机械设计名词术语中英文对照表(待续)
机械设计名词术语中英文对照表
阿基米德蜗杆 Archimedes worm
安全系数 safety factor; factor of safety
安全载荷 safe load
凹面、凹度 concavity
安全载荷 safe load
凹面、凹度 concavity
扳手 wrench
板簧 flat leaf spring
半圆键 woodruff key
变形 deformation
摆杆 oscillating bar
摆动从动件 oscillating follower
摆动从动件凸轮机构 cam with oscillating follower
摆动导杆机构 oscillating guide-bar mechanism
摆线齿轮 cycloidal gear
摆线齿形 cycloidal tooth profile
摆线运动规律 cycloidal motion
摆线针轮 cycloidal-pin wheel
包角 angle of contact
保持架 cage
背对背安装 back-to-back arrangement
背锥 back cone ; normal cone
背锥角 back angle
背锥距 back cone distance
比例尺 scale
比热容 specific heat capacity
闭式链 closed kinematic chain
闭链机构 closed chain mechanism
臂部 arm
变频器 frequency converters
变频调速 frequency control of motor speed
变速 speed change
变速齿轮 change gear change wheel
变位齿轮 modified gear
变位系数 modification coefficient
标准齿轮 standard gear
标准直齿轮 standard spur gear
表面质量系数 superficial mass factor
表面传热系数 surface coefficient of heat transfer
表面粗糙度 surface roughness
并联式组合 combination in parallel
并联机构 parallel mechanism
并联组合机构 parallel combined mechanism
并行工程 concurrent engineering
并行设计 concurred design, CD
不平衡相位 phase angle of unbalance
不平衡 imbalance (or unbalance)
不平衡量 amount of unbalance
不完全齿轮机构 intermittent gearing
波发生器 wave generator
波数 number of waves
补偿 compensation
参数化设计 parameterization design, PD
残余应力 residual stress
操纵及控制装置 operation control device
槽轮 Geneva wheel
槽轮机构 Geneva mechanism ; Maltese cross
槽数 Geneva numerate
槽凸轮 groove cam
侧隙 backlash
差动轮系 differential gear train
差动螺旋机构 differential screw mechanism
差速器 differential
常用机构 conventional mechanism; mechanism in common use
车床 lathe
承载量系数 bearing capacity factor
承载能力 bearing capacity
成对安装 paired mounting
尺寸系列 dimension series
齿槽 tooth space
齿槽宽 spacewidth
齿侧间隙 backlash
齿顶高 addendum
齿顶圆 addendum circle
齿根高 dedendum
齿根圆 dedendum circle
齿厚 tooth thickness
齿距 circular pitch
齿宽 face width
齿廓 tooth profile
齿廓曲线 tooth curve
齿轮 gear
齿轮变速箱 speed-changing gear boxes
齿轮齿条机构 pinion and rack
齿轮插刀 pinion cutter; pinion-shaped shaper cutter
齿轮滚刀 hob ,hobbing cutter
齿轮机构 gear
齿轮轮坯 blank
齿轮传动系 pinion unit
齿轮联轴器 gear coupling
齿条传动 rack gear
齿数 tooth number
齿数比 gear ratio
齿条 rack
齿条插刀 rack cutter; rack-shaped shaper cutter
齿形链、无声链 silent chain
齿形系数 form factor
齿式棘轮机构 tooth ratchet mechanism
插齿机 gear shaper
重合点 coincident points
重合度 contact ratio
冲床 punch
传动比 transmission ratio, speed ratio
传动装置 gearing; transmission gear
传动系统 driven system
传动角 transmission angle
传动轴 transmission shaft
串联式组合 combination in series
串联式组合机构 series combined mechanism
串级调速 cascade speed control
创新 innovation creation
创新设计 creation design
垂直载荷、法向载荷 normal load
唇形橡胶密封 lip rubber seal
