作业中的英语词汇
QT:Quality target品质目标
QP:Quality policy目标方针
QI:Quality improvement品质改善
CRITICAL DEFECT:严重缺点(CR)
MAJOR DEFECT:主要缺点(MA)
MINOR DEFECT:次要缺点(MI)
MAX: Maximum最大值
MIN: Minimum最小值
DIA: Diameter直径
DIM: Dimension尺寸
LCL: Lower control limit管制下限
UCL: Upper control limit管制上限
EMI:电磁干扰
ESD:静电防护
EPA:静电保护区域
ECN:工程变更
ECO: Engineering change order工程改动要求(客户)
ECR:工程变更需求单
CPI: Continuous Process Improvement 连续工序改善
Compatibility:兼容性
Marking:标记
DWG: Drawing图面
Standardization:标准化
Consensus:一致
Code:代码
ZD: Zero defect零缺点
Tolerance:公差
Subject matter:主要事项
Auditor:审核员
BOM:Bill of material物料清单
Rework:重工
PILOT RUN: (试投产)
FAI:首件检查
FPIR:First Piece Inspection Report首件检查报告
FAA:首件确认
SPC:统计制程管制
CP: capability index(准确度)
CPK: capability index of process(制程能力)
PMP:制程管理计划(生产管制计划)
MPI:制程分析
DAS: Defects Analysis System 缺陷分析系统
PPB:十亿分之一
Flux:助焊剂
P/N:料号
L/N:Lot Number批号
Version:版本
Quantity:数量
Valid date:有效日期
MIL-STD:Military-Standard军用标准
ICT: In Circuit Test (线路测试)
ATE:Automatic Test Equipment自动测试设备
MO: Manafacture Order生产单
T/U: Touch Up (锡面修补)
I/N:手插件
P/T:初测
F/T: Function Test (功能测试-终测)
ASY:组立
P/K:包装
TQM:Total quality control全面品质管理
MDA:manufacturing defect analysis制程不良分析(ICT)
RUN-IN:老化实验
HI-pot:高压测试
FMI:Frequency Modulation Inspect高频测试
DPPM: Defect Part Per Million
(不良率的一种表达方式:百万分之一) 1000PPM即为0.1%
Corrective Action: (CAR改善对策)
ACC:允收
REJ:拒收
S/S:Sample size抽样检验样本大小
SI-SIV:Special I-Special IV特殊抽样水平等级
CON:Concession / Waive特采
ISO:国际标准化组织
ISA:Industry Standard Architecture工业标准体制结构
OBA:开箱稽核
FIFO:先进先出
PDCA:管理循环
Plan do check action计划,执行,检查,总结
WIP:在制品(半成品)
S/O: Sales Order (业务订单)
P/O: Purchase Order (采购订单)
P/R: Purchase Request (请购单)
AQL:acceptable quality level允收品质水准
LQL;Limiting quality level最低品质水准
QVL:qualified vendor list合格供应商名册
AVL :认可的供货商清单(Approved Vendor List)
QCD: Quality cost delivery(品质,交期,成本)
MPM:Manufacturing project management制造专案管理
KPI:Key performance indicate重要绩效指标
MVT:Manufacturing Verification Test制造验证试产
Q/R/S:Quality/Reliability/Service质量/可靠度/服务
STL:ship to line(料到上线)
NTF:No trouble found误判
CIP:capacity improvement plan(产能改善计划)
MRB:material review board(物料审核小组)
MRB:Material reject bill退货单
JIT:just in time(即时管理)
5S:seiri seiton seiso seiketsu shitsuke
(整理,整顿,清扫,清洁,修养)
SOP:standard operation process(标准作业程序)
SIP:Specification inspection process制程检验规格
TOP: Test Operation Process (测试作业流程)
WI: working instruction(作业指导书)
SMD:surface mounting device(表面粘着原件)
FAR:failure aualysis report故障分析报告
CAR:Corrective action report改善报告
BPR: 企业流程再造 (Business Process Reengineering)
ISAR :首批样品认可(Initial Sample Approval Request)-
JIT:实时管理 (Just In Time)
QCC :品管圈 (Quality Control Circle)
Engineering Department (工程部)
