07年3月BSI对我公司的TS审核报告及我们的改善报告
07年3月BSI对我公司的TS审核报告及我们的改善报告,现在上传上来,供大家学习
Market
SHENZHEN JINGCHENGDA ELECTRIC CIRCUIT CO., LTD
Quality System Audit Defect Report
Date:2007-3-15 ■Quality □Environment □SS—00259 Number: A76555/3
Audit dept. Market Audit date 2007.03.15 Assesso BSI Xue Qin(Shirley)Huang
Description of Nonconformity: Customer satisfaction of 2006,was only summarized by customer satisfaction
Survey,the objective data of on-going performance indicators like PPM, 100%on-time delicery were not considered
Audit Basis ■ISO/TS16949:2002 □ISO14001:2004 □SS—00259:2005
Duty dept. Market Principal Jing Sun
Clause 8.2.1.1 Defect Property ■ MIN
□ MAJ
Cause analysis:
When we made the document of customer content instance, we didn’t put some item of ISO/ISO16949
8.2.1.1.2. come into the technology document such as customer complaint charge, abnormity delivery charge.
Department principal: Jing Sun Date: Mar-20 2007
Corrective action report:
1. According to ISO/ISO16949 technology specification 8.2.1.1 requirement to amend 《Investigate proce
dure of customer content instance》,this document will add the superfluity item as below : customer
complaint charge ,abnormity delivery charge and so on . To add the assess way of customer content
instance and to amend the add item of ISO/ISO16949 8.2.1.1 come into < investigate list of customer
content instance >;
2. Market department supervisor arrange the person of market department ,quality department to train the
Revise document /list including ( 《Investigate procedure of customer content instance》< investigate
list of customer content instance >)
3. Market department will provide the revise document of < investigate list of customer content instance >
to Tianma and according to the feedback result of customer content to correct and improve it .
Verification of effectiveness:
Auditor: Verification date:
Quality Dept.
Date: 2007-3-15 ■Product audit □ Environment □SS—00259 Number:A76555/1
Audit dept Quality Dept. Audit date 2007.03.15 Assessor BSI Lin Mei (Anne) Qiu
Description of Nonconformity: The organization’s process internal audit was not effective implemented
(1) No evidence that some items were verified according the customer drawings .such as:0.35±0.05,but the
Product Accept criteria was 0.35±20%; (2) No evidence when complaints occurred,the product audit plan
Were updated.such as:July 2006,1003D1018B was complained,but no product audit conducted
Audit Basis ■ISO/TS16949:2002 and the special request of TIANMA
Duty dept Quality Dept. Principal Songlin Hu Defeng Gao
Clause 8.2.2.3 Defect
Property ■ MIN
□ MAJ
Cause Analysis:
1.When the product was audited, the internal auditor hadn’t put the customer drawing as product data to audit it .
2.When the product was audited, the internal auditor also hadn’t put the customer drawing &technology
requirement as the audit condition to audit it .
3.When R&D department was dealing with customer data,which need to put the customer data to change into internal SOP, They forgot to audit & validate the customer data such as customer drawing .
4.When the document of 《Product check procedure》 was made by us ,we didn’t calculate the product
which was complaining by client need to be re-audited&validated, which led to the1003D01018 was
being complained by client ,we didn’t audit &validate the improve product in time.
Department principal: Defeng Gao Date: Mar-20-2007
Correct/prevent action:
1.Quality department will arrange product audit ,the purpose is that put the customer drawing、
technology requirement as a important gist when the product was audited.
2.The document of 《Product check procedure》must be revised by quality department ,the revised
document is as below:
a)To revise the data of ISO audit gist and auditing import ,which must be cover the customer drawing
& technology requirement
b)The improve product must be re-audited&validated when it was complained
3.To revise the other correlation document ,for example :SOP ,SIP, control plan ,PFMEA and so on .
4.If the product auditing found the defect which it has get to client ,we must be contact the client to correct and improve it .
Department principal:Xiping Zhang&YongxingZhang Date: Mar-20-2007
Date: 2007-3-15 ■Quality □Environment □SS—00259 Number: A76555/2
Audit dept R&D center Audit date 2007.03.16 Assessor BSI Wei (Lancer) Chu
Description of Nonconformity: Process parameter in control plan was inconsistent with ones in PFMEA.for
Product 1003D01018B,drying speed from PFMEA was 1-1.8m/min,but in control plan it was 1-1.5m/min.
Duty dept R&D Principal Xiping Zhang、Yongxin Zhang
Clause 7.3.3.2 Defect Property ■ MIN
□ MAJ
Cause analysis :
PFMEA analysis/revise→validate/confirm change →evaluate/revise control plan → evaluate/revise
produce process.
-01018 drying speed from control plan was 1-1.5m/min ,but in PFMEA it was 1.8m/min.
Correct/prevent action :
procedure》 revised.
organize the CFT member to evaluate and revise the drying speed from 1-1.8m/min to 1-1.5m/min after
R&D department and quality department approved.
change →evaluate/revise control plan → evaluate/revise produce process after PFMEA analysis and
revise won’t be done by us .
审核报告是PDF档的,没有办法传上来!!:mad: :mad:这是我们的改善报告
Market
□ MAJ
Cause analysis:
content instance >;
Quality Dept.
Property ■ MIN
□ MAJ
Cause Analysis:
- In order to avoid the problems happen again ,we will organize the person of internal auditor & engineer of
□ MAJ
Cause analysis :
- When we made the 《Engineering change manage procedure》,we didn’t according to car product process
produce process.
- Process engineer of R&D department didn’t understand the engineering change clearly ,they only calculated
- Revise the document of 《Engineering change manage procedure》to particular define the change
- Quality department will train the document of 《Engineering change manage procedure》 for person
procedure》 revised.
- Process engineer according to the new 《Engineering change manage procedure》to change process and
- The drying speed of control plan/SOP has been revised from1-1.8m/min to 1-1.5m/min by CFT team
5 个回复
gdf1223 (威望:2) (湖北 武汉) 电子制造 品质工程部经理 - 懂得做人,学会处世
