IBM客户稽查资料与大家共享
Ÿ Is a list of all such products maintained?
2 Are deviations to the approved list approved by the PQE?
Ÿ A requirement for periodic EC audits?
Ÿ How are process, tooling or material modifications required by the EC
documented?
Ÿ Is all tooling, fixtures and gauges traceable to the EC level?
Ÿ Is EC level control included?
Ÿ List of organizations that must approve?
Ÿ IBM controlled design change records (EC, offspecs, REA/ROS)?
Ÿ Supplier controlled design changes?
Ÿ Material changes?
Ÿ Test/inspection changes?
Ÿ Packaging?
Ÿ Supplier design driven changes?
Ÿ Process flow change?
Ÿ Tooling (methods and equipment)?
Ÿ Site location?
B. Change Control:
Ÿ Key improvement activities with progress checkpoints and expected
improvement levels for each ?
Ÿ SPQL levels for key metrics for the next 12 months by family and/or
part number)?
Key performance metrics are reviewed at executive level? (typically include: quality,
customer satisfaction, continuous improvement, audit, etc.)
Management methodology & review
A. Overall Management System
Review Area N/A No Yes
Vendor “ Health Check” Review Checklist
PDF 文件以 "FinePrint pdfFactory Pro" 试用版创建 http://www.pdffactory.com
Ÿ Where Cp/Cpk statistics are used, are methods for periodically
confirming Cp/Cpk values defined?
a. Has a plan for sorting the defective product been completed and
reviewed by IBM?
Ÿ When a defect is produced from a single cavity, are all products from
the tooling rejected?
Ÿ Where parts are produced from multicavity tooling, are per cavity
audits conducted?
Ÿ Is receiving inspection documentation maintained by commodity?
Ÿ Are these parameters jointly defined by IBM and the supplier?
Ÿ Is the method for detecting and flagging product that contain
“ unusual” characteristics defined?
Ÿ Is the method for recording data defined
Ÿ Is the measurement methodology defined (SPC, AQL, frequency,
sample size, etc.)?
Ÿ Are these parameters tracked and measured?
a. Are reworked products clearly identified as such?
Ÿ Rework process?
Ÿ ETN process?
a. Are all tests that the returns are subject to included in the
document
Ÿ Failure analysis process?
appropriate references to other documents controlling the process?
D. Process Definition/Control and Qualification
Ÿ Equipment and tooling lead times?
Ÿ Recovery records?
Ÿ For end product and in-process packaging not provided by IBM, is
there a process lot testing to ensure adequacy against damage, ESD,
dropping, humidity, etc.?
- Are all independent lab requirements met where applicable (UL, ISO, etc.)
- Is the system used to order parts and control inventory within lead-times
- Is there a list of approved sources for parts and services
documented?
- Is the EC process documented with:
Ÿ Material changes?
- Is the product change process used to document changes in the following, and
Ÿ Packaging?
Ÿ Site location?
- Is the process change process used to document changes in the following:
- Are all product, process or engineering changes approved by IBM prior to
B. Change Control:
- Is a chart (histogram) provided to IBM monthly that includes quality problem
- Is the data collection methodology addressed that includes which data and the
part number)?
- Does the supplier have a documented quality improvement plan which addresses:
- Are process capability (e.g. Cp/Cpk) statistics established for critical process
reviewed by IBM?
audits conducted?
sample size, etc.)?
- Are critical process parameters defined for each inspection, test and operation
Ÿ Rework process?
Ÿ ETN process?
document
- Are specific flowcharts/process documents available describing the:
- Is a “ flowchart” documented describing the entire process from receipt of
Ÿ Recovery records?
- Is there a documented disaster recovery plan addressing:
- Does all product packaging meet IBM requirements, or where deviated from,
- Is the process used to identify units associated with a given lot documented in
- Is a list of products requiring date coding maintained with a description of
- Does the product label contain all items required by IBM
3 个回复
peilin (威望:0)
