专业词汇(续)
十七画
储物柜 cabinet
压入配合 force-fit
压力铸造;压铸;硬模铸造 die casting
压克力;亚加力;聚甲基丙烯酸甲脂 acrylics; polymethyl methacrylate (PMMA)
压延成形法;辗压 calendering
压花 coining
压花身;滚花身 knurled shank
压花器 knurling tool
压槽器 groover
压缩 compression
压缩力 compressive force
压缩机;压气机 compressor
压缩铸造法 compression moulding
应力 stress
应力 - 应变曲线 stress-strain curve
应力分布 stress distribution
应变 strain
应变计 strain gauge
应变能 strain energy
击穿电压 breakdown voltage
挤压 extrusion
挤压成形 extrusion moulding
档位过滤器 notch filter
环氧树脂;冷凝胶 epoxy resin
瞬时电流 instantaneous current
瞬态 transient stage
瞬变电流 transient current
瞬变电压 transient voltage
矫顽力 coercive force
缩版;缩图 reduction
缝衣针 needle
缝焊接 seam welding
纵切面;剖面 section
翼形螺帽 wing nut
翼面;空气动力面 aerofoil; airfoil
翼规 wing compasses
声强度 sound intensity
联接;轴接 coupling
联轴节;联接器 coupling
联锁电路 interlock circuit
临界值;阈值 threshold
薄木皮;单板 veneer
薄皮镶合;单板镶贴 veneering
螺柱 stud
螺栓 bolt
螺纹;螺丝牙 screw thread
螺纹切削法 screw thread cutting
螺纹车削 thread cutting
螺钉;螺丝 screw
螺旋齿轮 helical gear
螺帽;螺母 nut
螺丝批;螺丝起子 screwdriver
螺丝攻 tap
螺丝钉孔接榫 slot-screwed joint
螺丝接合 screwing
螺距 pitch
螺线管;筒形线圈;电磁线圈 solenoid
镀锌 galvanizing
镀锌片 galvanized sheet
镀锡铁片 tinplate
镁 magnesium
锚式螺纹 anchor screw thread
键 key
键槽 keyway
锤光锤 planishing hammer
锻接 forge welding
锻造;锻工 forgework; forging
锻钢 forged steel
阔叶树 deciduous tree
隐线;虚线 hidden line
鲜艳的颜色 chromatic colour
黏土 clay
黏合 cohesion
黏接 gluing
黏结剂;胶合剂 adhesive
黏着 adhesion
点 dot
点阵间距;点阵间隔 lattice spacing
点焊接 spot welding
醛树脂;电玉 ureaformaldehyde (UF)
十八画
断面线 cross hatching line
断裂 fracture
断路掣 miniature circuit breaker (MCB)
柜 carcase
台夹;固定夹 bench holdfast
台阻 bench stop
台垫;垫板 bench hook
簧片 spring
简单齿轮系 simple gear train
简谐运动 simple harmonic motion
绕组 winding
虫漆;士力 shellac
覆盖层 coating
转子 rotor
转向杆 angle bar
转矩;扭矩 torque
转能器;换能器;传感器 transducer
转动能 rotational energy
转动惯量;惯性力矩 moment of inertia
转速 spindle speed
转轴 axis of rotation
转环刀 swive knife
锁固垫圈 lock washer
锁定电路 latch circuit
镍 nickel
镍银 nickel silver
锤 hammer
锤打金工 beaten metalwork
锤光 planishing
锤尖法 drawing-down
锤锻法;冲锻法;模锻法 drop forging
离心式离合器 centrifugal clutch
离合器 clutch
杂木 serayah
杂散电容 stray capacitance
杂锦锉;针锉 needle files
双刀双掷开关 double-pole-double-throw switch
双金属的 bimetallic
双圆头锤 blocking hammer
双极面结型晶体管 bipolar junction transistor
双线规;榫规 mortise gauge
