英语足球术语
英语足球术语,FREE KICK:任意球(英式足球), TRY 进球(橄榄球)。下面英文详细术语,来自外语角论坛。
Advantage rule:
a clause in the rules that directs the referee to refrain from stopping play for a foul if a stoppage would benefit the team that committed the violation.
Advantages:
situations where a team has possession of the ball and outnumbers the opposition near the opposing goal.
American football:
a term used by non-Americans to distinguish the popular U.S. sport of football from soccer which they also call football.
APSL:
American Professional Soccer League — the nation''''s only outdoor professional soccer league since 1991, consisting of 8 teams in the U.S. and Canada (expanding to 12 by 1995).
Assist:
the pass or passes which immediately precede a goal; a maximum of two assists can be credited for one goal.
Attacking midfielder:
the most forward-playing midfielder, playing right behind the forwards; he supports the offense by providing passes to forwards to set up goals.
Attacker:
any player on the team that has possession of the ball.
Attacking team:
AYSO:
American Youth Soccer Organization — an administrative body of youth soccer which sets rules and provides information and equipment to youth league referees, coaches and players.
Back:
a defender.
Back header:
a player''''s use of his head to direct the ball backwards.
Back tackle:
an attempt by a defender to take the ball away from a ball carrier by swinging the defender''''s leg in front of the ball from behind.
Ball carrier:
a player that has possession of the ball.
Banana kick:
a type of kick that gives the ball a curved trajectory; used to get the ball around an obstacle such as a goaltender or defender.
Beat:
to get the ball through or around an opponent by dribbling or shooting.
Behind the defender:
the area between a defender and his goal.
Bicycle kick:
when a player kicks the ball in mid-air backwards and over his own head, usually making contact above waist level; an acrobatic shot.
Break:
when a team quickly advances the ball down the field in an attempt to get its players near the opponent''''s goal before the defenders have a chance to retreat; also called an advantage.
Breakaway:
when an attacker with the ball approaches the goal undefended; this exciting play pits a sole attacker against the goalkeeper in a one-on-one showdown.
Bundesliga:
The German professional soccer league.
Cap:
a recognition earned by a player for each appearance in an international game for his country.
Carrying the ball:
a foul called on a goalkeeper when he takes more than 4 steps while holding or bouncing the ball.
Caution:
see Yellow card.
Center:
a pass from a player located near the sideline towards the middle of the field; used to get the ball closer to the front of the goal; also called a cross.
Center circle:
a circular marking with a 10-yard radius in the center of the field from which kickoffs are taken to start or restart the game.
Center line:
see Midfield line.
Center spot:
a small circular mark inside the center circle that denotes the center of the field from which kickoffs are taken to start or restart the game.
Central defender:
a player who guards the area directly in front of his own goal in a zone defense; does not exist in a man-to-man defense.
Charge:
to run into an opponent; legal if done from the front or side of the ball carrier; illegal against a player without the ball or from behind.
Chest trap:
when a player uses his chest to slow down and control a ball in the air.
Chip pass:
a pass lofted into the air from a player to a teammate; used primarily to evade a defender by kicking the ball over his head.
Chip shot:
a kick lofted into the air to try to sail the ball over the goalkeeper''''s head and still make it under the crossbar into the goal.
Clear:
to kick the ball away from one''''s goal.
Cleats:
the metal, plastic or rubber points in the bottom of a soccer shoe used to provide a player with traction; term also used to refer to the shoes themselves.
Club:
a team that plays in a league.
CONCACAF:
The Confederation Norte-Centroamericana y Del Caribe de Footbal — the regional organization of North American and Central American soccer under which World Cup qualifying matches are played; member countries include the U.S., Canada, Mexico, and Central American and Caribbean countries.
Consolation match:
a tournament game played between the losers of the 2 semifinal matches to determine the third-place team.
Corner arc:
a quarter-circle with a radius of 1 yard located at each of the 4 corners of the field; on a corner kick, the ball must be kicked from inside this arc.
Corner area:
see Corner arc.
Corner flag:
the flag located at each of the 4 corners of the field, inside the corner area.
Corner kick: (角球)
a type of restart where the ball is kicked from the corner arc in an attempt to score; awarded to an attacking team when the ball crosses the goal line last touched by the defending team.
Counterattack: (反攻)
an attack launched by a defending team soon after it regains possession of the ball.
