塑料E缩写及其中英文对照大全
AAS 丙烯腈、丙烯酸酯、苯乙烯共聚物 Acrylnitril-Acrylicester-Styrene Copolymer
ABR 丙烯酸酯-丁二烯橡胶 (参见AR) Acrylester-Butadiene Rubber(ASTM)
ABS 丙烯腈-丁二烯-苯乙烯共聚物 Acrylonitrile-butadiene-styrene copolymer
A/S 丙烯腈苯乙烯共聚物 Acrylonitrile-styrene copolymer
ACM 丙烯酸酯-2-氯乙烯醚橡胶(参见AR) Acrylester-2-Chlorovinylether rubber(ASTM)
ACS 苯乙烯、丙烯腈与氯化聚乙烯混合物 SAN blend with chlorinated polyethylene
AFMU 亚硝基橡胶;三氟亚硝基甲烷、亚硝基全氟丁酸 Nitrosorubber;TerpolymersofTFE,Trifluoronitrosomethane and Nitrosoperfluorobutyric acid(ASTM)
AL 藻朊酸纤维 Alginate Fibers
ALK 醇酸树脂 Alkyd Resin
A/MMA 丙烯腈-甲基丙烯酸酯共聚物 Acrylonitrile-metry1 methacrylate copolymer
ANM 丙烯酸酯丙烯腈橡胶(参见AR) Acrylester-Acrylnitril Rubber(ASTM)
AP 乙丙橡胶(参见APK,EPM,EPR) Ethylene-Propylene Rubber
APK 乙丙橡胶(参见AP,APT,EPM,EPR) Ethylene-Propylene Rubber
APT 三元乙丙橡胶(参见EPDM,EPT,EPTR) Ethylene-Propylene Terpolymerisate Rubber
AR 丙烯酸酯橡胶(参见ABR,ACM,ANM) Acrylester Rubber(BS)
A/S/A 丙烯腈-苯乙烯-丙烯酸酯共聚物 Acrylonitrile-styrene-acrylate copolymer
BBP 邻苯二酸丁酯苯酯 Benzyl Butyl Phthalate(DIN,ISO)
BOA 已二酸辛酯苄酯 Benzyl Octyl Adipate(ISO)
BMC 块状模塑料 Bulk Moulding Compound
BR 聚丁二烯橡胶 Polybutadiene Rubber(ASTM)
Buty1 丁基橡胶(参见IIR,PIBI) Buty1 Rubber(BS)
CA 乙酸纤维素 Cellulose acetate
CAB 乙酸-丁酸纤维素 Cellulose acetate butyrate
CAP 乙酸-丙酸纤维素 Cellulose acetate propionate
CF 甲酚-甲醛树脂 Cresol-formaldehyde resin
CFK 化纤增强塑料(参见KFK) Chemical Fiber Reinforced Plastics
CFM 聚三氟氯乙烯(参见PCTFE) Polychloro-Trifluoro Ethylene(ASTM)
CFRP 碳纤维增强塑料 Carbon Fiber Reinorced Plastics
CHC 共聚氯醇乙烯化氧橡胶(参见CHR,CO,ECO) Epichlorohydrin Ethylenoxide Rubber
CHR 均聚氯醇橡胶(参见CHC,CO,ECO) Epichlorohydrin Rubber
CM 氯化聚乙烯(参见CPE) Chlorinated Polyethyene(ASTM)
CMC 羧甲基纤维素 Carboxymethyl cellulose
CN 硝酸纤维素 Cellulose nitrate
CP 丙酸纤维素 Cellulose propiomate
CS 酷素塑料 Casein plastics
CT 三醋酸纤维 Triacetate Fiber
CTA 三乙酸纤维素 Cellulose Triacetate(GB)
CTA 三乙酸纤维素 Cellulose triacetate
DABCO 三乙撑二胺 Triethylene Diamine
DAP 苯二酸二烯丙酯树脂(参见FDAP) Diallyl Phthalate Resin(DIN,ASTM)
DBP 邻苯二(甲)酸二丁酯 Dibutyl Phthalate(DIN,ISO,IUPAC)
DCP 邻苯二酸辛酯 Dicapryl Phthalate(DIN,ISO,IUPAC)
DDP 邻苯二酸二癸酯 Didecyl Phthalate(DIN,ISO,IUPAC)
DEP 邻苯二酸二乙酯 Diethyl Phthalate(ISO)
DHP 邻苯二酸二庚酯 Diheptyl Phthalate(ISO)
