常見電子術語 中英文
常見電子術語
1 Phase Alteration Line(European format) PAL
2 National TV System Committee(US format) NTSC
3 Generic Array Logic GAL
4 Programable Logic Device PLD
5 Synchronous DRAM SDRAM
6 Dynamic Radom Access Memory DRAM
7 Static Radom Access Memory SRAM
8 Erasable Programmable ROM EPROM
9 Electrically Erasable Programmable ROM EEPROM
10 Local Area Network LAN
11 Wireless Local Area network WLAN
12 Common Core of Data CCD
13 Analog - Digtal Convertor ADC
14 Digtal-Analog Convertor DAC
15 Oscillator OSC
16 Pin Grid Array package PGA
17 Ceramic Pin Grid Array package CPGA
18 Leadless plastic chip carrier LPCC
19 Leadless chip carrier LCC
20 Quad Flat Pack QFP
21 Thin Quad Flat Pack TQFP
22 Low Quad Flat Pack LQFP
23 Optical Thin Quad Flat Pack OTQFP
24 Transmission Control Protocol TCP
25 Ball grid array BGA
26 Fine-Bitch Ball Grid Array FBGA
27 Thin Fine-Bitch Ball Grid Array TFBGA
28 Very Thin Fine-Bitch Ball Grid Array VFBGA
29 Plastic Ball Grid Array PBGA
30 Low Profile Fine Pitch Ball Grid Array LFBGA
31 ChipArray Ball Grid Array CABGA
32 Shrink Small Outline Plastic Packages SSOP
33 Small Outline Plastic Packages SOP
34 Thin Small Outline Package TSOP
35 Thin Shrink Small Outline Plastic Packages TSSOP
36 Quarter Size Outline Package QSOP
37 Very-small Outline Package μSOP
38 Micro-small Outline Package MSOP
39 Laqnd Grid Array LGA
40 Small Outline Ics SOIC
41 Small Outline SO
42 Small Outline Transistor SOT
43 Low Quad flat no-lead LQFN
44 Quad flat no-lead QFN
45 Micro Lead Frame Plastic MLFP
46 Micro Lead Frame MLF
47 Small Outline Diode Pakcage SOD
48 ADHESIVE ADH 膠
49 Alternating Current AC 交流電
50 AMERICAN WIRE GUIDE AWG 美國線材標準
51 Application Specific Integrated Circuit ASIC 特定用途集成电路
52 ASSEMBLY ASSY 組裝
53 BATTERIES BATT 電池
54 BELLEVILLE BELLEVILLE 盤形(賤)
55 BILL OF MATERIAL BOM 材料清單
56 BUFFER LAYER BL 緩沖器
57 CAPACITOR & CAP/ RES NETWORK RCN CPN 電阻/電容網路
58 CAPACITORS CAPS 電容
59 CAPACITY CAP 電容,容量
60 CERAMIC CER 陶瓷
61 COMPACT DISC-READ ONLY MEMORY CD-ROM 光盤驅動器
62 CONNECTORS ADAPTERS HOUSING CONNECTOR KITS CON ADP HSG KIT 連接器, 轉接器, 外罩,連接器套件
63 CONNNECTOR CONN/CONCT 連接器
64 DATABASE DBASE DATABASE
65 DELAY LINE DLINE 時間遲延線
66 DIAGRAM DIAG 圖表
