Minitab R16.1.1 更新通知
Minitab 16.1.1 共改正25个问题,其中主要"协助"新功能的修正,繁体中文环境支持的修正
看一下对自己工作有影响者,请更新为16.1.1
官方说明文件抄录
1 In the Assistant output for Chi-Square %Defective Test, the Power Report displays incorrect bounds for the individual confidence intervals if a sample has 0 defects, or if the sample's defect-count equals its number of trials. Minitab fails to automatically convert the 2-sided confidence interval to a 1-sided confidence bound in these cases. (159846)
2 In the Assistant, Binomial Capability and Poisson Capability do not accept 0 as a maximum rate of defective items or defects. (161340)
3 General Regression and the Assistant's Regression are unable to fit a model if values are very small. When values are too small, General Regression fits a model of main effects but omits higher order terms; Regression in Assistant displays an error that it cannot fit a model. (161608)
4 In the Assistant's Binomial Capability output, the "Z.Bench" terminology is inconsistent with the "Process Z" terminology used in Stat > Quality Tools > Capability Analysis > Binomial. (162025)
5 Commands in the Assistant do not function on a computer using Traditional Chinese regional settings with the English version of Minitab. (162462)
6 Stat > Quality Tools > Attribute Agreement Analysis fails when the input columns were created using the Assistant’s Create Attribute Agreement Worksheet. (162661)
7 In the Assistant output for Poisson and Binomial Capability, the conclusion in the Comments that "DPU is not acceptable" is inaccurate in some cases where you fail to reject the hypothesis that the defect rate is below the target. (162902)
8 In the French Assistant Summary Report for 2-Sample % Defective, the Test section of the Comments field displays the wrong conclusion when testing whether Group 1 is less than Group 2 and the p-value is less than alpha. (162954)
9 In the Assistant Summary Report for Chi-Square Goodness-of-Fit Test, the Test section of the Comments field erroneously indicates the process and target percents differ in some cases where the p-value is greater than alpha. The p-value is correct, but the comment can be wrong. (163058)
10 In General Linear Model, stored means for two-way interactions and the interaction plots may be incorrect when a covariate is included in the model. (162846)
11 Using COM, date values put into a variant array are not correct. (160392)
12 Using COM, saved projects become corrupt when running Minitab behind the scenes or any time a scheduled task runs Minitab when the user is not logged into the computer. (162788)
13 Using COM, late binding, which causes Windows to use the registry to determine object-type, is broken. The associated error message mentions "Element not found". (162790)
14 After assigning a formula in the worksheet using column indicators like C1 and C2, reopening the Assign Formula dialog box causes Minitab to replace the column indicators with the actual variable names. This change corrupts the formula's syntax if the column names are so long that they together exceed the character-limit of the Assign Formula dialog box. (161712)
15 When copying and pasting cells from Excel to Minitab and the Excel cells include comments, the pasted cells in Minitab do not reflect the original data values in Excel. (162838)
16 The French version of Minitab names a column incorrectly when creating a split-plot design. It erroneously names the column “DC” (Difficile à changer) instead of the correct name, “SB” (Sous-blocs). (163235)
17 Updating I-MR charts after changing the graph's title and saving the project can result in assertion failures or run-time exceptions. (126679)
18 When using the German version of Minitab and German regional settings, create a Probability Distribution Plot, double-click the curve, click the "Shaded Area" tab, and select the "Probability"
radio button. Minitab erroneously displays a period decimal-separator instead of a comma decimal-separator in the Probability field of the dialog box. (163094)
19 An assertion error occurs after highlighting all items in the Project Manager, then right-clicking and choosing Append to Report. (162440)
20 When a user enters a single response column and a By variable in the dialog box for Capability Analysis for Multiple Variables (Nonnormal), Minitab erroneously displays an error message that no By variable has been provided. (163082)
21 In General Regression, the confidence interval for the Box-Cox lambda is occasionally incorrect. (162442)
22 The option to send Minitab output directly to Microsoft PowerPoint causes assertion failures in Minitab if the user has PowerPoint 2000 or prior versions of PowerPoint. (162812)
23 When using command language (WOPEN) to import a CSV or tab-delimited file, specifying an empty column as a date causes a run-time exception. (163260)
24 In Create Attribute Agreement Analysis Worksheet, Minitab fails to create an "Assessments" column with the same value order as the "Standards" column when using the option "Sample standard/attribute in worksheet". (163509)
25 When a frequency column is used to create a Pareto chart, a run-time error occurs if the user subsequently tries to add Data Labels using a column of labels. (163763)
wang168 (威望:20) (台湾 台湾) 咨询业 咨询顾问
重点是使用英文版者,在简体或繁体中文环境下,使用协助功能会当机
R16.1.1改善了