磁流体轴承 magnetic fluid bearing
从动带轮 driven pulley
从动件 driven link, follower
从动件平底宽度 width of flat-face
从动件停歇 follower dwell
从动件运动规律 follower motion
从动轮 driven gear
粗线 bold line
粗牙螺纹 coarse thread
大齿轮 gear wheel
打包机 packer
打滑 slipping
带传动 belt driving
带轮 belt pulley
带式制动器 band brake
单列轴承 single row bearing
单向推力轴承 single-direction thrust bearing
单万向联轴节 single universal joint
单位矢量 unit vector
当量齿轮 equivalent spur gear; virtual gear
当量齿数 equivalent teeth number; virtual number of teeth
当量摩擦系数 equivalent coefficient of friction
当量载荷 equivalent load
刀具 cutter
导数 derivative
倒角 chamfer
导热性 conduction of heat
导程 lead
导程角 lead angle
等加等减速运动规律 parabolic motion; constant acceleration and deceleration motion
等速运动规律 uniform motion; constant velocity motion
等径凸轮 conjugate yoke radial cam
等宽凸轮 constant-breadth cam
等效构件 equivalent link
等效力 equivalent force
等效力矩 equivalent moment of force
等效量 equivalent
等效质量 equivalent mass
等效转动惯量 equivalent moment of inertia
等效动力学模型 dynamically equivalent model
底座 chassis
低副 lower pair
点划线 chain dotted line
(疲劳)点蚀 pitting
垫圈 gasket
垫片密封 gasket seal
碟形弹簧 belleville spring
顶隙 bottom clearance
定轴轮系 ordinary gear train; gear train with fixed axes
动力学 dynamics
动密封 kinematical seal
动能 dynamic energy
动力粘度 dynamic viscosity
动力润滑 dynamic lubrication
动平衡 dynamic balance
动平衡机 dynamic balancing machine
动态特性 dynamic characteristics
安全载荷 safe load
凹面、凹度 concavity
安全载荷 safe load
凹面、凹度 concavity
扳手 wrench
板簧 flat leaf spring
半圆键 woodruff key
变形 deformation
摆杆 oscillating bar
摆线齿轮 cycloidal gear
包角 angle of contact
保持架 cage
背锥角 back angle
比例尺 scale
臂部 arm
变速 speed change
变位齿轮 modified gear
标准齿轮 standard gear
波发生器 wave generator
波数 number of waves
补偿 compensation
槽轮 Geneva wheel
槽数 Geneva numerate
槽凸轮 groove cam
侧隙 backlash
差速器 differential
车床 lathe
齿槽 tooth space
齿槽宽 spacewidth
齿侧间隙 backlash
齿顶高 addendum
齿顶圆 addendum circle
齿根高 dedendum
齿根圆 dedendum circle
齿厚 tooth thickness
齿距 circular pitch
齿宽 face width
齿廓 tooth profile
齿廓曲线 tooth curve
齿轮 gear
齿轮机构 gear
齿轮轮坯 blank
齿轮传动系 pinion unit
齿轮联轴器 gear coupling
齿条传动 rack gear
齿数 tooth number
齿数比 gear ratio
齿条 rack
齿形系数 form factor
插齿机 gear shaper
重合度 contact ratio
冲床 punch
传动系统 driven system
从动带轮 driven pulley
从动轮 driven gear
粗线 bold line
粗牙螺纹 coarse thread
大齿轮 gear wheel
打包机 packer
打滑 slipping
带传动 belt driving
带轮 belt pulley
带式制动器 band brake
单位矢量 unit vector
刀具 cutter
导数 derivative
倒角 chamfer
导程 lead
导程角 lead angle
等效量 equivalent
底座 chassis
低副 lower pair
(疲劳)点蚀 pitting
垫圈 gasket
垫片密封 gasket seal
顶隙 bottom clearance
动力学 dynamics
动能 dynamic energy
动平衡 dynamic balance
4 个回复
guest01 (威望:1) (广东 东莞) 其它行业 经理 - 不管是否站在Q的职位上,我永远不会离开质量的工作...