67 DIE SORTING DS 挑選
68 DIODES DIO 二極體
69 DOUBLE DBL 雙倍
70 DRAWING DWG 圖面
71 EACH EA 個(單位)
72 ELECTRIC ELECTR 電的
73 ELECTRO MAGNETIC INTERFERENCE EMI 電磁干扰
74 ELECTRO-STATIC DISCHARGE ESD 靜電防護
75 ENGINEERING CHANGE NOTIFICATION ECN
76 ENGINEERING CHANGE ORDER ECO
77 ENGINEERING CHANGE REQUEST ECR
78 EXTERNAL EXT 外部的
79 EXTERNAL PROCEDURES EXTPROC 外部程序(測試程序, 裝配指令--沒有內部程序)
80 FABRICATED PC BOARDS PCBFAB 組裝好PC板
81 FANS FAN BLOWER 風扇
82 FAST SWITCHING FS 快速開關
83 FERREOUS FERRO 鐵
84 FERRITE BEADS FERRITE 鐵氧體磁珠
85 FINAL LEVEL ASSEMBLY (WORK GROUP SPECIFIC) FNLASY 最後階組裝(工作群特定),PHANTOM,PURCHASED ASSEMBLY
86 FIT FIT 適配
87 FLAT FLAT 平坦的
88 FLAT PACKAGE FP
89 FOAM FOAM 泡沫材料
90 FOAM FOR PACKAGING PKG FOAM 包裝外型(圖)
91 FUSES, CIRCUIT BREAKERS FILTERS THERMOSTATS FUSE POLS CKT BKR THERMOSTAT FILTER 保險絲,斷路器.溫度控制器, 濾波器
92 GALLON GAL 加侖
93 GILBERT GILBERT 吉伯(磁通量的單位)
94 GROUND GND 接地
95 HANDGRIP HDR 手把
96 HARDNESS HRNSS 硬度
97 Heat HT 熱
98 HEAT SINK HTSK 散熱片
99 HEX HEX 六連的
100 INSERT INSERT 插入/件
101 INSULATION INSUL 絕緣
102 INTEGRATED CIRCUIT IC 集成回路
103 INTEGRATED CIRCUITS IC 積體電路
104 INVERT INVTR 轉 化的
105 JACKS , PLUGS , POWER CORDS LOOP BACK JACK CORD 插座,插塞,電源絕緣電線
106 KILOPASCAL KPA 千伏特
107 KIT KT 元件
108 LABEL LBL 標簽
109 LABELS LBL 標籤
110 LEAKAGE LKG 泄漏
111 LED LED 發光二極體
112 LEN LN 導光柱
113 LIGHT-EMITTING EDITOR LED 發光二極管
114 LINES OF COMMUNICATION LOC 通信線路
115 LINK LK 聯接
116 LIQUID CRYSTAL DISPLAY LCD 液晶顯示器
117 LIST LST 清單,列表
118 LITERATURE LIT 印刷品
119 LOCATE LOCATE 位置
120 LOCK LCK 鎖
121 LOCKNUT LKNT 防松螺母
122 LOGIC LGC 邏輯
123 LOGO LOGO 標示
124 LUG LUG 接線片
125 MACHINE MACH 機器
126 MANUFACTURE CHANGE ORDER MCO
127 MAXIMUM MAX 最大
128 METERIAL MTL 材料
129 MFG ASSY PROCEDURE REWORK INSTRUCTIONS PCAMAP 製造裝配程序, 重工指令
130 MILLIAMPERE MA 毫安
131 MINIMUM MIN 最小
132 MODULE MDL 模組,模塊
133 MOUNT MNT 設置,安放
134 NETWORK NTWK 網絡
135 NUMBER NBR/NO. 數碼
136 ON-GOING RELIABILITY TEST ORT 可靠度測試
137 OPTOELECTRONIC OPTO 光電子晶體
138 OSCILLATORS CRYSTALS OSC XTAL 石英振盪晶體
139 PANEL PNL 面板
140 PART PER MILLION PPM 百萬分之
141 PARTS PRTS 零件
142 PC ASSEMBLY DRAWING PCADWG PC 組裝圖 (CAD)
143 PCA PURCHASED DISTRIBUTOR PARTS PCA PUR DX PCA 採購的批發商料件
144 PCA PURCHASED NON-FRANCHISED PCA PUR NF PCA 採購的非經銷權