DHXP 邻苯二酸二已酯 Dihexyl Phthalate(ISO)
DIBP 邻苯二酸二异丁酯 Diisobutyl Phthalate(DIN,ISO)
DIDA 已二酸二异类癸酯 Diisodecyl Adipate(DIN,ISO,IUPAC)
DIDP 邻苯二酸二异癸酯 Diisodecyl Phthalate(DIN,ISO,IUPAC)
DINA 已二酸二异壬酯 Diisononyl Adipate(ISO)
DINP 邻苯二酸二异壬酯 Diisononyl Phthalate(DIN,ISO)
DIOA 已二酸二异辛酯 Diisooctyl Adipate(DIN,ISO,IUPAC)
DIOP 邻苯二酸二异辛酯 Diisooctyl Phthalate(DIN,ISO,IUPAC)
DIPP 邻苯二酸二异戊酯 Diisopentyl Phthalate
DITDP 邻苯二酯二异十三酯 Diisotridecyl P(DIN,ISO)
DITP 邻苯二酯二异十三酯(参见DITDP) Diisotridecyl Phthalate(DIN)
DMC 面团模塑料 Dough Molding Compound
DMF 二甲基甲酰胺 Dimethyl Formamide
DMP 邻苯二酸二甲酯 Dimethyl Phthalate(ISO)
DMT 对苯二酯二甲酯 Dimethyl Terephthalate
DNP 邻苯二酸二壬酯 Dinonyl Phthalate(ISO,IUPAC)
DOA 已二酯二辛酯,已二酸二(2-乙已基)酯
Dioctyl Adipate,Di-2-Ethyexyl Adipate(DIN,ISO,IUPAC)
DODP 邻苯二酸辛、癸酯(参见ODP) Dioctyl Decyl Phthalate(ISO)
DOIP 间苯二酸二辛酯,间苯二酸二(2-乙已基)酯
Dioctyl Isophthalate,Di-2-Ethylhexyl Isophthalate(DIN,ISO)
DOP 邻苯二酸二辛酯,邻苯二酯二(2-乙已基)酯
Dioctyl Phthalate Di-2-Ethylhexyl Phthalate(DIN,ISO,IUPAC)
DOS 癸二酸二辛酯,癸二酸二(2-乙已基)酯
Dioctyl Sebacate,Di-2-Ethylhexyl Sebacate(DIN,ISO,IUPAC)
DOTP 对苯二酸二辛酯,对苯二酸二(2-乙已基)酯
Dioctyl Terephthalate,Di-2-Ethylhexyl Terephthalate(DIN,ISO)
DOZ 壬二酸二辛酯,壬二酸二(2-乙已基)酯
Dioctyl Azelate,Di-2-Ethylhexyl Azelate(DIN,ISO,IUPAC)
DPCF 磷酸二苯甲苯酯 Diphenyl Cresyl Phosphate(ISO)
DPOF 磷酸二苯辛酯 Diphenyl Octyl Phosphate(ISO)
DUP 苯二酸十一烷酯 Diundecyl Phthalate
EC 乙基纤维素 Ethyl cellulose
ECB 乙烯共聚体与沥青混合物 Ethylene Copolymer Bitumen Mixture
ECO 氯醇橡胶(参见CHC,CHR,CO) Epichlorohydrin Rubber(ASTM)
EEA 乙烯/丙烯酸乙酯共聚物 Ethylene Ethylacrylate Copolymer(ISO)
ELO 环氧化亚麻仁油 Epoxydized Linseed Oil(DIN,ISO)
EP 环氧树脂 Epoxide resin
E/P 乙烯-丙烯共聚物 Ethylene-propylene copolymer
E/P/D 乙烯-丙烯-二烯三元共聚物 Ethylene-tetrafluoroethylene copolymer
E/TFE 乙烯-四氟乙烯共聚物 Ethhlene-tetrafluoroethylene copolymer
E/VAC 乙烯-乙酸乙烯酯共聚物 Ethylene-vinylacetate copolymer
E/VAL 乙烯-乙烯醇共聚物 Ethylene-vinylalcohol copolymer
FDAP 苯二酸二烯丙酯(树脂)(参见DAP) Diallyl Phthalate(Resin)
FEP 全氟(乙烯-丙烯)共聚物,四氟乙烯-六氟丙烯共聚物
Perfluorinated ethvlence-propylene copolymer
FLU 维通橡胶 Viton
FPM 偏氟乙烯/六氟丙烯橡胶 Vinylidene Fluoride Hexaflyoropropylene Rubber(ASTM)
FRP 纤维增强塑料 Fiber Reinforce Plastics
FSI 含氟甲基硅烷橡胶 Fluoro Methylsilicon Rubber(ASTM)
