一般质量詞彙(Quality)
1 ABC analysis ABC 分析
2 Accelerated life test 加速壽命試驗
3 Accelerated test 加速試驗
4 Acceptability criterion 允收標準
5 Acceptable limit 允收界限
6 Acceptable process 允收製程水準
7 Acceptable quality 允收品質
8 Acceptable quality level (AQL) 允收品質水準
9 Acceptable reliability level (ARL) 允收可靠度水準
10 Acceptance 允收,驗收
11 Acceptance and rejection criteria 允收與拒收準則
12 Acceptance criteria 允收準則
13 Acceptance inspection 驗收檢驗
14 Acceptance limit 允收界限
15 Acceptance plan 驗收計畫
16 Acceptance procedure 驗收程序
17 Acceptance product 允收品
18 Acceptance sampling, attribute 計數值驗收抽樣
19 Acceptance sampling, variable 計量值驗收抽樣
20 Accepting lot 允收批
21 Accuracy 準確度
22 Acronym 縮寫
23 Action 行動,措施
24 Action, corrective 矯正行動(措施)
25 Agreement on verification method 驗(查)證方法之協議
26 Allowable percent defective (Acceptable quality level, AQL) 允收不良率(允收品質水準)
27 Allowance 允差,裕度
28 American National Standards Institute (ANSI) 美國標準協會
29 American Society for Mechanical Engineers (ASME) 美國機械工程師學會
30 American Society for Quality Control (ASQC) 美國品質管制學會
31 American Society for Testing and Materials (ASTM) 美國材料試驗學會
32 American Standard Association (ASA) 美國標準協會
33 Anti-Static Tray 防靜電盤
34 Anti-Static Tray 防靜電盤
35 Applied statistics 應用統計學
36 Appraisal cost 鑑定成本,評估成本
37 Appraisal of quality 品質評估
38 Approved Parts List 合格物料清單
39 Approved Vendor List 合格供應商名錄
40 AQL (Acceptable quality level) 允收(品質)水準
41 AQL(Acceptable Quality Level) 允收品質水準
42 Assignable cause (Special cause) 非機遇原因(特殊原因)
43 Assurance function 保證功能
44 Assurance quality 保證品質
45 Attribute classification 品性分類
46 Attribute data 計數數據
47 Attribute inspection 計數值檢驗
48 Attribute sampling 計數值抽樣
49 Attribute sampling plan 計數值抽樣計畫
50 Audit plan 稽核計畫
51 Audit report 稽核報告
52 Average outgoing quality limit (AOQL) 平均出廠水準
53 Bad lot 壞批
54 Bar chart (diagram) 條(形)圖
55 Bar Code 條碼
56 Batch (Lot) 批
57 Batch of material 材料批
58 Batch process 分批製造方法
59 Batch size 批量
60 Batch testing 批試驗
61 Bilateral 雙邊
62 BOM(Bill of Materials) 物料清單
63 BOM(Bill of Materials) 物料清單
64 Brainstorming 腦力激盪法
65 Buyer 買方; 客戶
66 C chart C(管制)圖
67 Calibration 校正
68 Capability 能力
69 Capability, machine 機器能力
70 Capability, process 製程能力
71 Capacity 能量, 容量
72 Carton 紙箱
73 Carton 紙箱
74 Category 類別
75 Cause and effect diagram 特性要因圖
76 Cause And Effect Diagram 特性要因圖
77 Cause, assignable 非機遇原因
78 Cause, avoidable 可避免原因
79 Cause, chance 機遇原因
80 Cause, common 共同原因
81 Cause, random 隨機原因
82 Cause, special 特殊原因
83 Certification 驗證
84 Certified quality engineer (CQE) 合格品質工程師
85 Certified quality technician (CQT) 合格品質技術師
86 Certified reliability engineer (CRE) 合格可靠度工程師
87 Characteristic (品質)特性
88 Characteristic curve, operating (OC curve) 操作特性曲線,OC曲線
89 Characteristic diagram 特性要因圖
90 Characteristic function 特性函數
91 Characteristic operating curve (OC curve) 特性操作曲線(OC曲線)
92 Characteristic, qualitative 質的特性
93 Characteristic, quantitative 量的特性
94 Chart 圖,(管制)圖
95 Chart, control 管制圖
96 Chart, percent defective 不良率管制圖
97 Check Sheets / Tally Charts 查檢表
98 Classification of defectives 不良品分類
99 Classification of defects 缺點分類
100 Classification of failure 失效分類, 故障分類
101 Clearance 間隙, 餘隙
102 Code 簡化, 代號