145 PERMANENT MAGNET PM 永久磁鐵
146 PHER (DISK DRIVES) PRPHL 周邊, 硬碟
147 PHOTOLUMINESCENCE PL
148 PIN PIN 針,栓(連接)
149 PLANE HEAD PHH
150 PLASTIC PLSTC 塑膠
151 PLATED PLTD 鍍金的
152 PLUG PLUG 插頭
153 POSITION POSN 位置
154 POWER PWR 電源
155 POWER SUPPLIES CONVERTER PWRSPLY CONVRT 電源供應器, 變流器,整流器;(電視、收音機的)變頻器
156 printde cirruit board assembly PCBA 裝配后的PCB
157 PRINTED CIRCUIT BOARD PCB 印刷電路板
158 PRODUCTION MARKET,PLANT MAINTENANCE,PROJECT MANAGEMENT PM 生產市場/保養/專案管理
159 PROGRAM PROG 程序
160 PROGRAMMABLE DEVICES .(EX:PAL,GAL,PROM,MEMORY) IC 可程式化元件
161 PROGRAMMED DEVICES (EX: PAL,GAL,PROM,MEMORY) P.A.L ;EPLD; PROM; GAL; EPROM; FLASH; FPGA; PLD 已程式化元件
162 PROGRAMMED KIT ASSEMBLIES SW ASY FW ASY 程式套件組立
163 PROGRAMMED MEDIA ASSEMBLIES PMEDLA 程式媒體裝配(PHANTOM)
164 QUANTITY Q'TY/QUANT 數量
165 RADIUS RDL 半徑
166 RECORDING MEDIA MEDIA 紀錄媒介
167 RED RED 紅色
168 REDUNDANT TRANSFER SWITCH RTS 冗余式切換開關
169 REFERENCE DRAWINGS (NON PCA) REFDWG 參考圖(非PCA) (CAD)
170 RELAY RELAY 繼電器
171 REQUIRED REQD 需求
172 RESISTANCE RES 電阻
173 RESISTOR NETWORK RNW 電阻網路
174 RESISTORS RES 電阻
175 REVISION REV 版本
176 RIVET RVT 鉚釘
177 ROUND RND 圓形
178 ROW ROW 排
179 SCHEMATICS SCHEM 電子方塊原理圖
180 SCREEN SCRN 銀幕,顯示器
181 SCREW SCRW 螺絲
182 SCREWS SER 螺絲
183 SEIZURE SEIZURE
184 SEMI-MANUFACTURED GOODS SEMS 半成品
185 SER SER 重量單位
186 SERIES SERIES 系列
187 SHIELD SHLD 防護物
188 SHRINK SHRNK 收縮
189 SHRINK TUBING HSTUBE 熱縮套管
190 SILICONE SLCN 矽樹脂
191 SILKSCREEN SSCRN 絲印
192 SLACKEN SLCN 減緩放慢
193 SOCKET SKT 插座
194 SOCKETS SKT 座
195 SOFTWARE SFTWR
196 SOFTWARE PROGRAM FOR MULTIPLE DEVICES SW JAM ; SW JTAG; SW JCF 多設備的軟體程式
197 SOFTWARE PROGRAMS SWPROG 軟體程式
198 SOLDER SLDR 焊接,焊錫
199 SPACER SPCR 襯套,襯墊
200 SPECIFICATION SPEC 規格(架構文件, 供應商提供的文件)
201 SPECIFICATION SPEC 規格
202 SPRING SPR 彈簧
203 SQ(SQUARE) SQ 平方
204 STAINLES STEEL SST 不鏽鋼
205 STANDARD STD 標準
206 STANDOFFS INSULATORS STDF SPCR 絕緣體
207 STEEL STL 鋼鐵
208 STEP STP 步調
209 STRAP STRAP 皮帶
210 STRIP STRP 帶
211 STYLE STYLE 類型
212 SUB CONTRACTED PCBS PCA 子合約PCB (外部製程)
213 SUPERLATTICE SL 超點陣
214 SUPPLY SPLY 供應
215 SURFACE MOUNT COMPONENT SMC 表面安裝零件
216 SURFACE MOUNT DEVICE SMD 表面安裝設備
217 SURFACE MOUNT TECHNOLOGY SMT 表面安裝技術
218 SWITCH SW 開關,轉換
219 SWITCHED VIRTUAL CIRCUIT SVC 開關,轉換