GPS 通用聚苯乙烯 General polystyene
GRP 玻璃纤维增强塑料 Glass fibre reinforced plastics
HDPE 高密度聚乙烯 High density polyethylene
HIPS 高冲击强度聚苯乙烯 High impact polyethylene
HMWPE 高分子量聚乙烯 High Molecular Weight Polyethylene
HR 丁基橡胶(参见Butyl,PIBI) Brtyl Rubber,Isprene Isobutylene Copolymer(ASTM)
IR 异戊二烯橡胶
Isoprene Rubber,Cis 1,4-Polyisoprene "Synthetic Natural Rubber"(ASTM,BS)
KFK 碳纤维增强塑料 Carbonfiber Reinforced Plastics(DIN)
LDPE 底密度聚乙烯 Low density polyethylene
MBS 甲基丙烯酸甲酯/丁二烯/苯乙烯共聚物
Methyl Methacrylate Butadiene Styrene Copolymer
MC 甲基纤维素 Methyl cellulose
MDPE 中密度聚乙烯 Middle density polyethylene
MF 三聚氰胺-甲醛树脂 Melamine- formaldehyde resin
MPF 三聚氰胺-酚甲醛树脂 Melamine-phenlo-formaldehyde resin
NBR 丁腈橡胶(参见PBAN) Butadiene Acrylnitrile Rubber,Nitrile Rubber(ASTM,BS)
NC 硝基纤维素(参见CN) Nitrocellulose
NCR 腈基氯丁橡胶 Nitrile Chloroprene Rubber(ASTM)
NDPE 低压法聚乙烯 Low Pressure Polyethylene
NK,NR 天然橡胶 Natural Rubber(ASTM)
ODP 苯二酸辛、癸酯(参见DODP) Octyl Decyl Phthalate(ISO)
OER 油充橡胶 Oil Extended Rubber
PA 聚酰胺 Polyamide
PA4 尼龙4,聚丁内酰胺及纤维 Pa from Butyrolactam
PA6 尼龙6,聚已内酰胺及纤维 Pa from Caprolactam(DIN,ISO)
PA6I 尼龙6I,间苯二酯六甲基二胺及纤维 Pa from Hexamethylene Diamine and Isophthalacid
PA6T 尼龙6T,聚对苯二甲酰已二胺及纤维
Pa from Hexamethylenediamine and Terephthalicacid
PA66 尼龙66,聚已二酰已二胺及纤维 PA from Hexamothylene diamine and Adipic acid
PA610 尼龙610,聚癸二酸已二胺及纤维
PA from Hexamethylene diamine and Sebacic acid(DIN,ISO)
PA1010 尼龙1010,聚癸二栈癸二胺及纤维 PA from Sebacicdiamine and Sebacic acid
PA11 尼龙11,聚氨基十一酸及纤维 PA from 11 amine-Undeca acid(DIN,ISO)
PA12 尼龙12,聚十二内酰胺及纤维 PA from Lauric Lactam(DIN,ISO)
PA6/12 尼龙612,聚已内酰胺和聚十二内酰胺混合物及纤维
Mixed PA from Caprolactam and Dcdecanlactam(DIN,ISO)
PA66/610 尼龙66/610及纤维
Mixed PA from Hexamethylene diamine Adipic acid and Sebacic acid
PAA 聚丙烯酸 Poly(acrylic acid)
PAC 聚丙烯腈及纤维(参见PAN,PC) Polyacrylonitrile(IUPAC)
PAN 聚丙烯腈 Polyacrylonitrile
PB 聚丁烯-1 Polybutene-1
PBTP 聚对苯二甲酸丁二(醇)酯 Poly (butylenes terephthalate)
PC 聚碳酸酯 Polycarbonate
PCR 氯丁橡胶 Polychloroprene Rubber
PCTFE 聚三氟氯乙烯 Polychlorotrifluoroethylene
PDAP 聚邻苯二甲酸二烯丙酯 Poly(diallyl phthalate)
PDAIP 聚间苯二甲酸二烯丙酯 Poly(diallyl isophthalate)
PE 聚乙烯 Polyethylene
PEC 氯化聚乙烯 Chlorinated polyethylene
