate(CAP) 丙酸纤维素
CPE Chlorinated polyethylene(PE-C) 氯化聚乙烯
CPVC Chlorinated polyvinyl Chloride(PVC-C) 氯化聚氯乙烯
CS Casein plastics 酪素塑料
CSM &cspr Chorosulfonated polyethylene 氯磺化聚乙烯
CTA Cellulose triacetate 三乙酸纤维素
DMC Dough moulding tompound 圈状模塑料
E/P Ethylene propylene copolymer 乙烯一丙烯共聚物
CA-MPR Elastomer alloy melt processable rubber 弹性体合金一可熔融成型橡胶
EA-TPV Elastomer alloy thermoplastic vulcanizate 弹性体合金一热塑性硫化料
EC Ethylene cellulose 乙基纤维素
EEA Ethylene ethylacrylate copolymer 乙烯一丙烯酸乙酯共聚物
EP Epoxide or epoxy(cured) 环氧树脂
EPDM Ethylene propylene diene terpolymer 乙丙三元共聚物
EPS Expandable polystyrene 可发性聚苯乙烯
ETFE Ethylene/tetrafluoroethylene 乙烯一四氟乙烯共聚物
EVA Ethylene vinyl accetate copolymer 乙烯一乙酸乙烯酯共聚物
EVAL/EVOH Ethylene vinyl alcohol copolymer 乙烯一乙烯醇共聚物
FEP Fluorinated ethylene propylene(TFE-HEP) 四氟乙烯一六氟丙烯共聚物
CPMC Granular polyester moulding compound 粒状聚酯模塑料
HDPE High density ployethylene(PE-HD) 高密度聚乙烯
HIPS High impact polystyrene(TPS or IPS) 高抗冲聚苯乙烯
HMWPE High molecular weight polyethylene 高分子量聚乙烯
LCP Liquid crystal polymer 液晶聚合物
LDPE Low Density polyethylene(PE-LD) 低密度聚乙烯
LLDPE Linear low density polyethylene 线型低密度聚乙烯
MBS Methyl methacrylate-butadiem-styrene copolymer 甲基丙烯酸甲酯一丁二烯一苯乙烯共聚物
MC Methyl cellutose 甲基纤维素
MDPE Medium density polyethylene(PE MD) 中密度聚乙烯
MF Melamine formaldehyde 三聚氰胺一甲醛树脂
MPF Melamine phenol formaldehyde resin 三聚氰胺一酚甲醛树脂
NC Nitroncellulose 硝基纤维素
PA Polyamide or nylon 聚酰胺(尼龙)
PA6 Polyamide 6 or nylon 6 尼龙6
PA11 Polyamide 11 or nylon 11 尼龙11
PA12 Polyamide 12 or nylon 12 尼龙12
PA46 Polyamide 46 or nylon 46 尼龙46
PA66 Polyamide 66 or nylon 66 尼龙66
PA610 Polyamide 610 or nylon 610 尼龙610
PAA Polyacrylic acid 聚丙烯酸
PAA6 Polyaryl amide or,poly-m-xylene-adipamide(PA MXD6) 聚芳酰胺
PAN Polyacrylonitrile 聚丙烯腈
PB Polybutene-1 聚丁烯-1
PBI Polybenzimidazole 聚苯并咪唑
PBT Polybutylene terephthalate 聚对苯二甲酸丁二醇酯
PC Polycarbonate 聚碳酸脂(防弹胶)
PCTFE Polychlorotrifluorethylene 聚三氟氯乙烯
PDAP Polydiallyl phthalate 聚鄰苯二酸二烯丙酯
PE Polyethylene 聚乙烯
PEBA Polyether block amide 酯一酰嵌段共聚物
PEC Chorinated polyethlene (see CPE) 氯化聚乙烯
PEEK Polyether ether ketone 聚醚醚酮
PEEL Polyether ester(YPBO) 聚醚脂
PEI Polyether imide 聚醚酰亚胶
PEK Polyether ketone 聚醚酮
PEKK Polyethylene ketone ketone 聚醚酮酮
PEOX Polyetylene(oxlde) 聚氧化乙烯
PES Polyether sulphone 聚醚砜
PET Polyethylene terephthalate 聚对苯二甲酸乙二醇酯
PETP (see PET)
PF Phenol formaldehyde resin 酚醛树脂
PI Polyimide 聚酰亚胺
PMC Polyester moulding compound 聚酯模塑料
PMCA Polymethy α-chloacrylate 聚α--氯化丙烯酸甲酯
PMI Polymethacrylimide 聚甲基丙烯酰亚胺
PMMA Polymethyl methacrylate(acrylic) 聚甲基丙烯酸甲酯
PMMA-T Toughened acrylic 增靱聚丙烯酸酯
PO Polyolefine 聚烯烃