220 SWITCHES SWT 開關
221 System SYS 系統
222 TAB DRAWINGS TABFAM 平板黏著技術圖
223 TELECOMMUNICATION MODULES MOD 通訊模組
224 TERM TERM 期限
225 TERMINALS CONTACTS RECEPTACLES POST HEADER TERM CONT RECP HDR 終端器,接觸器, 插座,????
226 TEST TST 測試
227 THE UNIT OF RESISTANT OHM 歐姆(電阻單位)
228 THERMISTOR THMS 電熱調節器
229 TIE TIE 線夾,帶子
230 TIGHTEN TIGHTEN 拉緊
231 TOOTH TTH 牙
232 TOP ASSEMBLY-OEM TPASY OEM OEM 的最高組立
233 TOP LEVEL CDOC ASSY TOPCDOC 最高階客戶文件裝配(PHANTOM)
234 TRANSFORMER XFMR 變壓器
235 TRANSFORMER XFER
236 TRANSFORMER XFTR
237 TRANSFORMERS INDUCTORS TORPID XFMR TOROID INDUCT 變壓器,電感器,環形線圈
238 TRANSISTORS XTR 電晶體
239 TRUSS HEAD TRH 圓頭錐形(偏傘頭)螺絲
240 TUBE TBG 套管
241 TURN TURN 轉動
242 Underwriters' Laboratories UL (美國)保險商研究所,安規
243 UNINTERRUPTABLE POWER SUPPLY UPS 不間斷電源
244 UNIVERSAL STATUS MONITOR USM
245 UNIVERSAL SERIAL BUS USB 通用串行總線接口
246 UNTHREAD UNTHD 無螺紋
247 Voltage Alternating Current VAC 交流電壓
248 VOLTAGE DIRECT CURRENT VDC 直流電壓
249 VOLTAGE DIRECT SERVO VSF 伺服電壓
250 WASHER WSHR 緩沖墊/器
251 WASHERS NUTS WSHR NUT 華司,螺母
252 WELDMENT WLDMNT 焊件
253 WHITE WHT 白色
254 WIRE LUGS LUG 電線架
255 WIRE, CABLE WIRE CBL 電線,電纜
256 WIRE/NYLON W/NYL 線材/尼龍料
257 WOOD FOR PACKAGING PKG WOOD 包裝木(圖)
258 WRAPPER WRAPPER 包裝紙
259 PRODUCT PART QUALITY PROVED PPAP
260 ADVANCE PLAN FOR QUALITY PLAN APQP
261 FAILURE MODE EFFECT ANALYSIS FMEA
262 FINITE ELEMENT ANALYSIS FEA
263 COMPUTER AIDED DESIGN CAD
264 COMPUTER AIDED DRAFT CAD
265 COMPUTER AIDED ENGINEERING CAE
266 COMPUTER AIDED MANUFACTURE CAM
267 PRO ENGINEER PRO/E
268 AGILE AGILE PDM SYSTEM,COLLABORATION SYSTEM
269 PROGRESS PROGRESS MIS SYSTEM
270 ORACLE ERP ORACLE MIS SYSTEM
271 PRO/INTRALINK INTRALINK PRO/E PDM SYSTEM
272 JEWEL JEWEL 珠寶標籤
273 SINGLE-IN-LINE PACKAGE SIP 單列直插式包裝
274 DUAL-IN-LINE PACKAGE DIP 雙列直插式包裝
275 GLAZE 釉
276 SCREEN 網版印刷
277 WIRE WOUND RESISTOR 線繞電阻器
278 NETWORK RESISTOR 網路電阻器
279 CEMENT 水泥
280 CU-NI 銅鎳
281 NI-CR 鎳鉻
282 METAL FILM RESISTOR 金屬皮膜電阻器
283 CARBON COMPOSITION RESISTOR 碳素合成電阻器
284 CARBON FILM RESISTOR 碳素皮膜電阻器
285 PROPANE(C3H3) 丙烷
286 SOLID 固體
287 CHIP RESISTOR 片狀電阻器
288 JAPANESE INDUSTRIAL STANDARDS JIS 日本工業標準
289 COLOR CODE 色碼
290 ATTENUATOR 衰減器
291 WAFER 晶片
292 PATTERN 電路圖案
293 OFFSET 補償
294 OPEN LOOP GAIN 迴路放大率
