ASQ CQT BOK
Page 1 of 8
BODY OF KNOWLEDGE
CERTIFIED QUALITY TECHNICIAN
The topics in this Body of Knowledge include additional detail in the form of subtext explanations and the
cognitive level at which the questions will be written. This information will provide useful guidance for
both the Exam Development Committee and the candidate preparing to take the exam. The subtext is not
intended to limit the subject matter or be all-inclusive of what might be covered in an exam. It is meant to
clarify the type of content to be included in the exam. The descriptor in parentheses at the end of each entry
refers to the maximum cognitive level at which the topic will be tested. A complete description of cognitive
levels is provided at the end of this document.
I. QUALITY CONCEPTS AND TOOLS
A. Quality Concepts
their satisfaction levels; define internal and external suppliers and key elements of
relations with them. (Comprehension)
freedom from defects, etc.) and processes (such as monitoring, measuring, continuous
improvement, etc.). (Co mprehension)
(Comprehension)
(Comprehension)
NOTE: Specific distinctions between prevention, appraisal, internal and external
failure costs will not be covered.
processes used, etc. (Knowledge)
including the PDCA cycle, lean manufacturing, brainstorming, benchmarking, etc., to
solve various quality problems. (Application)
B. Quality Tools
Select, construct, apply, and interpret the seven quality tools: cause and effect diagrams,
flow charts (process maps), check sheets, Pareto diagrams, scatter diagrams, control charts,
and histograms. (Synthesis)
Page 2 of 8
C. Team Functions
and following an agenda, recording and distributing minutes, establishing ground
rules and protocols, etc. (Application)
including the importance of diversity and team member participation, how to use
creative-thinking tools like brainstorming, and use various tools to achieve consensus,
etc. (Application)
performing. (Application)
developing and participating on virtual teams, using electronic communications to
support distant collaboration, etc. (Comprehension)
II. STATISTICAL TECHNIQUES
A. General Concepts
parameter, statistic, statistical process control, statistical quality control, etc.
(Comprehension)
(Application)
randomization, etc. (Knowledge)
(MTBF), and mean time between maintenance actions (MTBMA), and recognize
failure models such as bathtub curve, prediction, growth, etc. (Knowledge)
B. Calculations
Page 3 of 8
area under the normal curve. (Application)
C. Control Charts
explain their construction and use. (Application)
(Comprehension)
(Analysis)
(Analysis)
capability ratio (CR) in various situations. (Analysis)
process capability. (Application)
(Application)
determining statistical control to distinguish between common cause and special
cause variation. (Analysis)
instead of numerically. (Comprehension)
Page 4 of 8
III. METROLOGY AND CALIBRATION
A. Measurement and Test Equipment (M&TE)
Describe, select, and use the following types of tools, and evaluate their measurement
results to determine conformance to specifications. (Evaluation)
standards. (Application)
NOTE: The components of gage R&R are covered in area IV.B.3.
(Application)
on processes and products. (Comprehension)
equipment. (Application)
IV. INSPECTION AND TEST
A. Blueprint Reading and Interpretation
BODY OF KNOWLEDGE
A. Quality Concepts
- Customers and suppliers
- Quality principles for products and processes
- Quality standards, requirements, and specifications
(Comprehension)
- Cost of quality (COQ)
(Comprehension)
- Six sigma
- Continuous improvement techniques
B. Quality Tools
Page 2 of 8
C. Team Functions
- Meeting management
- Team development
etc. (Application)
- Team stages
- Globalization
A. General Concepts
- Terminology
(Comprehension)
- Frequency distributions
(Application)
- Design of experiments (DOE)
- Reliability
B. Calculations
- Measures of central tendency
- Measures of dispersion
- Statistical inference
Page 3 of 8
- Confidence limits
- Probability
- Student’s t
- Analysis of variance (ANOVA)
C. Control Charts
- Techniques and applications
- Control limits vs. specification limits
(Comprehension)
- Variables charts
(Analysis)
- Attributes charts
(Analysis)
- Rational subgroups
- Process capability measures
- Machine capability measures
- PRE-control chart
(Application)
- Common and special cause variation
- Data plotting
Page 4 of 8
- Hand tools (e.g., calipers, micrometers, linear scales)
- Gages (e.g., pins, thread, custom gages)
- Optical tools (e.g., comparators, profiles, microscopes)
- Coordinate measuring machines (CMM)
- Electronic measuring equipment (e.g., digital displays, output)
- Weights, balances, and scales
- Hardness testing equipment (e.g., Brinell, Rockwell)
- Surface plate methods and equipment
- Surface analyzers (e.g., optical flats, roughness testers)
- Force measurement tools (e.g., torque wrenches, tensiometers)
- Angle measurement tools (e.g., protractors, sine bars, angle blocks)
- Color measurement tools (e.g., spectrophotometer, color guides, light boxes)
- Gage maintenance, handling, and storage
- Measurement and test equipment (M&TE) identification and inventory
- Gage repeatability and reproducibility (R&R) studies
- Calibration intervals
(Application)
- Calibration error
- Customer-supplied M&TE
- Blueprint symbols and components
5 个回复
xieyuexiu (威望:0) (广东 深圳)