TQEM: Total Quality Environment Management
(全面品质环境管理)
PD: Production Department (制造)
LOG: Logistics (后勤支持)
Shipping: (进出口)
AOQ:Average Output Quality平均出货质量
AOQL:Average Output Quality Level平均出货质量水平
FMEA:failure model effectiveness analysis失效模式分析
CRB: Change Review Board (工程变更会议)
CSA:Customer Simulate Analysis客户模拟分析
SQMS:Supplier Quality Management System供应商品质管理系统
QIT: Quality Improvement Team 品质改善小组
QIP:Quality Improvement Plan品质改善计划
CIP:Continual Improvement Plan持续改善计划
M.Q.F.S: Material Quality Feedback Sheet (来料品质回馈单)
SCAR: Supplier Corrective Action Report (供货商改善对策报告)
8D Sheet: 8 Disciplines sheet ( 8D单)
PDCA:PDCA (Plan-Do-Check-Action) (管理循环)
MPQ: Material Packing Quantity (物料最小包装量)
DSCN: Delivery Schedule Change Notice (交期变更通知)
QAPS: Quality Assurance Process Sheet (品质工程表)
DRP :运销资源计划 (Distribution Resource Planning)
DSS:决策支持系统 (Decision Support System)
EC :电子商务 (Electronic Commerce)
EDI :电子资料交换 (Electronic Data Interchange)
EIS :主管决策系统 (Excutive Information System)
ERP :企业资源规划 (Enterprise Resource Planning)
FMS :弹性制造系统 (Flexible Manufacture System)
KM :知识管理 (Knowledge Management)
4L :逐批订购法 (Lot-for-Lot)
LTC :最小总成本法 (Least Total Cost)
LUC :最小单位成本 (Least Unit Cost)
MES :制造执行系统 (Manufacturing Execution System)
MPS :主生产排程 (Master Production Schedule)
MRP :物料需求规划 (Material Requirement Planning)
MRPⅡ:制造资源计划 (Manufacturing Resource Planning)
OEM :委托代工 (Original Equipment Manufacture)
ODM :委托设计与制造 (Original Design & Manufacture)
OLAP:线上分析处理 (On-Line Analytical Processing)
OLTP:线上交易处理 (On-Line Transaction Processing)
OPT :最佳生产技术 (Optimized Production Technology)
PDCA:PDCA管理循环 (Plan-Do-Check-Action)
PDM:产品数据管理系统 (Product Data Management))
RCCP:粗略产能规划 (Rough Cut Capacity Planning)
SCM :供应链管理 (Supply Chain Management)
SFC :现场控制 (Shop Floor Control)
TOC:限制理论 (Theory of Constraints)
TQC :全面品质管制 (Total Quality Control)
FYI/R:for your information/reference仅供参考
ASAP:尽快
S/T:Standard time标准时间
TPM:total production maintenance:全面生产保养
ESD Wrist strap:静电环
IT:information technology信息技术,资讯科学
CEO:Chief Executive Officer执行总裁
COO:Chief Operaring Officer首席业务总裁
SWOT:Strength,Weakness,Opportunity,Threat
优势﹐弱点﹐机会﹐威胁
Competence:专业能力
Communication:有效沟通
Cooperation:统御融合
Vibration Testing:振动测试
IDP:Individual Development Plan个人发展计划
MRP:Material Requirement Planning物料需求计划
MAT'S:Material材料
LRR:Lot Rejeet Rate批退率
ATIN:Attention知会
3C:Computer ,Communication , Consumer electronic
消费性电子
5W1H:When , Where , Who , What , Why , Ho
5M: Man , Machine , Material , Method , Measurement
人,机器,材料,方法,测量
4MIE: Man,Material,Machine,Method,Environment
人力,物力,财务,技术,时间(资源)
7M1I: Manpower , Machine , Material , Method, Market , Management , Money , Information
