8D report中 Occurrence和Escape两项,存疑问,谁能帮忙?
请帮忙看一下8D report里面的一个东东。
这个8D report里每一步都有: Occurrence和Escape两项;我搞不清楚这两项具体是填什么。
STEP 4: Identify Root Cause: (attach supporting evidence)
The impact is caused during our loading process. After a hard impacted, the product was deformation, and it could not be normal used.
Occurrence:
Escape:
下面是我们美国公司人员发过来的MAIL,供辅助您了解。
The root cause has not yet been defined. This all pertains to steps 4 - 7 on the 8D. I would like to for you to complete a “5 why’s” sheet.
For example (these are just my words and may not be the same as your analysis)
Why did the muffler get impacted during the loading process?
Answer: It was dropped.
Why was it dropped?
Answer: The muffler was not secured or tied effectively to the forklift truck.
Why was it not tied to the forklift?
Answer: The operator did not think it was needed.
Why didn’t the operator think it was necessary?
Answer: There were no instructions for the operator to tie the muffler to the forklift.
Why were there no instructions for this?
Answer: This part of the process was not defined in the process flow.
Thus, root cause in this case is “no instructions available to the operator to tie the muffler to the forklift to prevent it from being dropped and impacted”.
This instruction must include how to tie it onto the forklift and then training must be done to assure the operator knows how to do it. Lastly, the training must result in effective operator work so this issue will not reoccur. Again, this root cause analysis all pertains to the “Occurrence” portions of steps 4 – 7 on the 8D.
All references to the inspection of the muffler should be part of the “escape” portions of the 8D.
Let me know if you have any questions. Remember, the root cause must be identified and resolved so that this will not happen again.
Occurrence:
Escape:
Why was it dropped?
9 个回复
james7369 (威望:0) (上海 闵行区) 电子制造 工程师 -
这样的根本原因分析方法,适用于8D报告里第4到第7步的"Occurrence"这一项
也就是说,关于8D报告内的第4到第7步内"Occurrence"这项的填写,你应该按"5 why"的方法进行根本原因分析
关于8D报告内的第4到第7步内"escape"这项的填写,你应该从你们是如何进行产品的检验这个方面来考虑
美国人严谨,5 why 的原因分析方法的确是好用
但是这样的原因分析方法竟然可以适用于8D报告内的第4到第7步?呵,有点搞不懂
