ETSI 近期正式发布的和即将发布的EN标准
Published:
已发布的:
- EN 301 025-1 V1.3.1 (2007-02): VHF radiotelephone equipment for general communications and associated equipment for Class "D" Digital Selective Calling (DSC); Part 1: Technical characteristics and methods of measurement
- EN 301 025-1 V1.3.1 (2007-02): 电磁兼容性和无线频谱事物(ERM);一般通信用VHF无线电电话设备和D类数字选择呼叫(DSC)相关设备;第1部分:技术特性和测试方法
第1部分:技术特征和测量方法
Under one-step approval:
处于正式批准中:
Under voting
处于投票表决中:
已发布的:
- EN 301 025-2 V1.3.1 (2007-02): Part 2: Harmonized EN under article 3.2 of the R&TTE Directive
- EN 301 025-2 V1.3.1 (2007-02): 第2部分:R&TTE导则第3.2章中的协调EN标准
- EN 301 025-3 V1.3.1 (2007-02): Part 3: Harmonized EN under article 3.3 (e) of the R&TTE Directive
- EN 301 025-3 V1.3.1 (2007-02): 第3部分:R&TTE导则第3.3 (e) 章中的协调EN标准
- EN 301 929-1 V1.2.1 (2007-02): VHF transmitters and receivers as Coast Stations for GMDSS and other applications in the maritime mobile service;
- EN 301 929-1 V1.2.1 (2007-02): 在海事移动业务中的GMDSS和其它应用的海岸站VHF发射器和接收器;
第1部分:技术特征和测量方法
- EN 301 929-2 V1.2.1 (2007-02): Part 2: Harmonized EN under article 3.2 of the R&TTE Directive
- EN 301 929-2 V1.2.1 (2007-02): 第2部分:R&TTE导则第3.2章中的协调EN标准
- ETSI EN 301 178-1 V1.3.1 (2007-02): Portable Very High Frequency (VHF) radiotelephone equipment for the maritime mobile service operating in the VHF bands (for non-GMDSS applications only); Part 1: Technical characteristics and methods of measurement
- ETSI EN 301 178-1 V1.3.1 (2007-02): 用于工作在VHF频段的海事移动业务的便携式甚高频(VHF)无线电话设备(只限于non-GMDSS应用);第1部分:技术特性和测试方法
- EN 301 178-2 V1.2.2 (2007-02): Portable Very High Frequency (VHF) radiotelephone equipment for the maritime mobile service operating in the VHF bands (for non-GMDSS applications only); Part 2: Harmonized EN covering essential requirements of article 3.2 of the R&TTE Directive
- EN 301 178-2 V1.2.2 (2007-02): 用于工作在VHF频段的海事移动业务的便携式甚高频(VHF)无线电话设备(只限于non-GMDSS应用);第2部分:满足R&TTE导则第3.2章基本要求的协调EN标准
- EN 302 500-1 V1.1.1 (2007-02): Short Range Devices (SRD) using Ultra WideBand (UWB) technology; Location Tracking equipment operating in the frequency range from 6 GHz to 8,5 GHz; Part 1: Technical characteristics and test methods
- EN 302 500-1 V1.1.1 (2007-02): 使用超宽频(UWB)技术的短距离设备(SRD);运行在6 GHz到8,5 GHz频段间的位置跟踪设备;第1部分:技术特性和测试方法
- EN 302 500-2 V1.1.1 (2007-02): Short Range Devices (SRD) using Ultra WideBand (UWB) technology; Location Tracking equipment operating in the frequency range from 6 GHz to 8,5 GHz; Part 2: Harmonized EN covering essential requirements of article 3.2 of the R&TTE Directive
- EN 302 500-2 V1.1.1 (2007-02): 使用超宽频(UWB)技术的短距离设备(SRD);运行在6 GHz到8,5 GHz频段间的位置跟踪设备;第2部分:满足R&TTE导则第3.2章中基本要求的协调EN标准
处于正式批准中:
- EN 301 893 V1.4.1 (2007-02): 5 GHz high performance RLAN; Harmonized EN covering essential requirements of article 3.2 of the R&TTE Directive
- EN 301 893 V1.4.1 (2007-02): 5 GHz高性能RLAN;满足R&TTE导则第3.2章基本要求的协调EN标准
Under voting
处于投票表决中:
- EN 301 908-1 V3.2.1 (2007-02): Base Stations (BS), Repeaters and User Equipment (UE) for IMT-2000 Third-Generation cellular networks; Part 1: Harmonized EN for IMT-2000, introduction and common requirements, covering essential requirements of article 3.2 of the R&TTE Directive
- EN 301 908-1 V3.2.1 (2007-02): IMT-2000第三代蜂窝网络的基站(BS),中继器和用户设备(UE);第1部分:满足R&TTE导则第3.2章基本要求的IMT-2000, 导言和普通要求的的协调EN标准;
- EN 301 908-2 V3.2.1 (2007-02): Part 2: Harmonized EN for IMT-2000, CDMA Direct Spread (UTRA FDD) (UE) covering essential requirements of article 3.2 of the R&TTE Directive
- EN 301 908-2 V3.2.1 (2007-02): 第2部分:满足R&TTE导则第3.2章基本要求的IMT-2000, CDMA直接扩频(UTRA FDD) (用户终端)的协调标准
- EN 301 908-3 V3.2.1 (2007-02): Part 3: Harmonized EN for IMT-2000, CDMA Direct Spread (UTRA FDD) (BS) covering essential requirements of article 3.2 of the R&TTE Directive
- EN 301 908-3 V3.2.1 (2007-02): 第2部分:满足R&TTE导则第3.2章基本要求的IMT-2000, CDMA直接扩频(UTRA FDD) (基站)的协调标准
- EN 301 908-7 V3.2.1 (2007-02): Part 7: Harmonized EN for IMT-2000, CDMA TDD (UTRA TDD) (BS) covering essential requirements of article 3.2 of the R&TTE Directive
- EN 301 908-7 V3.2.1 (2007-02): 第7部分:满足R&TTE导则第3.2章基本要求的IMT-2000, CDMA时分双工(UTRA TDD) (基站)的协调标准
- EN 301 908-11 V3.2.1 (2007-02): Part 11: Harmonized EN for IMT-2000, CDMA Direct Spread (UTRA FDD) (Repeaters) covering essential requirements of article 3.2 of the R&TTE Directive
- EN 301 908-7 V3.2.1 (2007-02): 第7部分:满足R&TTE导则第3.2章基本要求的IMT-2000, CDMA时分双工(UTRA TDD) (中继器)的协调标准
0 个回复