PeCe 氯化聚氯乙烯及纤维(参见CPVC,PC,PVCC) After Chlorinated PVC
PEOX 聚氧化乙烯;聚环氧乙烷 Poly(ethylene oxide)
PETP 聚对苯二甲酸乙二(醇)酯 Poly(ethylene terephthalate)
PF 酚醛树酯 Phenol-formaldehyde resin
PFEP 四氟乙烯/六氟丙烯共聚物(参见FEP)
Tetrafluoroethylene Hexafluoropropylene Copolymer
PI 聚酰亚胺 Polyimide
PMCA 聚a-氯化丙烯酸甲酯 Poly(methyl-a-chloroacrylate)
PIB 聚异丁烯 Polyisobutylene(DIN,BS)
PIBI 丁基橡胶(参见Butyl,IIR) Butyl Rubber,Isoprene Isobutene Rubber
PMI 聚甲基丙烯酰亚胺 Polymethacrylimide
POM 聚甲醛 polyformaldehyde(polyoxymethylene)
PMMA 聚甲基丙烯酸甲酯 Poly(methyl methacrylate)
POR 环氧丙浣橡胶 Polyepoxy Rubber
PP 聚丙烯 Polypropylene
PPC 氯化聚丙烯 Chlorinated polypropylene
PPO 聚苯醚(聚2,6-二甲基苯醚),聚苯撑氧 Poly(phenylene oxide)
PPOX 聚氧化丙烯,聚环氧丙烷 Poly(propylene oxide)
PPS 聚苯硫醚 Poly(phenylene sulfide)
PPSU 聚苯砜 Poly(phenylene sulfone)
PS 聚苯乙烯 Polystyrene
PSAN 苯乙烯/丙烯腈共聚物(参见SAN) Styrene Acrylnitrile Copolymer(DIN)
PSB 苯乙烯/丁二烯共聚物(参见SB) Styrene Butadiene Copolymer(DIN)
PSI 甲基苯基硅橡胶 Methylsilicone Rubber With Phonyl Group(ASTM)
PSU 聚砜 Polysulfone
PTFE 聚四氟乙烯 Polytetrafluoroethylene
PUR 聚氨酯 polyurethane
PVAC 聚乙酸乙烯酯 polyurethane
PVAL 聚乙烯醇 Poly(vinyl alcohol)
PVB 聚乙烯醇缩丁醛 Poly(vinylbutyral)
PVC 聚氯乙烯 Poly(vinyl chloride)
PVA 聚乙烯醇及纤维(参见PVAC) Polyvinylalcohol
PVAA 聚乙烯醇缩醛纤维 Polyvinyl Acetal
PVCA 氯乙烯-乙酸乙烯酯共聚物 Poly(vinyl chloride-acetate)
PVCC 氯化聚氯乙烯 Chlorinated poly(vinyl chloride)
PVDC 聚偏二氯乙烯 Poly(vinylidene chloride)
PVDF 聚偏二氟乙烯 Poly(vinylidene fluorde)
PVF 聚氟乙烯 Poly(vinyl fluoride)
PVF2 聚偏二氟乙烯(参见PVDF) Polyvinylidene Fluoride
PVFM 聚乙烯醇缩甲醛 Poly(vinyl formal)
PVK 聚乙烯基咔唑 Poly(vinyl carbazole)
PVFO 聚乙烯醇缩甲醛(参见PVFM) Polyvinylformal(DIN)
PVSI 甲基苯基乙烯基硅橡胶 Methylsilicone Rubber with Phenyl and Vinyl Group(ASTM)
PVP 聚乙烯基吡咯烷酮 Poly(vinyl pyrrolidone)
PY 不饱和聚酯树脂 Unsaturated Polyester Resin(BS)
RP 增强塑料 Reinforced plastics
RF 间苯二酚-甲醛树脂 Resoreinol-formaldehyde resin
S/AN 苯乙烯-丙烯腈共聚物 Styrene-acrylonitrile copolymer
SAN 苯乙烯/丙烯腈共聚物(参见PSAN) Styrene-Acrylnitrile Copolymer(GB,DIN,ISO)
SB 苯乙烯/丁二烯(参见PSB) Styrene-Butadiene(DIN,ISO)
SBR 丁苯橡胶 Styrene Butadiene Rubber(ASTM,BS)
SBS 苯乙烯/丁二烯/苯乙烯嵌段共聚物 Styrene Butadiene Styrene block Polymer
SCR 苯乙烯氯丁二烯橡胶 Styrene Chloroprene Rubber(ASTM)
