hellp me!
What's the meaning :unless otherwise specified all dimensions
are in millimeters. non:limited
dimensions other than the size of raw
material shall be held to +/-0.75
except as follows:
edge to hole:+/-0.35
flange to holes :+/-0.5
between holes:
in flat :+/-0.15
between flanges:+/-0.5
Morrisbj (威望:0) (北京 ) 机械制造 经理 - I wish to make more frie...
赞同来自: huayukai
No, Flange is a component to connect two pipes or pipe and pipe fittings or pipe and valves etc. They always used by couples.
There are many types of flanges. bolts connected , thread connected, welding flange, etc.
6 个回复,游客无法查看回复,更多功能请登录注册