人力, 机器, 材料, 方法, 市场, 管理, 资金, 资讯
1 Accuracy 准确度
2 Action 行动
3 Activity 活动
4 Analysis Covariance 协方差分析
5 Analysis of Variance 方差分析
6 Approved 承认
7 Attribute 计数值
8 Average 平均数
9 Balance sheet 资产负债对照表
10 Binomial 二项分配
11 Brainstorming Techniques 脑力风暴法
12 Cause and Effect Matrix 因果图(鱼骨图)
13 CL:Center Line 中心线
14 Check Sheets 检查表
15 Complaint 投诉
16 Conformity 合格(符合)
17 Control 控制
18 Control chart 控制(管制)图
19 Correction 纠正
20 Correlation Methods 相关分析法
21 CPI: continuouse Process Improvement 连续工序改善
22 Cross Tabulation Tables 交叉表
23 CS: Customer Sevice 客(户)服(务)中心
24 DSA: Defects Analysis System 缺陷分析系统
25 Data 数据 Description:品名
26 DCC: Document Control Center 文控中心
27 Decision 决策、判定
28 Defects per unit 单位缺点数
29 Description 描述
30 Device 装置
31 Do 执行
32 DOE: Design of Experiments 实验设计
33 Element 元素
34 Engineering recbnology 工程技
35 Environmental 环境
36 Equipment 设备
37 Estimated accumulative frequency 计算估计累计数
38 EV: Equipment Variation 设备变异
39 External Failure 外部失效,外部缺陷
40 FA: Failure Analysis 失效分析
41 Fact control 事实管理
42 Fatigue 疲劳
43 FMEA: Failure Mode and Effect Analysis失效模式与效果分析
44 FPY: First-Pass Yield (第一次通过)合格率
45 FQA: Final Quality Assurance 最终品质保证
46 FQC: Final Quality control 最终品质控制
47 Gauge system 测量系统
48 Grade 等级
49 Histogram 直方图
50 Improvement 改善
51 Initial review 先期审查
52 Inspection 检验
53 Internal Failure 内部失效、内部缺陷
54 IPQC: In Process Quality Control 制程品质控制
55 IQC: Incomming Quality Control 来料品质控制
56 IS International Organization for Standardization 国际标准化组织
57 LCL: Lower Control limit 管制下限
58 LQC: Line Quality Control 生产线品质控制
59 LSL: Lower Size Limit 规格下限
60 Machine 机械
61 Manage 管理
62 Materials 物料
63 Measurement 测量
64 Median 中位数
65 MSA: Measurement System Analysis 测量系统分析
66 Occurrence 发生率
67 Operation Instruction 作业指导书
68 Organization 组织
69 Parto 柏拉图
70 PPM:Parts per Million (百万分之)不良率
71 Plan 计划
72 Policy 方针
73 Population 群体
74 PQA: Process Quality Assurance 制程品质保证
75 Practice 实务(践)
76 Prevention 预防
77 Probability 机率
78 Probability density function 机率密度函数
79 Procedure 流程
80 Process 过程
81 Process capability analysis 制程能力分析(图)
82 Process control and Process capability制程管制与制程能力
83 Product 产品
84 Production 生产
85 Projects 项目
86 QA: Quality Assurance 品质保证
87 QC: Quality Control 品质控制
88 QE: Quality Engineering 品质工程
89 QFD: Quality Function Desgin 品质机能展开(法)
90 Quality 质量
91 Quality manual 品质手册
92 Quality policy 品质政策(质量方针)
93 Random experiment 随机试验
94 Random numbers 随机数
95 R:Range 全距(极差)
96 Reject 拒收
97 Repair 返修
98 Repeatusility 再现性
99 Reproducibility 再生性
100 Requirement 要求
101 Responsibilities 职责
102 Review 评审
103 Reword 返工
104 Rolled yield 直通率
105 RPN: Risk Priority Number 风险系数
106 Sample 抽样,样本