103 Code letter 代字
104 Coefficient 係數
105 Commissioning 委製
106 Commodity 商品
107 Common cause (Chance cause) 共同原因(機遇原因)
108 Company standard 公司標準
109 Company-wide quality control (CWQC) 全公司品質管制
110 Complaint 抱怨
111 Completed product verification 成品驗證
112 Concession; Waiver 特採,特認
113 Confirmation 確認
114 Conformance to the requirement 符合要求
115 Conformation 一致
116 Conforming article 合格品
117 Conformity 符合
118 Consignment 委託, 寄售
119 Consistency 一致性
120 Consumer 消費者
121 Contact, Terminal 端子
122 Continuous production 連續生產
123 Continuous sampling 連續抽樣
124 Contract 合約
125 Contract requirements 合約需求
126 Contractors 合約商
127 Control chart 管制圖
128 Control limit 管制界限
129 Control limit, lower 管制下限
130 Control limit, upper 管制上限
131 Control line 管制線
132 Control of nonconforming material 不合格物料之管制
133 Control of nonconforming product 不合格產品之管制
134 Control of production 生產管制
135 Control plan 管制計畫
136 Control point 管制點
137 Control station 管制站
138 Control, in 在管制(狀態)下
139 Control, out of 超出管制
140 Control, under 在管制(狀態)下
141 Controlled process 管制製程
142 Corrective action 矯正行動, 改正措施
143 Cosmetics, Appearance 外觀
144 Cost, appraisal 評估(鑑定)成本
145 Cost, external failure 外部失敗成本
146 Cost, internal failure 內部失敗成本
147 Cost, quality 品質成本
148 Cost, rework 重加工成本
149 Criteria for workmanship 工作技藝準則
150 Criteria of Inspection for Battery Assembly 電池組裝檢驗規範
151 Criteria of inspection for Plastic parts 塑膠件檢驗標準
152 Criterion 準則, 規範
153 Criterion, acceptance 驗收準則(規範)
154 Critical Characteristic 重要特性
155 Critical defect 嚴重缺點
156 Critical defective 嚴重不良品
157 Cumulative frequency 累積次數
158 Customer 客戶, 顧客
159 Customer complaint 顧客抱怨
160 Customer requirement 顧客要求
161 Customer satisfaction 顧客滿意度
162 D chart d管制圖
163 Data 數據
164 Data analysis 數據分析
165 Data processing 資料處理
166 Data, inspection 檢驗數據
167 Defect 疵病,缺點
168 Defect and failure analysis 缺點與失效分析
169 Defect chart 缺點數(管制)圖
170 Defect Free 零缺點
171 Defect, chronic 慢性缺點
172 Defect, critical 嚴重缺點
173 Defect, major 主要缺點
174 Defect, minor 次要缺點
175 Defect, sporadic 突發缺點
176 Defective 不良品
177 Defective, fraction 不良率
178 Defects classification 缺點分類
179 Definition(s) 定義
180 Delivering 運送
181 Delivery 交貨,出廠
182 Delivery inspection 出廠檢驗
183 Delivery quality 出廠品質
184 Delivery time 運送時間
185 Demonstration 示範,驗證,展現
186 Design change 設計變更
187 Design control 設計管制
188 Design criterion 設計準則
189 Design of experiment (DOE) 實驗計畫
190 Design planning 設計規畫
191 Design qualification 設計之合格性
192 Design release 設計發佈
193 Design review 設計審查
194 Design specification 設計規格
195 Design validation 設計確認
196 Design verification 設計驗證,查證
197 Designed experiment 實驗計畫
198 Deviation 離差
199 Deviation, standard 標準差
200 Diagram, scatter 散佈圖
201 Dimension 尺寸
202 Disassemble 拆裝
203 Discrepant material 不適宜材料
204 Document approval and issue 文件核發
205 Document changes and modifications 文件變更與修訂
206 Document control 文件管制
207 Documentation 文件化,文書處理,書面化
208 Documentation of the quality system 品質系統文件處理,文件化
209 Double specification 雙邊規格
210 Economic quality 經濟品質
211 Efficiency 效率
212 Electrical Test 電氣測試
213 Element 單件,元件
214 Engineer, quality 品質工程師
215 Engineer, quality control 品質管制工程師
216 Environment control 環境