Creating space:
when a player from the attacking team moves without the ball to draw defenders away from the ball carrier and give him space.
Cross or crossing pass:
a pass from an attacking player near the sideline to a teammate in the middle or opposite side of the field; used to give the teammate a good scoring opportunity.
Crossbar:
the horizontal beam that forms the top of a goal and sits on top of the two posts; it is 24 feet long and supported 8 feet above the ground.
Cut down the angle:
when the goalie comes out of the goal several feet to make himself closer and larger to an attacker, leaving the attacker less net to shoot at.
Cut off:
when a defensive player keeps his body between an attacker and the defender''''s goal, forcing the attacker out towards the sidelines.
Dangerous play:
when a player attempts a play that the referee considers dangerous to that player or others, such as trying to kick the ball out of the goalie''''s hands, even if no contact is made.
Defenders:
the players on the team that does not have possession of the ball.
Defending team:
Advantage rule:
Advantages:
American football:
APSL:
Assist:
Attacker:
Attacking team:
AYSO:
Back:
a defender.
Back header:
Back tackle:
Ball carrier:
Banana kick:
Beat:
Bicycle kick:
Break:
Breakaway:
Bundesliga:
Cap:
Carrying the ball:
Caution:
see Yellow card.
Center:
Center circle:
Center line:
see Midfield line.
Center spot:
Central defender:
Charge:
Chest trap:
Chip pass:
Chip shot:
Clear:
Cleats:
Club:
CONCACAF:
Consolation match:
Corner arc:
Corner area:
see Corner arc.
Corner flag:
Corner kick: (角球)
Counterattack: (反攻)
Creating space:
Crossbar:
Cut down the angle:
Cut off:
Dangerous play:
Defenders:
Defending team:
4 个回复
尘风 (威望:0) (安徽 芜湖) 在校学生 经理 - 我总觉得,星星曾生长在一起,像一串绿葡萄,因为天...
a team''''s function of preventing the opposition from scoring.
Defensemen:
the 3 or 4 players on a team whose primary task is to stop the opposition from scoring; also called fullbacks.
Defensive midfielder:
the player positioned just in front of his team''''s defense; he is often assigned to mark the opposition''''s best offensive player; also called the midfield anchor.
Defensive pressure:
when one or more defenders closely mark a ball carrier to harass him into losing the ball.
Deflection:
the ricochet of a ball after it hits a player.
Direct free kick:
a kick awarded to a player for a serious foul committed by the opposition; the player kicks a stationary ball with no opposing players within 10 yards of him; a goal can be scored directly from this kick without the ball touching another player.
Diving header:
a ball struck near ground level by the head of a diving player.
Draw: (平)
a game that ends with a tied score.
The Draw:
the selection of World Cup teams to place them into playing groups for the tournament and the event surrounding this selection.
Dribbler:
a player who advances the ball while controlling it with his feet.
Dribbling: (带球)
the basic skill of advancing the ball with the feet while controlling it.
Drop ball:
a method of restarting a game where the referee drops the ball between 2 players facing each other.
Drop kick:
when a goalie drops the ball from his hands and kicks it just after it hits the ground.
Endline:
see Goal line.
English Football Association:
an association of English soccer teams founded in 1863 to set soccer rules.
European Cup:
the championship tournament played between Europe''''s top national teams.
F.A.:
Football Association; often used to refer to the English Football Association, who, along with FIFA and other football associations, helps maintain the rules of soccer.
Fake or feint:
a move by a player meant to deceive an opposing player; used by a ball carrier to make a defender think the ball carrier is going to dribble, pass or shoot in a certain direction when he is not.
Far post:
the goalpost furthest from the ball.
Field:
the rectangular area where soccer matches are played.
FIFA:
Federation Internationale de Football Association — the official governing body of international soccer since 1904 which established the World Cup tournament; helps set and revise rules of the game, called the 17 Laws.
FIFA World Cup:
a solid gold statue given to the champion of each World Cup tournament to keep for the next 4 years.
Flick header:
a player''''s use of his head to deflect the ball.
Foot trap:
a player''''s use of his foot to control a rolling or low-bouncing ball.
Football:
name for soccer everywhere except in the U.S.; also, what American''''s call their popular team sport which evolved from soccer and rugby.
Formation: (编队)
the arrangement into positions of players on the field; for example, a 4-3-3 formation places 4 defenders, 3 midfielders and 3 forwards on the field.