POM Polyoxymethylene or,acetal or polyformaldehyde 聚甲醛
POM-CO Acetal copolymer 聚甲醛共聚物
POM-H Acetal homopolymer 聚甲醛均聚物
PP polypropylene 聚丙烯
PPC Chlorinated polypropylene 氯化聚丙烯
PPE Polyphenylene ether(ss PPO) 聚苯醚
PPO Polyphenylene oxide-usually modified 聚苯醚
PPOX Polypropylene oxide 聚氧化丙烯
PPS Polyphenylene sulphide 聚苯硫醚
PPSU Polyethylene sulfone 聚苯砜
PPVC Plasticised polyvinyl chloride(PVC-P) 增塑聚氯乙烯
PS Polystyrene(GPPS) 聚苯乙烯
PSU Polysulphone 聚砜树脂
PTFE Polytetyafluoroethylene 聚四氟乙烯
PU Hard polyurethane elastomer 硬聚氨脂弹性体
PUR Polyurethane 聚氨脂
PVAC Polyvinylacetate 聚乙酸乙烯脂
PVAL Polyvinylalcohol 聚乙烯醇
PVB Polyvinylbutyral 聚乙烯醇缩丁醛
PVC Polyvinyl chloride 聚氯乙烯
PVCC Chlorinated polyvinyl chloride 氯化聚氯乙烯
PVDC Polyvinylidene chloride 聚偏二氯乙烯
PVDF Polyvinylidene fluoride 聚偏二氟乙烯
PVF Polyvinyl fluorde 聚氟乙烯
PVFM Polyvinylformal 聚乙烯醇缩甲醛
PVK Polyvinyl carbazole 聚乙烯基咔唑
PVP Polyvinyl pyrrolidone 聚乙烯吡咯烷酮
SAN Styrene acrylonitrile copolymer 苯乙烯一丙烯腈共聚物(透明大力膠)
SBS Styrene butadiene styrene block copolymer 苯乙烯一丁二一苯乙烯嵌共聚物
SEBS Styrene butadiene styrene block copolymer(saturated) 苯乙烯一丁二烯一苯乙烯嵌共聚物(胞和)
SI Silicone 聚硅氧烷
SMA Styrene_maleic anhydride copolymer 苯乙烯一马来酐共聚物
SMC Sheet moulding compound 片状摸塑料
SMS Styrene_methylstyrene copolymer 苯乙烯一甲基苯乙共聚物
TP-EE Thermoplastic elastomer-either ester 醚酯类热塑性弹性体
TP-EPDM Thermoplastic elastomer-based on EPDM 三元乙丙橡膠类热塑性弹性体
TP-EVA Thermoplastic elastomer-baged on EVA 乙烯乙酸酯共聚物类热塑性弹性体
TP-NBR Thermoplastic elastomer-based on NBR 丁腈橡膠类热塑性弹性体
TPE Thermoplastic elastomer rubber 热塑性弹性体
TPO Thermoplastic polyolefin 热塑性聚烯烃
TPO-XL Thermoplastic polyolefin rubber-crosslinked(rubber) 交联热塑性聚烯烃橡膠
TPR Thermoplastic rubber(etaslomer) 热塑性橡膠
TPU Thermoplastic polyurethance 热塑性聚氧脂
TPV Thermoplastic elastomer or rubber-crosslinked(rubber) 交联热塑性弹性体或橡膠
UF Urea formaldehyde 脲醛树脂
UHMWPE Ultrahigh molecular weight polyethylene 超高分子量聚乙烯
UP Unseturated polyester resin 不胞和聚脂树脂
UPVC Unplasticsed polychloride 末增塑聚氧乙烯
VC/E Vinylchloride ethylene copolymer 氯乙烯一乙烯共聚物
VC/E/MA Vinylchloride ethylene maleic acid co
C/E/VAC
VC/MA Vinylchloride maleic acid copolymer
氯乙烯一乙烯一乙酸乙烯酯共聚物
氯乙烯一马来酸共聚物
VC/OA Vinylchloride octylacrylate copolymer 氯乙烯一丙烯酸辛酯共聚物
VC/P Vinylchloride propylene copolymer 氯乙烯一丙烯共聚物
VC/VAC Vinylchloride vinylacetate copolymer 氯乙烯一乙酸乙烯酯共聚物
VC/VDC Vinylchloride vinylidene chloride copolymer 氯乙烯一偏氯乙烯共聚物
VE Vinyl ester resing 乙烯基酯树脂
VLDPE very low density polyethylene 極低密度聚乙烯
英缩写 英全名 中文名
PE Polyethylene 聚乙烯
PETP (see PET)
PI Polyimide 聚酰亚胺
PO Polyolefine 聚烯烃
SI Silicone 聚硅氧烷
C/E/VAC
氯乙烯一乙烯一乙酸乙烯酯共聚物
氯乙烯一马来酸共聚物
danielldf (威望:0)
