[分享]工程质量词汇-1 (27Jun'04)
A-weighted sound pressure level A 声压级
abnormal noise 异常噪音
abnormal wear 异常磨损
abolition 废除
abrasion 磨损
absolute value 绝对值
absolutely 绝对地
absorbent cotton 脱脂棉
absorbing jig 吸引夹具
accelerated test 加速试验
acceleration 加速度
accelerator 促进剂,加速器
accelerometer 加速度计
acceptable quality level A Q L
acceptable quality level 合格品质水准
acceptable reliability level 合格可靠水准
acceptance 合格
accumulate 积累
accuracy 精度
acetic acid 醋酸
acetophenone 乙酰笨
acidity 酸度
acoustic noise 噪声
acrylic 丙烯酸的
activated carbon 活性炭
activator 活性剂
additive 添加剂
adhering 粘着
adhesion 粘着
adhesion coefficient 粘着系数
adhesion test 粘着试验
adhesive 胶(水)
adhesive coefficient 粘着系数
adhesive face 粘着面
adhesive fitting 粘着(配合)装配
adjustment 调节
aerobic 有氧的
aerosolling 烟雾剂
age hardening 经时硬化
aging 老化
air blow 吹气
air flow 空气流
air gun 空气枪
(air) inlet (空气)进口
air leak 空气泄漏
air outlet 出气口
alcohol 酒精
alcohol (solvent) 酒精(溶剂)
algorithm 算法
alignment 校中
alignment mark 校中标记
alkali 碱
alkaline 碱性的
abnormal noise 异常噪音
abnormal wear 异常磨损
abolition 废除
abrasion 磨损
absolute value 绝对值
absolutely 绝对地
absorbing jig 吸引夹具
acceleration 加速度
accelerator 促进剂,加速器
accelerometer 加速度计
acceptance 合格
accumulate 积累
accuracy 精度
acetic acid 醋酸
acetophenone 乙酰笨
acidity 酸度
acoustic noise 噪声
acrylic 丙烯酸的
activator 活性剂
additive 添加剂
adhering 粘着
adhesion 粘着
adhesion test 粘着试验
adhesive 胶(水)
adhesive face 粘着面
adjustment 调节
aerobic 有氧的
aerosolling 烟雾剂
age hardening 经时硬化
aging 老化
air blow 吹气
air flow 空气流
air gun 空气枪
(air) inlet (空气)进口
air leak 空气泄漏
air outlet 出气口
alcohol 酒精
algorithm 算法
alignment 校中
alignment mark 校中标记
alkali 碱
alkaline 碱性的
sinskj (威望:2) (海外 ) 在校学生 工程师
根据isigma的解释,AQL:Acceptable Quality Level. Also referred to as Assured Quality Level. The largest quantity of defectives in a certain sample size that can make the lot definitely acceptable; Customer will definitely prefer the zero defect products or services and will ultimately establish the acceptable level of quality. Competition however, will 'educate' the customer and establish the customer's values. There is only one ideal acceptable quality level - zero defects - all others are compromises based upon acceptable business, financial and safety levels.
