[分享]工程质量词汇-2 (28Jun'04)
allocation 分配
allowable loss 许容损失
allowable voltage 许用电压
alloy 合金
alternate 代替品
alternative characteristic 代用特性
alumina 氧化铝
aluminum alloy 铝合金
ambient temperature 环境温度
ammeter 电流表
amount 数量
amphoteric metal 两性金属
anaerobic 厌氧性的
anaerobic adhesive 厌氧性胶水
analysis of variance 偏差分析
anechoic room 无音室
angular 有角的
angularity 角状
anion 阴离子
anisotropy 各向异性
anneal 退火
annealing 退火
anti corrosion test 防腐蚀试验
anti-blocking agent 防阻塞剂
anti-rust oil 防锈油
anti-rust treatment 防锈处理
antielectrostatic agent 防静电剂
appearance 外观
application 应用
applied voltage 施加电压
apply 施加
apply an electric current 加电流
approval 审批
approved drawing 已审批图纸
aqueous cleaning 水清洗
aqueous solution 水溶剂
araldite 环氧树脂粘合剂
arc 弧
area 面积
area resistance 面积抵抗
arrow mark 箭头标志
as it is 实际上,其实
as they are 实际上,其实
at a rough estimate 大概估计
at random 随机
at the beginning of shift 轮班初期
atmospheric corrosion resistance 大气腐蚀抵抗
atmospheric pressure 大气压
atmospheric pressure(head) 大气压(头)
attractive 吸引的
audible noise inspection 可听噪音检查
auditee 勘查员
available period 适用期间
axial 轴向的
axis 轴
sinskj (威望:2) (海外 ) 在校学生 工程师
关于Analysis of Variance(ANOVA):
ANOVA is a statistical analysis technique in which the total variation is divided into meaningful sources of variation.
ANOVA can be used to:
determine the statistical significance of effects
calculate the components of variance
estimate the contribution to variation by each identified source
estimate the underlying noise within the process