双头砂轮机 double-ended grinder
双头螺栓 stud
双稳态电路 bistable circuit
双稳态多谐振动器;双稳态多谐振荡器; 双稳态复振器 bistable multivibrator
雏形;原型;首版 prototype
鸡眼圈 eyelet
鸡眼钳 eyelet setter
额定值 rating
颜色;色彩 colour
颜色笔 colour pencil
啮合 meshing
啮接 bridle joint
辘压;滚压 rolling
十九画
滤波扼流器;平流扼流圈 smoothing choke
滤波电容器;平流电容器 smoothing capacitor
滤波电路;平流电路 smoothing circuit
爆炸图;零件分散图 exploded drawing (view)
爆振燃烧 detonation
稳定 steady
稳定平衡 stable equilibrium
稳定剂 stabilizer
稳流器 current stabilizer
稳态 steady state
稳压器 voltage stabilizer
系固件;扣件 fastener
系杆 tie
绘画 painting
绘图 drawing
绘图技巧 drawing technique
绘图材料 drawing materials
绘图板;画板 drawing board
绘图格式 drawing format
绘图纸 drawing paper
绘图铅笔 drawing pencil
绘图仪器 drawing instruments
边材 sapwood
边刨;槽口刨;子口刨 rebate plane
边榫 edge joint
边缘处理 edging
链条 chain
链传动 chain drive
链轮 chain wheel
链轮齿 sprocket
镗孔 boring
錾 chisel
关锁装置 locking device
韵律;节奏 rhythm
廿画
悬臂梁 cantilever
矿物 mineral
继电器 relay
蠕变;潜变 creep
触发器;复振器;正反器 flip-flop
译码;译码 decode
钟铜 bell metal
廿一画
栏板 ripping fence
栏板锁杆 locking lever
护面罩 face shield
护眼屏 eye screen
铁 iron
铁 - 碳金相图 iron-carbon equilibrium diagram
铁板 iron plate
铁砧 anvil; creasing iron; iron plate; tinman’s anvil
铁素体 ferrite
钉 nail
铁剪 snips
铁钳;钉钳 pincers
铁撬 crowbar
铁线边 wired edge
铁矿石 iron ore
铁? rust
驱动 driving
驱动力 driving force
廿二画
弯曲力矩 bending moment
弯曲机;折床 bending machine
弯刨 spokeshave
弯铁剪 curved snips
叠榫;搭接 lap joint
铸件 casting
铸造 casting
铸模;模子 mould
铸模成形;倒模成形;模塑 moulding
铸钢;生钢 cast steel
铸铁;生铁 cast iron
廿三画
纤维 fibre
纤维板 fibre board
纤维素醋酸酯 cellulose acetate (CA)
变形;扭曲 distortion
变速系统 speed control system
变压器;火牛 transformer
逻辑状态 logic state
逻辑门 logic gate
髓线 medullary ray
体积 volume
鹬嘴钳 snipe nose pliers
廿四画
灵敏度 sensitivity
廿五画
镶边 lipping
廿六画
钻 drill
钻孔;钻削 drill; drilling
钻床 drilling machine
钻嘴 bit
钻头夹盘 drill chuck
钻头扳手 drill chuck key
凿 chisel
凿切 chiselling
凿身 chisel blade
其它
G 字夹 G clamp
G 码 G code
M 码 M code
PN 结 PN junction
PVC 胶;聚氯乙烯 polyvinyl chloride (PVC)
T 尺;丁字尺 tee square
T 字叉榫 tee bridle joint
T 角榫 tee angle joint
T 型接合 tee joint
V 字板 V-board
V 形坑带和滑轮 vee belt and pulley
V 形枕 V block
V 型槽座与钳 vee block & clamp
储物柜 cabinet
压入配合 force-fit
压花 coining
压花器 knurling tool
压槽器 groover
压缩 compression
压缩机;压气机 compressor
应力 stress
应变 strain
应变计 strain gauge
应变能 strain energy
挤压 extrusion
