翻译
・"Homogeneous material "means a material that can not be mechanically disjoined into different material.
・The term"homogeneous " means "of uniform composition throughout". Example of "homogeneous materials " are
・The term "mechanically disjoined" means that the material can, in principle, be separated by mechanical actions
such as : unscrewing, cutting, grinding and abrasive processes.
example:・Sigle molded plastics which has no coating and no attachement is regards as homogeneous material
・Electric calbe consists of metal conductor and insulation material. For this case, it not regarded as one homogeneous
・ Semiconductor package is composed of many homogeneous materials such as plastic molding, leadframe ally, gold bonding wire etc.. Each homogeneous component material must be analyzed.这是客户的一个调查报告,这是什么意思呀,看不明白
4 个回复
loaferfdu (威望:0)
这里特别要小心均质材料的概念,RoHS所有的100、1000都是针对这个概念来的,他会给你的工作带来很多很多的麻烦。
等你开始痛骂这个概念的时候,你就真的理解这个概念了,呵呵