217 Environment test 環境試驗
218 Environmental stress 環境壓力,環境應力
219 Environmental stress screening 環境應力篩選
220 Environmental test specification 環境試驗規格
221 Environmental testing 環境試驗
222 Ergonomics 人因學
223 Examination 查驗
224 Experiment, design of 實驗計畫
225 Exterior Carton 外箱
226 Fabricated material 製程材料
227 Failure analysis 故障分析,失效分析
228 Failure cause 故障原因,失效原因
229 Feedback 回饋
230 Field data 實地數據,現場數據
231 Field failure data 現場故障數據,實地失效數據
232 Field quality 現場品質
233 Final Article Inspection 終檢,成品檢驗
234 Final design review 最終設計審查
235 Final inspection 最終檢驗
236 Final product specification 成品規格
237 Final rejection 最終拒收
238 Finger Cot 指套
239 Finished goods lot rejection rate (%) 成品批退率
240 First Article 首件
241 First article(piece) Inspection 首件檢驗
242 Fishbone diagram 魚骨圖
243 Fixture 治具
244 Flexibility 彈性
245 Flow chart (diagram) 流程圖
246 Follow-up 跟催
247 Frequency 次數,頻率
248 Gage (Gauge) 量規
249 Gage inspection 量規檢驗
250 Gage, block 塊規
251 Glossary 詞彙,術語辭典
252 Go 通過
253 Go and not-go 通過及不通過
254 Gold Sample 標準樣品
255 Go-no-go 通過不通過
256 Good lot 好批
257 Green-dot-label 綠點標籤
258 Guideline(s) 指導綱要
259 Handling 搬運
260 Hand-sorting method 人工分選法
261 Histogram 直方圖
262 Histogram 歷史圖
263 Histogram 直方圖
264 Histogram, frequency 次數直方圖
265 Historical series 時間數列
266 Housing 外殼
267 Human engineering 人因工程
268 Humidity 濕度
269 Identification 鑑別
270 Identification of inspection and test status 檢驗及測試狀況識別
271 Identification of nonconforming product 不合格產品識別
272 Identification stamp 證明章,識別章
273 Identify 鑑定,鑑別
274 Improvement Plan 改善計畫
275 Incoming Inspection 進料檢驗
276 Incoming lot quality 進貨(批)品質
277 Incoming lot rejection rate (%) 進料批退率
278 Incoming material 進料
279 Incoming material control 進料管制
280 Incoming material inspection 進料檢驗
281 Initial failure 初期故障,初期失效
282 In-process inspection 製程中檢驗
283 In-Process Inspection 製程檢驗
284 Inspection 檢驗
285 Inspection and test record 檢驗與試驗記錄
286 Inspection and test status 檢驗與試驗狀況
287 Inspection and Test Status 檢驗測試狀況
288 Inspection by attribute 計數值檢驗
289 Inspection by batch 檢驗批
290 Inspection by variable 計量值檢驗
291 Inspection lot 檢驗批
292 Inspection measuring and test equipment 檢驗、量測與試驗設備
293 Inspection method 檢驗方法
294 Inspection plan 檢驗計畫
295 Inspection procedure 檢驗程序
296 Inspection record 檢驗記錄
297 Inspection specification 檢驗規格
298 Inspection station 檢驗站
299 Inspection, 100% 100%檢驗
300 Inspection, curtailed 全數檢驗,100%檢驗
301 Inspection, in line 生產線上檢驗
302 Inspection, in process 製程中檢驗
303 Inspection, manual 人工檢驗
304 Inspection, normal 正常檢驗
305 Inspection, original 原始檢驗
306 Inspection, patrol 巡迴檢驗
307 Inspection, process 製程檢驗
308 Inspection, reduced 減量檢驗
309 Inspection, sampling 抽樣檢驗
310 Inspection, tightened 加嚴檢驗
311 Inspector 檢驗員
312 Inspector, patrol 巡迴檢驗員
313 Inspector, roving 巡迴檢驗員
314 Installation 安裝
315 Interchangeability 交換性
316 Job description 工作說明書
317 Job rotation 工作輪調
318 Job shop (vs. Mass production job) 零星生產工作工場(相對於大量生產工作工場)
319 Job specification 工作規格
320 Labeling 標識
321 Labeling 標示
322 Lack of control 缺乏管制
323 Learning 燒機測試
324 Level, acceptable quality (AQL) 允收品質水準
325 Limit, average outgoing quality (AOQL) 平均出廠品質界限