档位过滤器 notch filter
瞬态 transient stage
矫顽力 coercive force
缩版;缩图 reduction
缝衣针 needle
缝焊接 seam welding
纵切面;剖面 section
翼形螺帽 wing nut
翼规 wing compasses
声强度 sound intensity
联接;轴接 coupling
联轴节;联接器 coupling
临界值;阈值 threshold
薄木皮;单板 veneer
薄皮镶合;单板镶贴 veneering
螺柱 stud
螺栓 bolt
螺纹;螺丝牙 screw thread
螺纹车削 thread cutting
螺钉;螺丝 screw
螺旋齿轮 helical gear
螺帽;螺母 nut
螺丝攻 tap
螺丝接合 screwing
螺距 pitch
镀锌 galvanizing
镀锡铁片 tinplate
镁 magnesium
键 key
键槽 keyway
锻接 forge welding
锻钢 forged steel
阔叶树 deciduous tree
隐线;虚线 hidden line
黏土 clay
黏合 cohesion
黏接 gluing
黏结剂;胶合剂 adhesive
黏着 adhesion
点 dot
点焊接 spot welding
十八画
断裂 fracture
柜 carcase
台阻 bench stop
台垫;垫板 bench hook
簧片 spring
绕组 winding
虫漆;士力 shellac
覆盖层 coating
转子 rotor
转向杆 angle bar
转矩;扭矩 torque
转速 spindle speed
转轴 axis of rotation
转环刀 swive knife
锁固垫圈 lock washer
锁定电路 latch circuit
镍 nickel
镍银 nickel silver
锤 hammer
锤光 planishing
锤尖法 drawing-down
离合器 clutch
杂木 serayah
杂锦锉;针锉 needle files
双金属的 bimetallic
双头螺栓 stud
雏形;原型;首版 prototype
鸡眼圈 eyelet
鸡眼钳 eyelet setter
额定值 rating
颜色;色彩 colour
颜色笔 colour pencil
啮合 meshing
啮接 bridle joint
辘压;滚压 rolling
十九画
爆振燃烧 detonation
稳定 steady
稳定剂 stabilizer
稳态 steady state
系固件;扣件 fastener
系杆 tie
绘画 painting
绘图 drawing
绘图格式 drawing format
绘图纸 drawing paper
绘图铅笔 drawing pencil
边材 sapwood
边榫 edge joint
边缘处理 edging
链条 chain
链传动 chain drive
链轮 chain wheel
链轮齿 sprocket
镗孔 boring
錾 chisel
关锁装置 locking device
韵律;节奏 rhythm
廿画
悬臂梁 cantilever
矿物 mineral
继电器 relay
蠕变;潜变 creep
译码;译码 decode
钟铜 bell metal
廿一画
栏板 ripping fence
栏板锁杆 locking lever
护面罩 face shield
护眼屏 eye screen
铁 iron
铁板 iron plate
铁素体 ferrite
钉 nail
铁剪 snips
铁钳;钉钳 pincers
铁撬 crowbar
铁线边 wired edge
铁矿石 iron ore
铁? rust
驱动 driving
驱动力 driving force
廿二画
弯曲力矩 bending moment
弯刨 spokeshave
弯铁剪 curved snips
叠榫;搭接 lap joint
铸件 casting
铸造 casting
铸模;模子 mould
铸钢;生钢 cast steel
铸铁;生铁 cast iron
廿三画
纤维 fibre
纤维板 fibre board
变形;扭曲 distortion
变压器;火牛 transformer
逻辑状态 logic state
逻辑门 logic gate
髓线 medullary ray
体积 volume
廿四画
灵敏度 sensitivity
廿五画
镶边 lipping
廿六画
钻 drill
钻床 drilling machine
钻嘴 bit
钻头夹盘 drill chuck
凿 chisel
凿切 chiselling
凿身 chisel blade
其它
G 字夹 G clamp
G 码 G code
M 码 M code
PN 结 PN junction
T 尺;丁字尺 tee square
T 型接合 tee joint
V 字板 V-board
V 形枕 V block
guest01 (威望:1) (广东 东莞) 其它行业 经理 - 不管是否站在Q的职位上,我永远不会离开质量的工作...