Forward line:
the 3 or 4 forwards who work together to try and score goals; consists of two wingers and 1 or 2 strikers.
Forward pass:
a pass made towards the opposition''''s goal.
Forwards: (前卫)
the 3 or 4 players on a team who are responsible for most of a team''''s scoring; they play in front of the rest of their team where they can take most of its shots; strikers and wingers.
Foul: (犯规)
a violation of the rules for which an official assesses a free kick.
4-2-4:
a formation that consists of 4 defenders, 2 midfielders and 4 forwards.
4-3-3:
a formation that consists of 4 defenders, 3 midfielders and 3 forwards; the most common formation used by teams.
4-4-2:
a formation that consists of 4 defenders, 4 midfielders and 2 forwards.
Free kick:
a kick awarded to a player for a foul committed by the opposition; the player kicks a stationary ball without any opposing players within 10 yards of him.
Front header:
the striking of a ball in the air by a player''''s forehead; the most common type of header.
Front tackle:
an attempt by a defender to kick the ball away from an attacker by approaching him from a head-on position.
Fullbacks:
see Defensemen.
Goal:
a ball that crosses the goal line between the goalposts and below the crossbar for which a point is awarded; also, the 8-foot high, 24-foot wide structure consisting of two posts, a crossbar and a net into which all goals are scored.
Goal area:
the rectangular area 20 yards wide by 6 yards deep in front of each goal from which all goal kicks are taken; inside this area, it is illegal for opposing players to charge a goalie not holding the ball.
Goal kick:
a type of restart where the ball is kicked from inside the goal area away from the goal; awarded to the defending team when a ball that crossed the goal line was last touched by a player on the attacking team.
Goal line:
the field boundary running along its width at each end; also called the end line; runs right across the front of the goal; the line which a ball must completely cross for a goal to be scored.
Goalie:
see Goalkeeper.
Goalkeeper:
the player positioned directly in front of the goal who tries to prevent shots from getting into the net behind him; the only player allowed to use his hands and arms, though only within the penalty area.
Goalmouth:
the front opening to each goal.
Goalposts:
the two vertical beams located 24 feet apart which extend 8 feet high to form the sides of a goal and support the crossbar.
Hacking:
kicking an opponent''''s legs.
Halfback:
see Midfielder.
Halftime: (半场)
the intermission between the 2 periods or halves of a game.
Halves:
see Periods.
Hand ball: (手球)
a foul where a player touches the ball with his hand or arm; the opposing team is awarded a direct free kick.
Hat trick:
3 or more goals scored in a game by a single player.
Header:
the striking of a ball in the air by a player''''s head.
Hook:
the curved trajectory of a ball due to spin imparted on it by a kicker, such as in a banana kick.
IFAB:
International Football Association Board — the organization consisting of 4 British soccer organizations and FIFA that approves all changes in the official international rules of soccer called the 17 Laws.
In bounds:
when a ball is within the boundaries of the field, having not completely crossed a sideline or goal line.
In play:
when a ball is within the boundaries of the field and play has not been stopped by the referee.
Indirect free kick:
a kick awarded to a player for a less-serious foul committed by the opposition; the player kicks a stationary ball without any opposing players within 10 yards of him; a goal can only be scored on this kick after the ball has touched another player.
Injury time:
time added to the end of any period according to the referee''''s judgment of time lost due to player injuries or intentional stalling by a team.
Instep drive:
a straight shot taken with the instep of a player''''s foot; usually the most powerful and accurate of shots.
Intermission:
the 5-minute rest period between periods of a game.
Juggling:
keeping a ball in the air with any part of the body besides the hands or arms; used for practice and developing coordination.
Jules Rimet Trophy:
the trophy given to the World Cup winner between 1930 and 1970, after which it was permanently retired.
Kickoff: (开球)
the method of starting a game or restarting it after each goal; a player passes the ball forward to a teammate from the center spot.
Laws of the Game:
the 17 main rules for soccer established by FIFA.
Lead pass:
a pass sent ahead of a moving teammate to arrive at a location at the same time he does.
League:
an alliance of teams that organizes sporting competition.
Linesmen:
the 2 officials who assist the referee in making his decisions; they monitor the sidelines and goal lines to determine when a ball goes out of bounds and they carry a flag to signal their observations.
Linkmen:
see Midfielders.
Loft or lob:
a high-arcing kick.
