品质部 Special for quality department
一、品质专业词汇 Quality Professional Glossary
QC Quality Control (品质管控)
IQC Incoming Quality Control (进料品质管控)
IPQC In process Quality Control (制程品质管控)
FQC Final Quality Control (终点品质管控)
OQC Output Quality Control (最终出货品质管控)
QA Quality Assurance (质量保证)
TQC Total Quality Control (全面质量管理)
FAA First Article Assurance (首件确认)
POC Passage Quality Control (段检)
OQA Output Quality Assurance (出货质量保证)
QE Quality engineering (品质工程)
QI Quality Improvement (品质改善)
ACC Accept (允收) REE Reject (拒收) AOD Accept On Deviation (特采)
CR Critical (极严重的) MAJ Major (主要的) MIN Minor (轻微的)
AQL Acceptable Quality Level (品质允收水准)
S/S Sample size (抽样检验样本大小)
CAR Corrective Action Request (矫正措施要求)
C/R Corrective Action (矫正措施)
ECN Engineering Change Notes (工程变更通知)(供应商)
ECO Engineering Change Order (工程改动要求)(客户)
PCN Process Change Notice (工序改动通知)
PMP Product Management Plan (生产管制计划)
SIP Specification In Process (制程检验规格)
SOP Standard Operation Procedure (制造作业规范)
IS Inspection Specification (成品检验规范)
BOM Bill Of Material (物料清单)
PS Package Specification (包装规范)
SPEC Specification (规格)
CCC China Compulsory Certificate(中国强制认证)
QCC Quality Control Circle (品管圈)
QIT Quality Improvement Team (品质改善小组)
QP Quality Policy (质量方针)
QT Quality Target (质量目标)
OK OK (好,合格)
NG Not Good (不行,不合格)
Lot (批) Lot Size (批量)
Sample (样本) Sampling (抽样)
Defect (缺陷) Inspection (检验)
PDCA Plan Do Check Action (计划 执行 检查 总结)
5W1H When Where Who What Why How (何时 何地 何人 何事 为何 怎么做 )
4M1E Man Machine Material Method Environment (人 机器 物料 方法 环境)
二、产品词汇 Production Glossary
UPS Uninterruptible Power Supply (不间断电源)
EPS Emergency Power supply (应急电源)
Low Frequency Online UPS (低频在线UPS\工频在线UPS)
High Frequency Online UPS (高频在线UPS)
On-line UPS (在线UPS)
Off ine UPS (离线UPS)
Back-up UPS (后备UPS)
Line Interactive UPS (在线互动UPS)
Electric Power UPS (电力UPS)
Home UPS (家用UPS)
Inverter (逆变器)
Frequency Converter (变频器)
AC Stabilized Power Supply (交流稳压电源)
DC Power Supply (直流电源)
三、电气专用词汇 Electric Professional Glossary
Input Voltage (输入电压) Output Voltage (输出电压) Rated Voltage (额定电压)
Input Current (输入电流) Output Current (输出电流) Rated Current (额定电流)
Input Frequency (输入频率) Output Frequency (输出频率) Rated Frequency (额定功率)
Input Power (输入功率) Output Power (输出功率) Rated Power (额定功率)
Manual Bypass (手动旁路) Maintenance Bypass (维修旁路)
Transform Time (转换时间) Waveform Distortion (波形失真)
Phase (相数) Phase Sequence (相序)
Single Phase (单相) Three Phase (三相)
Efficiency (效率) Load (负载)
Temperature (温度) Humidity (湿度)
Normal (正常) Abnormal (不正常)
Waveform (波形) Sine Wave (正弦波)
Square Waveform (方波) Modified Sine Wave (修正正弦波)
MIN Minimum (最小值) MAX Maximum (最大值)
MIN Power (最小功率) MAX Power (最大功率)
Protection (保护) Fault/Failure (故障)
Reset (复位) Test (测试)
Startup (启动) Shutdown (关闭)
Alarm (报警) Silence (静音)
Overload Protection (过载保护)
Short Circuit Protection (短路保护)
Over Temperature Protection (过温保护)
Battery Low Voltage Protection (电池低压保护)
Rated Battery Voltage (额定电池电压)
Charge Voltage (充电电压)
Float Voltage (浮充电压)
Cycle Voltage (均充电压)
Charge Current (充电电流)
Isolation Resistance (绝缘电阻)
Isolation Intensity (绝缘强度)
Grounding Resistance (接地电阻)
Leakage current to ground (对地泄漏电流)
PF Power Factor (功率因数)
CF Crest Factor (峰值因数)
AVR Automatic Voltage regulate (自动稳压)
EPO Emergency Process Operation (紧急操作程序)
REC Rectifier (整流器) BYP Bypass (旁路) BAT Battery (电池)
L line (火线) N neutral (零线/中线) G Ground (地 )
SNMP Simple Network Management Protocol (简单网络管理协议)
USB Universal Serial Bus (通用串行总线架构)
SMT surface mount technology (贴片技术)
AI Auto-Insertion (自动插件)
四、产品包装箱和丝印词汇 Production Packaging-Box And Silk-Screen Glossary
Model (型号) Specification (规格)
Series (系列) Dimension (尺寸)
Quantity (数量) Capacity (容量)
Weight (重量) Shipping Weight (运输重量)
Net Weight (净重) Gross Weight (毛重)
L Length (长度) W Width (宽度)
H High (高度) D Depth (深度)
Color<英> Colour<美> (颜色)
Grey (灰色) Red (红色)
Black (黑色) White (白色)
Yellow (黄色) Silver (银色)
Blue (蓝色) Green (绿色)
S/N Serial Number (序列号)
TEL Telephone (电话)
Modem (调制解调器) FAX (传真)
Caution/Warning (警告) Notice (注意)
Port (端口) Slot (槽)
Parallel Port (并机端口)
Communication Port (通讯端口)
Intelligent Port (智能端口)
Single Mode (单机模式)
Parallel Mode (并机模式)
五、电子物料词汇 Electron Materiel Glossary
Transformer (变压器) Relay (继电器)
Transistor (晶体管) Resistance (电阻)
Capacitance (电容) Inductance (电感)
Diode (二极管) Audion (三极管)
Fuse (保险丝) Buzzer (蜂鸣器)
Socket (插座) Plug (插头)
Filter (滤波器) Fan (风扇)
Circuit Breaker (断路器)
Crystal Oscillator (晶振)
Touch Screen (触摸屏)
LCD Liquid crystal Display (液晶显示屏)
LED Light-emitting Diode (发光二极管)
MOSFET Metallic Oxide Semiconductor Field Effect Transistor(金属氧化物半导体场效应晶体管)
IGBT Isolated Gate Bipolar Transistor (绝缘双极性晶体管)
SCR Silicon Control Rectifier (可控硅)
STS Static Transform Switch (静态转换开关)
六、其他语言词汇 Other Language Glossary
中文 英文 法文 德文 西班牙文
灰色 gray gris grau gris
白色 white blanc weiß blanco
红色 red rouge rot rojo
蓝色 blue bleu blau azul
绿色 green vert grün verde
黑色 black noir Schwarz negro
橙色 orange orange orange naranja
黄色 yellow jaune gelb amarillo
0 个回复
