这是什么意思?
A. Adhesive – V88
B. Safety/Caution/Warning Labels
1. Color and legibility of the label should last a minimum of 5 years.
2. Exterior durability is based on vertical exposure for weather ability in the extreme United States, or a 2000-hour carbon-arc test in accordance with ASTM G152, or a 2000-hour xenon-arc test in accordance with ASTM G155.
3. Reference Standards:
a. ANSI B71.1 Consumer Turf Care Equipment
b. ANSI B71.3 Snow Throwers
c. ISO 8437
d. ISO 5395.2
4. Safety/Caution/Warning Labels shall conform to the following:
a. The verbiage “WARNING” must be a minimum of 6mm high.
b. The text under “WARNING” must be a minimum of 3mm high.
请大家援手,谢谢。
benjamin_xie (威望:2) (广东 广州) 食品饮料 员工
A. Adhesive – V88
粘合剂- V88
安全/警告/紧急标识
  1. Color and legibility of the label should last a minimum of 5 years.-
有色彩并且容易辨认的标识必须至少能维持5年
室外持久性是能基于直接暴露于美国极端的天气,或者依照ASTM G152标准做一个2000小时的炭精电弧测试,或者依照ASTM G155标准做一个2000小时的氙弧测试。
  1. Reference Standards:
参照的标准
a. ANSI B71.1 Consumer Turf Care Equipment;
c. ISO 8437
d. ISO 5395.2
  1. Safety/Caution/Warning Labels shall conform to the following:
安全/警告/紧急标识应跟下面一致:
首行的“WARNING”高度不得低于6毫米
紧接正文下面的“WARNING”高度不得低于3毫米
7 个回复,游客无法查看回复,更多功能请登录注册