295 MOLD 塑模
296 D/A CONVERTER 數位變類比轉換器
297 Transistor-Transistor Logic TTL
298 REED SWITCH 磁簧接點元件
299 SWR 駐波比
300 RINGING 振鈴
301 FLAT CABLE 扁形電纜線
302 UNDERSHOOT 下衝量
303 PULL-UP 提升
304 PULL-DOWN 拖曳
305 TABLE 表格
306 CERMET 金屬陶瓷
307 BACKLASH 齒間隙
308 SHAFT 轉軸
309 DRIVER 螺絲起子
310 ORING O形環
311 POTENTIOMETER 電位計
312 RHEOSTAT 變阻器
313 SLIDER 可變電阻的滑動觸點
314 DERATING 降低定額值
315 METALLIZED FILM 金屬化薄膜
316 CERAMIC 陶瓷
317 POLYESTER 聚乙酯薄膜
318 MYLAR 聚乙酯薄膜
319 POLYPROPYLENE 聚丙烯薄膜
320 POLYSTYRENE 聚苯乙烯薄膜
321 ETHYLENE GLYCOL 乙二醇
322 GLYCERINE 丙三醇
323 硼酸
324 氨水
325 糊狀物
326 MnO2 二氧化錳
327 NOISE LIMITER 雜訊限制器
328 MULTI-LAYER 多層
329 FILM 薄膜
330 POLYPROPYLENE PF 電容, PP電容 聚丙烯薄膜電容
331 POLYSTYRENE PS 電容, SU電容 聚苯乙烯薄膜電容
332 STYROL PF 電容, PP電容 聚丙烯薄膜電容
333 SELF HEALING ACTION 自行復原作用
334 MP CAPACITOR 金屬化紙質電容
335 GLASS 玻璃
336 RELATIVE PERMITIVITY 相對介質常數
337 FARAD F
338 DUMMY RESISTOR 假電阻
339 RIPPLE CURRENT 漣波電流
340 FLUX 清除溶劑
341 ACROSS THE LINE 電源間插入
342 HUMMING 嗡鳴
343 VARICAP 變容二極體
344 MULTIPLIER 容量倍增器
345 COUNTER 計數器
346 CLOCK 時脈
347 CARD RING 卡片環圈
348 AUTO ZERO AZ 自動規零
349 ONE-SHOT MULTIVIBRATOR 單穩態多諧振盪器
350 CONNECTOR 連接器
351 SURGE 突波
352 IMPULSE TEST 脈衝試驗
353 CHOKE COIL 扼流線圈
354 VCO 電壓控制震盪器
355 ROTARY SWITCH 旋轉式開關
356 FLEXIBLE SWITCH 引線式開關
357 GROUND PATTERN 接地印刷線
358 RAM 隨機存取記憶體
359 BACKUP BATTERY 備援電池
360 ELECTRIC DOUBLE LAYER 雙電荷層
361 SUPER CAPACITOR 超級電容器
362 GOLD CAPACITOR 金電容器
363 CELL 基本單元
364 TIMER 計時器
365 ONE-CHIP MICROCOMPUTER 單晶片微電腦
366 STANDBY 備用
367 DIGITAL TUNING SYSTEM DTS 數位調整系統
368 BASE 基座
369 CAP 蓋子
370 COLPITTS CRYSTAL 柯爾匹茲
371 HARTLEY CRYSTAL 哈特萊
372 ICXO MODULE 石英晶體震盪組件
373 OVERTONE 諧波
374 CITIZEN BAND CB 民用電台頻帶
375 SPG 可程式化石英體震盪器
376 SG 可程式化石英體震盪器
377 FLUX 助溶劑
378 DISCRETE 分立
379 PIN COMPATIBLE 插腳互換性
380 FAN-OUT 扇出數
381 ONE SHOT TIMER 單擊計時器
382 INTERFACE 介面
383 DATA 數據
384 CERAROCK 陶瓷振盪器
385 STAND SIGNAL GENERATOR SSG 標準器號產生器
386 VOLTAGE CONTROLLED OSCILLATOR VCO
387 SPURIOUS 寄生
388 ACTIVE REGION 作用區
389 INDUCTOR 電感器
390 SPIRAL COIL 螺旋形線圈
391 FERRITE BEADS 鐵氧體磁珠
392 BALUN 平衡-非平衡變換器
393 INDUCTANCE 電感
394 HYSTERESIS LOSS 磁滯損失
395 EDDY CURRENT LOSS 渦流損失
396 JOULE 焦耳熱
397 STEATITE 凍石
398 TRANSCEIVER 收發兩用機
399 SINGLE-SIDE BAND SSB
400 UHF
401 BALANCED MIXER 平衡混頻器
