HELP!请求各位高手翻译!以下是电子邮件,翻译人员不知所云,技术人员不懂英语!
I would like the minimum angular clearance in my bearing to be 0.0035 radian after pressing (into 0.062" steel which yields around the OD of the bearing). Please tell me how you need this specified. It looks like I should specify an approximate 30 micrometer internal clearance. Is there a class of fit I should specify?
How does changing the clearances effect the dynamic basic dynamic load rating of the 6006 bearing?
A second question, what would be the cost of an equivalent sealed bearing?
5 个回复
xiaoxiaozhenzi (威望:0)
在6006型号轴承的动力负载水平基础上如何变更间隙对动力的影响?
第二个问题, 相等的密封轴承的费用是多少