SI 聚硅氧烷 silicone
S/MS 苯乙烯—甲基苯乙烯共聚物 Styrene-a-methy styrene copolymer
S-PVC 悬浮聚合聚氯乙烯 PVC Suspension Polymerized
SYN 合成纤维类 Synthetic Fibers
TCEF 磷酸三氯乙酯 Tricresyl phosphate(ISO)
TCF 磷酸三甲苯酯(参见TCP,TKP,TTP) Tricresyl phosphate(DIN,ISO)
TCP 磷酸三甲苯酯(参见TCP,TKP,TTP) Tricresyl phosphate(IUPAC)
TDI 甲代苯撑异氰酸酯 Toluylene Diisocyanate
TIOTM 偏苯三酸三异辛酯 Triisooctyl Trimellitate(DIN,ISO)
TKP 磷酸三甲苯酯(参见TCF,TCP,TTP) Tricresyl phosphate
TM 聚硫橡胶 Polysulfide Rubbers
TMC 聚酯粘稠模塑料 Thick Molding Compound
TOF 磷酸三辛酯,磷酸三(2-乙已基)酯(参见TOP) Triocty Phosphate,Tri-2-Ethylhexyl Phosphate(DIN,ISO)
TOP 磷酸三辛酯(参见TOF) Trioctyl Phosphate(IUPAC)
TOPM 均苯四甲酸四辛酯 Tetraoctyl Pyromellitate(DIN,ISO)
TOTM 偏笨三酸三辛酯 Trioctyl Trimellitate(DIN,ISO)
TPA 1,5-反式聚戊烯橡胶(参见TPR) 1,5-Trans Polypentene Rubber
TPF 磷酸三酚酯(参见TPP) Triphenyl Phosphate(DIN,ISO)
TPP 醚酸三酚酯(参见TPF) Triphenyl Phosphate(IUPAC)
TPR 1.1,5-反式聚戊烯橡胶(参见TPA) 1,5-Trans Polypentene Rubber
2.热塑性橡胶(参见TR) Thermoplastic Rubber
TR 热塑性橡胶 Thermoplastic Rubber
丁苯嵌段共聚物(参见TPR) Butadiene Styrene Block Copolymer
TTP 磷酸三甲苯酯(参见TCF,TCP,TKP) Tricresyl Phosphate
UF 脲甲醛树脂 Urea-formaldehyde resin
UHMWPE 超高分子量聚乙烯 Ultra-high mojecular weight polyethylene
UP 不饱和聚酯 Unsaturated polyester
UP-G-G 玻纤织物聚酯预浸渍物 Polyester prepregnated Glassfiber Texfile
UP-G-M 玻璃毡聚酯预浸渍物 Polyester Textilglass Mat Prepreg
UP-G-R 玻璃束聚酯预浸渍物 Polyester Textilglass Roving Prepreg
UR 聚氨酯橡胶 Polyurethane Rubber(BS)
UA 醋酸乙烯 Vinyl Acetate
VAC 醋酸乙烯 Vinyl Acetate
VC 氯乙烯(参见VCM) Vinylchloride
VC/E 氯乙烯-乙烯共聚物 Vinylchloride-ethylene copolymer
VC/E/MA 氯乙烯-乙烯-丙烯酸甲酯共聚物 Vinylchloride-ethylene-methylacrylate copomer
VC/E/VAC 氯乙烯-乙烯-乙酸乙烯酯共聚物 Vinylchloride-ethylene-vinylacetate copolymer
VC/MA 氯乙烯-丙烯酸甲酯共聚物 Vinylchloride-methylacrylate copolymer
VC/MMA 氯乙烯-甲基丙烯酸甲酯共聚物 Vinylchloride-methyl methylac-rylate copolymer
VC/OA 氯乙烯-丙烯酸辛酯共聚物 Vinylchloride-octylacrylate copolymer
VC/VAC 氯乙烯-乙酸乙烯酯共聚物 Vihylchloride-vinylacetate copolymer
VC/VDC 氯乙烯-偏二氯乙烯共聚物 Vihylchloride-vinylidene chloride copolymer
VF 硬化纸板 Vulcanized Fiber
VPF 交联聚乙烯 Crosslinked Polyethylene
VSI 甲基乙烯基硅橡胶 Methylsilicone Rubber with Vinyl Group(ASTM)
WM ll增塑剂 Plasticizer
7 回答
3771 浏览
2007-05-09