402 TWIST PAIR WIRE 對絞線
403 MONOLITHIC CRYSTAL FILTER 單晶石英晶體振盪器濾波器
404 AIR LINE 架空線
405 DELAY LINE 延遲線(電磁延遲線)電信號變換為超音波
406 MAGNETOSTRICTION DELAY LINE 磁伸縮延遲線
407 CHARGE COUPLED DEVICE CCD 電荷耦合裝置
408 BUCKET BRIGADE DEVICE BBD 桶裝裝置
409 STRETCHING 延伸現象
410 FIGURE OF MERIT 特性值
411 OVERSHOOT 超越量
412 UNDERSHOOT 下衝量
413 PW 脈波寬度
414 DISTRIBUTED CONSTANT CIRCUIT 分部常數電路
415 SINK 吸收(電流)
416 SOURCE 源極(電流)
417 IC MODULE IC 組件
418 MULTIPLEXER 多工器
419 PULSE TRANSFORMER 脈衝變壓器
420 FERRITE 鐵氧體
421 TOROIDAL CORE 環形鐵心
422 PULSE REPETITION FREQUENCY PRF 脈衝週期
423 HYBRID TRANSFORMER 複合式變壓器
424 COMMON MODE CHOKE 共模扼流圈
425 UNIPOLAR 單極性
426 BIPOLAR 雙極性
427 CROSS TALK 串音
428 BACK SWING 反向擺動
429 ACTIVE 有源
430 差動放大器
431 KIRCHHOFF 克希霍夫
432 ONE PIECE 單片式
433 CARD EDGE CONNECTOR 單片式連接器
434 CARD EDGE 基板邊緣
435 PLUG 插頭
436 SOCKET 插座
437 FLAT CABLE 扁形線纜
438 RIBBON CABLE 帶形線纜
439 BURN IN 測定
440 NYLON 尼龍
441 METAL CONSENT 金屬插口
442 BUS LINE 匯流排線
443 DAUGHTER BOARD 子板
444 MULTIBUS 多通道匯流排
445 VARSABUS 萬用匯流排
446 HOUSING 殼體
447 STRAIN RELIEF 應力釋放器
448 CODING KEY 編碼鍵
449 GUARD 極性導引
450 SHIELD 遮蔽罩
451 OUTER SLEEVE 外套管
452 RELAY 繼電器
453 PIN HOLE 針孔
454 BERYLLIUM COPPER 鈹銅
455 BAJONETT LOCK 彈簧鎖固
456 LUMPING 集總
457 TOGGLE SWITCH 捺跳開關
458 SLIDE SWITCH 滑動開關
459 PUSH BUTTON SWITCH 按鈕開關
460 ROTARY SWITCH 旋轉開關
461 DIP SWITCH DIP開關
462 THERMO-SENSITIVE REED SWITCH 感溫磁簧開關
463 PTC THERMISTOR 正溫度系數熱敏電阻
464 NTC THERMISTOR 負溫度系數熱敏電阻
465 RELAY 繼電器(電磁開關器)
466 REED RELAY 磁簧繼電器
467 LATCHING RELAY 閂鎖繼電器
468 RS FLIP FLOP RS触發器
469 CHATTERING 顫動
470 BOUNCE 跳動
471 TRANSISTOR-TRANSISTOR LOGIC TTL 電晶體-電晶體邏輯(電路)
472 STRIPLINE 帶狀線
473 ATTENUATOR 衰減器
474 MAKE 接通
475 THROUGH 貫穿
476 TRANSISTOR ARRAY 電晶體陣列
477 SOLID STATE RELAY SSR 固態繼電器
478 ABSORBER 吸收器
479 PHOTO COUPLER 光耦合器
480 THYRISTOR 光閘流體耦合器
481 SENSOR 感知器
482 COULOMETER 數位電量計
483 ZERO CROSS TIMING 零交叉時序
484 GAS CHROMATOGRAPHY 氣體色層法
485 INONICS 離子學
486 RING CORE 環形鐵心
487 ROBBIN 捲線軸
488 PERMALLY 高導磁合金
489 FUSE 保險絲
490 POWER TRANSFORMER PT 電源變壓器
491 TOROIDAL 螺管形
492 EI CORE EI 形
493 EE CORE EE 形
494 POT 壺形
495 DRUM 鼓形
496 CLASP 壓鐵工具
497 VANISH 絕緣凡立水
498 MICA 雲母
499 MYLAR 樹脂
500 TEFLON 鐵氟龍
501 FIN 翼片
502 BATTERY 電池
503 BATTERY TAB 電池垂片
504 BATTERY PIN 電池接腳
505 TRICKLE CHARGE 涓流充電