326 Limit, control 管制界限
327 Limit, specification 規格界限
328 Loss of confidence 喪失信心
329 Lot (Batch) 批
330 Lot Control 批次管制
331 Lot tolerance percent defective (LTPD) 批容許不良(百分)率,拒收水準
332 Lower control limit (LCL) 管制下限
333 Machine capability 機器能力
334 Machine capacity 機器能量
335 Maintenance 維護,保養
336 Maintenance 保養,維護
337 Maintenance records 維護記錄
338 Major defect 主要缺點
339 Major defective 主要不良品
340 Malfunction 故障
341 Management representative 管理代表
342 Management responsibility 管理階層責任
343 Management review 管理階層審查
344 Management system 管理系統
345 Man-power 人力
346 Manual inspection 人工檢驗
347 Manual Soldering 手銲作業
348 Manufacturability 可製造性
349 Manufacturing control 製造管制
350 Manufacturing process 製造程序
351 Marking 標示
352 Mass production 大量生產
353 Material inventory 庫存物料
354 Material Review Board (MRB) 物料鑑審小組
355 Material Review Board(MRB) 物料鑑審小組
356 Material specification 材料規格
357 Mean life 平均壽命
358 Mean time between failures (MTBF) 平均失效間隔時間,平均故障間隔時間
359 Measurement, system 衡量(計測)系統
360 Minor defect 次要缺點
361 Minor defective 次要不良品
362 Minor failure 次要失效
363 Monitor 監督
364 Negative correlation 負相關
365 Nominal dimension 標稱尺寸
366 Nominal specification 標稱規格
367 Non-conformance 不符合
368 Non-conforming article 不符合品
369 Non-conforming product 不合格產品
370 Nonconformity 不符合
371 Nonconformity Analysis 不合格分析
372 Non-destructive inspection 非破壞性檢驗
373 Non-destructive testing (NDT) 非破壞性試驗
374 Non-replacement 不可更換
375 Number of defects 缺點數
376 Objective 目標
377 Objective value 目標值
378 One hundred percent inspection 全數檢驗,100%檢驗
379 On-Line QC (生產)線上品管
380 OOBA, Out of Box Audits 開箱檢驗
381 Operating characteristic curve 操作特性曲線,OC曲線
382 Operation 作業
383 Operations research (OR) 作業研究
384 Operator 作業員
385 Operator control 操作員管制
386 Outgoing Inspection 出貨檢驗
387 Outgoing return rate (PPM) 出貨退貨率
388 P chart P(管制)圖,不良率(管制)圖
389 P chart R(管制)圖,全距管制圖
390 Packaging 包裝
391 Packing List 包裝清單
392 Pareto analysis PARETO 分析,柏拉圖分析
393 Pareto curve PARETO 曲線,柏拉圖曲線
394 Pareto diagram PARETO圖
395 Pareto principle PARETO 原理,柏拉圖原理
396 Parts control 零件管制
397 Parts inspection 零件檢驗
398 Patrol inspection 巡迴檢驗
399 Patrol inspector 巡迴檢驗員
400 Percent defective 不良率
401 Percent defective chart 不良率(管制)圖
402 Pilot plant 試驗工場
403 Pilot production 試驗生產,先導生產
404 Pilot run 試運轉
405 Pilot Run 試產
406 Plan of acceptance 驗收計畫
407 Planning for controlled production 管制生產之計畫
408 Power of test (1-β) 檢定力
409 Preliminary Review (PR) 先期審查
410 Preventive action 預防措施(行動)
411 Preventive maintenance 預防保養,預防維護
412 Problem solving process (PSP) 問題解決
413 Procedure chart 程序圖
414 Process 製(造)程(序)
415 Process 製程
416 Process average 製程平均
417 Process average fraction defective 製程平均不良率
418 Process average quality 製程平均品質
419 Process capability 製程能力
420 Process Capability 製程能力
421 Process control 製程管制
422 Process Control 製程管制
423 Process control chart 製程管制圖
424 Process defect rate (PPM) 製程不良率
425 Process engineer 製程工程師
426 Process Flow Chart 製造流程表
427 Process Flow Chart 製造流程圖
428 Process Improvement 製程改善
429 Process inspection 製程檢驗
430 Process modification 製程之修改
431 Process quality 製程品質
432 Process variation 製程變異
433 Procurement 採購
434 Product 產品,乘積,生產