107 Sample space 样本空间
108 Sampling with replacement 放回抽样
109 Sampling without replacement 不放回抽样
110 Scatter diagram 散布图分析
111 Scrap 报废
112 Simple random sampling 简单随机取样
113 Size 规格
114 SL: Size Line 规格中心线
115 Stratified random sampling 分层随机抽样
116 SOP: Standard Operation Procedure 标准作业书
117 SPC: Statistical Process Control 统计制程管制
118 Specification 规范
119 SQA: Source(Supplier) Quality Assurance 供货商品质保证
120 Stage sampling 分段随机抽样
121 Standard Deviation 标准差
122 Sum of squares 平方和
123 Taguchi-method 田口(试验)方法
124 Theory 原理
125 TQC: Total Quality Control 全面品质控制
126 TQM: Total Quality Management 全面品质管理
127 Traceablity 追溯
128 Training 培训
129 UCL: Upper Control Limit 管制(控制)上限
130 USL: Upper Size Limit 规格上限
131 Validation 确认
132 Variable 计量值
133 Verification 验证
134 Version 版本
135 VOC: Voice of Customer 客户需求
136 VOE: Voice of Engineer 工程需求
137 Inventory stock report:庫存清单报告
138 Sales order report:出货报告
MAX: Maximum最大值
MIN: Minimum最小值
DIA: Diameter直径
DIM: Dimension尺寸
EMI:电磁干扰
ESD:静电防护
EPA:静电保护区域
ECN:工程变更
ECR:工程变更需求单
Compatibility:兼容性
Marking:标记
DWG: Drawing图面
Standardization:标准化
Consensus:一致
Code:代码
ZD: Zero defect零缺点
Tolerance:公差
Subject matter:主要事项
Auditor:审核员
Rework:重工
PILOT RUN: (试投产)
FAI:首件检查
FAA:首件确认
SPC:统计制程管制
PMP:制程管理计划(生产管制计划)
MPI:制程分析
PPB:十亿分之一
Flux:助焊剂
P/N:料号
L/N:Lot Number批号
Version:版本
Quantity:数量
Valid date:有效日期
I/N:手插件
P/T:初测
ASY:组立
P/K:包装
RUN-IN:老化实验
HI-pot:高压测试
ACC:允收
REJ:拒收
ISO:国际标准化组织
OBA:开箱稽核
FIFO:先进先出
PDCA:管理循环
WIP:在制品(半成品)
(整理,整顿,清扫,清洁,修养)
(全面品质环境管理)
Shipping: (进出口)
ASAP:尽快
ESD Wrist strap:静电环
优势﹐弱点﹐机会﹐威胁
Competence:专业能力
Communication:有效沟通
Cooperation:统御融合
MAT'S:Material材料
ATIN:Attention知会
消费性电子
人,机器,材料,方法,测量
人力,物力,财务,技术,时间(资源)
1 Accuracy 准确度
2 Action 行动
3 Activity 活动
6 Approved 承认
7 Attribute 计数值
8 Average 平均数
10 Binomial 二项分配
14 Check Sheets 检查表
15 Complaint 投诉
17 Control 控制
19 Correction 纠正
27 Decision 决策、判定
29 Description 描述
30 Device 装置
31 Do 执行
33 Element 元素
35 Environmental 环境
36 Equipment 设备
42 Fatigue 疲劳
48 Grade 等级
49 Histogram 直方图
50 Improvement 改善
52 Inspection 检验
60 Machine 机械
61 Manage 管理
62 Materials 物料
63 Measurement 测量
64 Median 中位数
66 Occurrence 发生率
68 Organization 组织
69 Parto 柏拉图
71 Plan 计划
72 Policy 方针
73 Population 群体
75 Practice 实务(践)
76 Prevention 预防
77 Probability 机率
79 Procedure 流程
80 Process 过程
83 Product 产品
84 Production 生产
85 Projects 项目
90 Quality 质量
95 R:Range 全距(极差)
96 Reject 拒收
97 Repair 返修
100 Requirement 要求
102 Review 评审
103 Reword 返工
106 Sample 抽样,样本
111 Scrap 报废
113 Size 规格
124 Theory 原理
127 Traceablity 追溯
128 Training 培训
131 Validation 确认
132 Variable 计量值
133 Verification 验证
134 Version 版本
12 个回复
hansenyi (威望:13) (广东 深圳) 咨询业 咨询顾问 - 企業運營管理,體系管理與品質管理