506 SURGE ABSORBER 突波吸收器
507 SOLENOID 螺管線圈
508 TRIAC 雙向三極管
509 ARRESTER 避雷器
510 CLAMP 箝位用
511 ZENER DIODE 齊納二極體
512 AVALANCHE DIODE 崩潰二極體
513 DIASURGE ABSORBER 抗突波吸收器
514 ARC 電弧
515 JITTER 顫動
516 CHOKE 抗流
517 THERMAL RUNAWAY 熱跑脫
518 EPOXY 環氧樹脂
519 WASHER 墊圈
520 ALUM ELETROLYTIC 鋁電解
521 POLYESTER CAPACITOR 塑膠/金屬化電容
522 Manufacturing Control Plans MCP
523 Manufacturing Input Documents MIDs
524 Gage Repeatability and Reproducibility GR&R
525 Out of BOX Audit OBA
526 End to End E2E
527 Process Flow Diagram PFD
528 Release Service Manager RSM
529 Digital Cordless Telecommunications DCT
530 Leadless leadframe package LLP
531 Design of Experiment DOE
532 Data Base Administrator DBA
533 Optical Thin Quad Flat Pack OTQFP
534 Do not populate DNP
15 Oscillator OSC
41 Small Outline SO
48 ADHESIVE ADH 膠
52 ASSEMBLY ASSY 組裝
60 CERAMIC CER 陶瓷
66 DIAGRAM DIAG 圖表
68 DIODES DIO 二極體
69 DOUBLE DBL 雙倍
70 DRAWING DWG 圖面
71 EACH EA 個(單位)
78 EXTERNAL EXT 外部的
83 FERREOUS FERRO 鐵
86 FIT FIT 適配
87 FLAT FLAT 平坦的
88 FLAT PACKAGE FP
89 FOAM FOAM 泡沫材料
92 GALLON GAL 加侖
94 GROUND GND 接地
95 HANDGRIP HDR 手把
97 Heat HT 熱
99 HEX HEX 六連的
107 KIT KT 元件
108 LABEL LBL 標簽
109 LABELS LBL 標籤
110 LEAKAGE LKG 泄漏
111 LED LED 發光二極體
112 LEN LN 導光柱
115 LINK LK 聯接
117 LIST LST 清單,列表
120 LOCK LCK 鎖
122 LOGIC LGC 邏輯
123 LOGO LOGO 標示
124 LUG LUG 接線片
125 MACHINE MACH 機器
127 MAXIMUM MAX 最大
128 METERIAL MTL 材料
131 MINIMUM MIN 最小
133 MOUNT MNT 設置,安放
134 NETWORK NTWK 網絡
139 PANEL PNL 面板
141 PARTS PRTS 零件
148 PIN PIN 針,栓(連接)
149 PLANE HEAD PHH
151 PLATED PLTD 鍍金的
152 PLUG PLUG 插頭
154 POWER PWR 電源
159 PROGRAM PROG 程序
165 RADIUS RDL 半徑
167 RED RED 紅色
170 RELAY RELAY 繼電器
175 REVISION REV 版本
176 RIVET RVT 鉚釘
177 ROUND RND 圓形
178 ROW ROW 排
181 SCREW SCRW 螺絲
182 SCREWS SER 螺絲
183 SEIZURE SEIZURE
185 SER SER 重量單位
187 SHIELD SHLD 防護物
188 SHRINK SHRNK 收縮
193 SOCKET SKT 插座
194 SOCKETS SKT 座
195 SOFTWARE SFTWR
202 SPRING SPR 彈簧
205 STANDARD STD 標準
207 STEEL STL 鋼鐵
208 STEP STP 步調
209 STRAP STRAP 皮帶
210 STRIP STRP 帶
211 STYLE STYLE 類型
214 SUPPLY SPLY 供應
218 SWITCH SW 開關,轉換
220 SWITCHES SWT 開關
221 System SYS 系統
224 TERM TERM 期限
226 TEST TST 測試
229 TIE TIE 線夾,帶子
231 TOOTH TTH 牙
240 TUBE TBG 套管
241 TURN TURN 轉動