435 Product acceptance 產品驗收
436 Product assurance 產品保證
437 Product engineer 產品工程師
438 Product specification 產品規格
439 Product verification 產品驗證
440 Production control 生產管制
441 Production foreman 生產領班
442 Production line 生產線
443 Production permit 生產特許
444 Production planning 生產計畫
445 Production release 准許生產開始
446 Production supervisor 生產現場之主管
447 Productivity 生產力
448 Prototype 原型,雛形
449 Purchaser 購買者,採購者
450 Purchaser supplied product 採購者提供之產品
451 Purchasing 採購
452 QC circle 品管圈(小組)
453 Qualification 合格,認定
454 Qualification test 鑑定試驗,合格測試
455 Qualified products list 合格產品清單
456 Quality 品質
457 Quality assurance (QA) 品質保證
458 Quality audit 品質稽核
459 Quality auditor 品質稽核員
460 Quality awareness 品質意識
461 Quality characteristic 品質特性
462 Quality consciousness 品質意識
463 Quality control (QC) 品質管制
464 Quality control engineer 品質管制工程師
465 Quality control manual 品質管制手冊
466 Quality control, statistical (SQC) 統計的品質管制
467 Quality cost 品質成本
468 Quality engineer 品質工程師
469 Quality improvement 品質改進
470 Quality improvement program 品質改進計畫,品質改進方案
471 Quality Improvement Project (QIP) 品質改善專案
472 Quality level 品質水準
473 Quality loop 品質環圈
474 Quality management 品質管理,品質經營
475 Quality manager 品質經理
476 Quality manual 品質手冊
477 Quality objective 品質目標
478 Quality policy 品質政策,品質方針
479 Quality responsibility 品質責任
480 Quality responsibility and authority 品質權責
481 Quality spiral 品質螺旋,品質螺線
482 Quality surveillance 品質監察
483 Quality system audit 品質系統稽核
484 Quality system principle 品質系統原則
485 Quality system procedure and instruction 品質系統與指導事項(品質系統程序與說明)
486 Quality system requirement 品質系統要求
487 Quality system review 品質系統審查
488 Quality, acceptable 允收特性
489 Quality, average outgoing 平均出廠品質
490 Quantitative characteristic 量的特性
491 Quantity 數量
492 Range 全距
493 Raw data 原始數據
494 Raw material 原料
495 Raw material inspection 原料檢驗
496 Reading 讀數
497 Recall 收回
498 Receiving inspection 進料檢驗
499 Receiving inspection and testing 接收檢驗與測試
500 Receiving quality record 接收檢驗計畫與管制
501 Reciprocal matrix 接收品質記錄
502 Reduced inspection 減量試驗
503 Reduced testing plan 減量抽樣計畫
504 Reference standard 參考標準
505 Region of acceptance 允收區域
506 Region of doubt 可疑區域
507 Region of rejection 拒收區域
508 Reject limit 拒收界限
509 Reject lot 拒收批
510 Rejectable process level 拒收製程水準
511 Rejectable quality level (RQL) 拒收(品質)水準
512 Rejectance number (Re) 拒收數
513 Rejected product 拒收(產)品
514 Rejection 拒收
515 Reliability 可靠度,可靠性
516 Reliability analysis 可靠度分析
517 Reliability Test 信賴性試驗
518 Repair 修理
519 Replaceability 可更換性
520 Representation sample 代表樣品
521 Representative sample 代表性樣本
522 Requirement for specifications 規格的要求
523 Responsibility 責任
524 Responsibility and authority 權責
525 Resubmitted lots 覆驗批
526 Reuseable 可重複使用
527 Review and evaluation of quality management system 品質管理系統之審查與評估
528 Revision 修訂
529 Rework 重作,重加工、返工
530 Rework analysis 重加工分析
531 Roving inspection 巡迴檢驗
532 S Chart S(管制)圖,標準差(管制)圖
533 Safety 安全,安全性
534 Salt-spray test 鹽霧試驗
535 Sample 樣本
536 Sample, representative 代表樣本
537 Sampling 抽樣
538 Sampling Inspection 抽樣檢驗
539 Sampling, acceptance 驗收抽樣
540 Scale 標度,尺度
541 Scatter 散佈
542 Scatter diagram 散佈圖
543 Schedule 時程表
