品质术语-中英文对照
品质术语-中英文对照
中英文对照
英文缩写 中文名称(英文全名)
SPC 统计制程管制Statistical Process Control
USL 规格上限Upper Specification Limit
LSL 规格下限Lower Specification Limit
UCL 管制上限Upper control limit
LCL 管制下限Lower control limit
PCL 前置管制中心限Per-control Central Limit
UPCL 前置管制上限Upper Per-control Limit
LPCL 前置管制下限Lower Per-control Limit
ANOVA 变异数分析Analysis of Variance
BSC 平衡计分卡Balanced Scoredoard
信赖区间Confidence interval
管制图Control chart
CTQ 品质关键Critical to quality
DPMO 每百万个机会的缺点数Defects per million opportunities
DPM 每百万单位的缺点数Defects per million
DPU 单位缺点数Defects per unit
DFSS 六个希格玛设计Design for six sigma
DOE 实验设计Design of experiment
制造设计Design of manufactring
FMEA 故障型态与效应分析Failure mode and effect analysis
故障率Failure rate
Gage R & R 量规重复能力与重制能力Gage repeatability & reproducibility
直方图 Histogram
假设检定Hypothesis testing
KM 知识管理Knowledge Management
MRP 物料需求规划 Material require planning
常态分配Normal distribution
QFD 品质机能展开Quality function deployment
6 σ 六个希格玛Six Sigma
σ, s 标准差Standard deviation
σ2, S2 变异数Variance
ABC 作业制成本制度Activity-Based Costing
BTF 计划生产Build To Forecast
BTO 订单生产Build To Order
CPM 要径法Critical Path Method
CPM 每一百万个使用者会有几次抱怨Complaint per Million
CRM 客户关系管理Customer Relationship Management
CRP 产能需求规划Capacity Requirements Planning
CS 顾客满意度Customer Satisfaction
CTO 客制化生产Configuration To Order
DVT 设计验证Design Verification Testing
DSS 决策支持系统Decision Support System
EC 设计变更/工程变更Engineer Change
EC 电子商务Electronic Commerce
EMC 电磁兼容Electric Magnetic Capability
EOQ 基本经济订购量Economic Order Quantity
ERP 企业资源规划Enterprise Resource Planning
FMS 弹性制造系统Flexible Manufacture System
FQC 成品品质管制Finish or Final Quality Control
IPQC 制程品质管制In-Process Quality Control
IQC 进料品质管制Incoming Quality Control
ISO 国际标准组织International Organization for Standardization
ISAR 首批样品认可Initial Sample Approval Request
JIT 实时管理Just In Time
MES 制造执行系统Manufacturing Execution System
MO 制令Manufacture Order
MPS 主生产排程Master Production Schedule
MRO 请修(购)单Maintenance Repair Operation
MRP 物料需求规划Material Requirement Planning
MRPII 制造资源计划Manufacturing Resource Planning
NFCF 更改预估量的通知Notice for Changing Forecast
OEM 委托代工Original Equipment Manufacture
ODM 委托设计与制造Original Design & Manufacture
OPT 最佳生产技术Optimized Production Technology
OQC 出货品质管制Out-going Quality Control
PDCA PDCA管理循环Plan-Do-Check-Action
PO 订单Purchase Order
QA 品质保证Quality Assurance
QC 品质管制Quality Control
QCC 品管圈Quality Control Circle
QE 品质工程Quality Engineering
RMA 退货验收Returned Material Approval
ROP 再订购点Re-Order Point
SCM 供应链管理Supply Chain Management
SFC 现场控制Shop Floor Control
SO 订单Sales Order
SOR 特殊订单需求Special Order Request
TOC 限制理论Theory of Constraints
TPM 全面生产管理Total Production Management
TQC 全面品质管制Total Quality Control
TQM 全面品质管理Total Quality Management
WIP 在制品Work In Process
中英文对照
英文缩写 中文名称(英文全名)
管制图Control chart
故障率Failure rate
直方图 Histogram
6 σ 六个希格玛Six Sigma
σ2, S2 变异数Variance
PO 订单Purchase Order
SO 订单Sales Order
15 个回复
huangweijin (威望:1) (江苏 苏州) 电子制造 课长 - 诚实,自信是做好品质工程师的前提
