OIF Broncho Fiberscopes
OIF Broncho Fiberscopes, with the excellent optical element,bring bright and clear and own Field of View as 110 degree for users.Upper 180 degree, Lower 130 degreebend degree to observe the Lobectomy precisly and Bronchial lesions. The unner Diameter of instrument Channel as 2.2mm.Cooperate with the biopsy clamp our company produced.Biopsy samples can be ensured.Cytology diagnosis of lung,
is applied for observation, biopsy sampling, Bacteriology, segment and sub-segment of patient’s bronchi. It can comply with photography, teaching and dynamic records while connection to TV system.
With 4mm of outer diameter of insertion tube, it has good insertion performance. With 130°Up,90°Down of angulations and 85°of view of field, it can reach the position observed fast and correctly and then detect the diseases.
With 25X magnifications, big depth of view and wide angle of view, and circle view of field, it can observe clear and vivid images within 3-50mm as well as small lesions never skipped.
With biopsy sampling device, it helps to detect early diseases and carries out surgery inside of body like getting rid of polypectomy. It is also useful precision device for researches of bronchi and lung diseases and Postoperative check.
It is with innovative plastic control body and reasonable instrumental channel inlet. With 2mm of working channel, it can comply with suction and keep smoothly movement of instrument like forceps. For surgery, it is very convenient, removable and reliable for pressing suction valve.
ABF-6 Fiber Bronchoscope is applied for observation, biopsy sampling, Bacteriology, Cytology diagnosis of lung, segment and sub-segment of patient’s bronchi. It can comply with photography, teaching and dynamic records while connection to TV system. With biopsy sampling device, it helps to detect early diseases and carries out surgery inside of body like getting rid of polypectomy. It is also useful precision device for researches of bronchi and lung diseases and Postoperative check.
OIF Broncho Fiberscopes, with the excellent optical element,bring bright and clear and own Field of View as 110 degree for users.Upper 180 degree, Lower 130 degreebend degree to observe the Lobectomy precisly and Bronchial lesions. The unner Diameter of instrument Channel as 2.2mm.Cooperate with the biopsy clamp our company produced.Biopsy samples can be ensured, Check Cytology diagnosis of lung,Acquisition sputum,
0 个回复