253 WHITE WHT 白色
275 GLAZE 釉
276 SCREEN 網版印刷
279 CEMENT 水泥
280 CU-NI 銅鎳
281 NI-CR 鎳鉻
286 SOLID 固體
289 COLOR CODE 色碼
290 ATTENUATOR 衰減器
291 WAFER 晶片
292 PATTERN 電路圖案
293 OFFSET 補償
295 MOLD 塑模
299 SWR 駐波比
300 RINGING 振鈴
302 UNDERSHOOT 下衝量
303 PULL-UP 提升
304 PULL-DOWN 拖曳
305 TABLE 表格
306 CERMET 金屬陶瓷
307 BACKLASH 齒間隙
308 SHAFT 轉軸
309 DRIVER 螺絲起子
310 ORING O形環
312 RHEOSTAT 變阻器
314 DERATING 降低定額值
316 CERAMIC 陶瓷
317 POLYESTER 聚乙酯薄膜
318 MYLAR 聚乙酯薄膜
322 GLYCERINE 丙三醇
323 硼酸
324 氨水
325 糊狀物
326 MnO2 二氧化錳
328 MULTI-LAYER 多層
329 FILM 薄膜
335 GLASS 玻璃
337 FARAD F
340 FLUX 清除溶劑
342 HUMMING 嗡鳴
343 VARICAP 變容二極體
345 COUNTER 計數器
346 CLOCK 時脈
347 CARD RING 卡片環圈
350 CONNECTOR 連接器
351 SURGE 突波
353 CHOKE COIL 扼流線圈
354 VCO 電壓控制震盪器
358 RAM 隨機存取記憶體
363 CELL 基本單元
364 TIMER 計時器
366 STANDBY 備用
368 BASE 基座
369 CAP 蓋子
373 OVERTONE 諧波
375 SPG 可程式化石英體震盪器
376 SG 可程式化石英體震盪器
377 FLUX 助溶劑
378 DISCRETE 分立
380 FAN-OUT 扇出數
382 INTERFACE 介面
383 DATA 數據
384 CERAROCK 陶瓷振盪器
387 SPURIOUS 寄生
389 INDUCTOR 電感器
392 BALUN 平衡-非平衡變換器
393 INDUCTANCE 電感
396 JOULE 焦耳熱
397 STEATITE 凍石
400 UHF
404 AIR LINE 架空線
409 STRETCHING 延伸現象
411 OVERSHOOT 超越量
412 UNDERSHOOT 下衝量
413 PW 脈波寬度
415 SINK 吸收(電流)
416 SOURCE 源極(電流)
417 IC MODULE IC 組件
418 MULTIPLEXER 多工器
420 FERRITE 鐵氧體
425 UNIPOLAR 單極性
426 BIPOLAR 雙極性
427 CROSS TALK 串音
428 BACK SWING 反向擺動
429 ACTIVE 有源
430 差動放大器
431 KIRCHHOFF 克希霍夫
432 ONE PIECE 單片式
434 CARD EDGE 基板邊緣
435 PLUG 插頭
436 SOCKET 插座
437 FLAT CABLE 扁形線纜
439 BURN IN 測定
440 NYLON 尼龍
442 BUS LINE 匯流排線
444 MULTIBUS 多通道匯流排
445 VARSABUS 萬用匯流排
446 HOUSING 殼體
448 CODING KEY 編碼鍵
449 GUARD 極性導引
450 SHIELD 遮蔽罩
452 RELAY 繼電器
453 PIN HOLE 針孔
456 LUMPING 集總
469 CHATTERING 顫動
470 BOUNCE 跳動
472 STRIPLINE 帶狀線
473 ATTENUATOR 衰減器
474 MAKE 接通
475 THROUGH 貫穿
478 ABSORBER 吸收器
481 SENSOR 感知器
485 INONICS 離子學
486 RING CORE 環形鐵心
487 ROBBIN 捲線軸
488 PERMALLY 高導磁合金
489 FUSE 保險絲
491 TOROIDAL 螺管形
492 EI CORE EI 形
493 EE CORE EE 形
494 POT 壺形
495 DRUM 鼓形
496 CLASP 壓鐵工具
497 VANISH 絕緣凡立水
498 MICA 雲母
499 MYLAR 樹脂
500 TEFLON 鐵氟龍
501 FIN 翼片
502 BATTERY 電池
507 SOLENOID 螺管線圈
508 TRIAC 雙向三極管
509 ARRESTER 避雷器
510 CLAMP 箝位用
514 ARC 電弧
515 JITTER 顫動
516 CHOKE 抗流
518 EPOXY 環氧樹脂
519 WASHER 墊圈
526 End to End E2E
牛顿 (威望:0) (福建 厦门) 机械制造 工程师
沙发:D