544 Scope 範圍
545 Scrap 廢料,廢品
546 Screening 篩選(剔)
547 Screening inspection 篩選檢驗
548 Screening process 篩選方法
549 Segregating 隔離
550 Selection of model for quality assurance 品質保證模式之選擇
551 Selection of qualified supplier 合格供應商之選擇
552 Self Inspection 自主檢查
553 Sensitivity 靈敏度
554 Sequence 序列
555 Sequence 節次(工廠作業)
556 Setup criteria 建立準則
557 Shipping 出貨
558 Shock test 衝擊試驗
559 Shop operation 現場作業
560 Single specification 單邊規格
561 Size, lot 批量
562 Size, sample 樣本大小
563 Sorting inspection 選分檢驗
564 Spare parts 備件
565 Special process 特殊製程
566 specification conflict 規格抵觸
567 specification limit 規格界限
568 specification limit, double 雙邊規格界限
569 specification limit, single 單邊規格界限
570 specification, nominal 標稱規格
571 specification, revision of 規格修訂
572 Standard of Inspection 檢驗標準,檢驗規範
573 Standard Repair Procedure (SRP) 標準維修程序
574 Statistical diagram 統計圖
575 Statistical Process Control 統計化製程管制
576 Statistical Process Control (SPC) 統計化製程管制
577 Statistical quality control (SQC) 統計(的)品質管制
578 Statistically stable 統計的穩定
579 Stocking 入庫
580 Storage 儲存
581 Stratification 層別法
582 Subcontractor 分包商
583 Supervisor 主管,監督員
584 Supplier 供應商
585 Supplier measurement control 供應商之量測系統
586 Suppliers monitoring and control 供應商監督與管制
587 Supplies 供應品
588 Surveillance 監督,追查
589 Symbol 符號
590 Symbols, glossary of 符號詞彙表
591 Technical personnel 技術人員
592 Technician 技術員
593 Technology 工藝學
594 Temporary standard 暫行標準
595 Tentative standard 試用標準
596 Term 項目
597 Terminology 術語
598 Test 檢定,試驗,測試
599 Test data 試驗數據
600 Test equipment 檢定設備,試驗裝備
601 Test method 檢定法(試驗方法)
602 Test planning 試驗規畫
603 Test procedure 試驗程序
604 Thermometer chart (Bar chart) 條圖
605 Tightened inspection 加嚴檢驗
606 Tolerance 公差,允差
607 Tolerance, bilateral 雙邊公差
608 Tolerance, unilateral 單邊公差
609 Tool 工具
610 Tooling 模具
611 Top management 高階層管理人員
612 Traceability 可追溯性
613 Traceability of material 物料追溯性
614 Transportation 搬運
615 Trend 趨勢
616 Trend chart 趨勢圖
617 Trial lot 試作批
618 Trial production 試作生產
619 Trivial many 瑣細的多數
620 Trouble shooter 追查員
621 Trouble-shooting 檢修,故障排除,問題排除
622 U chart U (管制)圖
623 Uniformity 一致性
624 Unilateral 單邊
625 Upper control limit (UCL) 管制上限
626 User instruction 使用說明書
627 Validity 有效性
628 Value analysis (VA) 價值分析
629 Value engineering (VE) 價值工程
630 Variable 變數; 計量值
631 Variable sampling plan 計量抽樣計畫
632 Variance (σ^2) 變異數; 二次動差
633 Variance, analysis of (ANOVA) 變異數分析
634 Vendee 買主
635 Vendor 供應商
636 Vendor quality rating 供應商品質分等
637 Vendor rating system 供應商分等制度
638 Vendor record card 供應商記錄卡
639 Verification 驗證
640 Verification inspection 驗證檢驗
641 Verification of purchased product 採購產品之驗證
642 Vibration test 震動試驗
643 Visual aid 目視教材
644 Visual inspection 目視檢驗
645 Vital few 重要的少數
646 Waiver 特採; 特認
647 Warranty period 保證時期; 保用期
648 Waste product 廢品
649 Wire Arranging 理線
650 Work instruction 工作說明書
651 Work Instruction, Standard Of Operation 作業指導書
652 Worker 作業員
653 Workmanship 手藝
654 Workmanship 工程技藝
655 Workmanship Standard for soldering 手銲錫作業標準
656 Workshop 工場
657 Yield 收率
658 Zero defects (ZD) 無缺點; 零缺點
659 Zone of acceptance 允收區域
660 Zone of rejection 拒收區域
6 个回复
mc99 (威望:0) (广东 江门) 机械制造 技术员 - 努力学习中
